Originally posted by soundiceuk
2 cm spark is somehow around 60kv (depending on humidity) should be good enough for me(I should have placed my order a month ago) everytime I make one myself after 1 use few minutes later, It will spark and short itself on nearby coils its really hard to overlap coils together ..
On Voltage Multiplier Circuit, from my experience you need to have your diodes and capacitor twice the voltage rating that your supply, and also your capacitance to be fairly high (100nf above) if you have lower, you have to have them very close together or the High Voltage will wither away back to ambient. (this is actually my biggest problem to create a very high voltage power supply that can be used Unloaded and still not break through the Insulation)
How about the conventional spark excited Original Tesla coil?, it would be better then slayer exciter, but Its also hard to control the voltage, based on my experience.
This project is so interesting its dragging me away from my current .Last edited by ricards; 01-26-2017, 05:45 PM.
Originally posted by ricards View PostHow about the conventional spark excited Original Tesla coil?, it would be better then slayer exciter, but Its also hard to control the voltage, based on my experience.
One idea I'm surprised hasn't been mentioned is the possibility of using a static machine. Let's see, if you had a Wimshurst generator for high voltage DC, you could put two Leyden jars on it with spark gaps and coils and basically have Bruce's mirrored arrangement with no rectifiers whatsoever. Hmm, remind me again what the famous/infamous Testatika machine looks like?
Cockroft-Walton and Villard Cascade High Voltage Multiplier Tips
Google "voltage multiplier paraffin wax"
Some gold out there!
I'll find the link a bit later but what shape was the top of the missing part of the pyramids?
Tesla writes he found the solution in the book of Revelations.
It has something to do with the ark of the covenant.
I will invite the person here that told me this and get them to expand on Revelations and Exodus.Last edited by soundiceuk; 01-26-2017, 07:37 PM.
Originally posted by tswift View PostInteresting idea, but by the time you acquire or fabricate rectifiers capable of taking the full coil voltage I don't think you'd really come out ahead. At least with the multiplier design the diodes only have to be rated for each stage voltage, not the full stack.
Originally posted by soundiceuk View PostInteresting, what about using very high KV Tesla coil as HVM?
Originally posted by soundiceuk View PostI'll find the link a bit later but what shape was the top of the missing part of the pyramids?
Need more explanation please........................
Originally posted by soundiceuk View PostTesla writes he found the solution in the book of Revelations. <SNIP> I will invite the person here that told me this and get them to expand on Revelations and Exodus.
"At this time I made a further careful study of the Bible, and discovered the key in Revelation. The first gratifying result was obtained in the spring of the succeeding year, when I reaching a tension of about 100,000,000 volts—one hundred million volts -- with my conical coil, which I figured was the voltage of a flash of lightening."
My Inventions - Chapter 5—The Influences That Shape Our Destiny
Its a good read.
I have read the whole revelations, and Interpreted differently. I also do not know what he means or what tesla found out. I'm also Interested to know.
OK, I tested the device with antenna and ground running from 2x 12V batteries. The dipole voltage goes from about 26KV unloaded on the workbench to about 24KV loaded with antenna and ground. The ZVS current rises from around 800 mA unloaded to around 1.2A loaded. The PPV firing, which was just a few times per second at 12V input drive to the ZVS, is now much greater and sounds more or less continuous. I would speculate that my antenna characteristics are a reasonably good match at this voltage for this driver. Increasing ion current any more will drive up the input power requirement significantly and make it harder to loop. Just slightly loaded down, enough for good firing on the PPV's but not so much that the driver is dissipating a lot of power.
Video link:
http://gateway.ipfs.io/ipfs/QmVj354X...b4SzkfGijJYEJ8
