Earth Grounding
Hello,
I must get learn to get past the humour of the rational world as in my post above.
The earth grounding seems to be a really big issue. I am mindful of the EV Gray circuit that used a 12 volt battery as a grounding point. Is it safe to use a large battery as a replacement for a poor local earth connection with the high voltages used in the Don Smith designs?
Dwane
Originally posted by Dwane View PostThe earth grounding seems to be a really big issue. I am mindful of the EV Gray circuit that used a 12 volt battery as a grounding point. Is it safe to use a large battery as a replacement for a poor local earth connection with the high voltages used in the Don Smith designs?
In Don's systems the capacitor is the earth, in Ed's it's the high voltage capacitor. In the Ed Gray system we have pictures of, the capacitor is 2 microfarads and there is a resistor in the discharge path of approximately 1000 ohms, so the RC time constant of this circuit is therefore 2 milliseconds. While it can't be conclusively proven what he was using, if I recall correctly Ed's patent states that short pulsed discharge times of 5-10 microseconds are desirable. This is therefore a very small fraction of the time constant of the discharge circuit and the capacitor really doesn't discharge any appreciable degree on a single pulse. Likewise, the voltage drop is essentially all taken up by the resistor, and an inductance in series (like the primary coil of Ed's motor) will not see very much voltage across it at all. It's only those first few electrons coming out of the battery negative, while the full dipole voltage is still in effect, that take on that radiant character and work the magic.
Or at least it sounds like a reasonable hypothesis, one that merits further testing. In Don's system the large Earth capacitance is what we're trying to tap, and it's those first electrons coming up from ground toward a high voltage dipole that work the magic. If you can think about it in these terms, the two systems are not so dissimilar after all. Obviously it would be superior to have a completely portable device requiring no permanent ground connection, but I think we'd all settle for provable, demonstrable, repeatable overunity with high COP of any form whatsoever, then we can focus on refining it and making it better.
I obtained a few high voltage MOSFET's a while back with the intent of putting this to the test once experimenting time permits. If this is correct then you could actually charge up any reasonable high voltage capacitor (a microwave oven cap might do), put a series resistance with it (capable of withstanding that big of a voltage drop!), and a transistor in series to shut off the discharge after 5 microseconds and see what it does to a coil. Easy enough to try....
Originally posted by tswift View PostAlso, if my understanding is correct (unproven) then it should be possible to defeat poor grounding by increasing voltage enough. Assuming Don's suitcase device was genuine (also unproven) then he clearly had it worked out well enough to use any old building wiring ground and get results.
It would seem Heat and Electric phenomenon is somehow the same.. well they're both energy.. it should be.
its as if we already have voltage potential right now like we already have absolute temperature..
anyone see the analogy?! that got me thinking!
If there was a differential in temperature "Heat" will flow.. If there was a difference in Electric Potential "Electricity" would happen..
It like its only relative If you have 400V in your body and I have 400V in mine it would seem that we do not have any voltage potential at all..
ahh.. another term for "Voltage" is "Potential Difference".. well that makes a lot of sense now!.
getting further down below, we would have more potential difference!
okay I see it!
(I actually was talking in my head below the ---- part and realized I was typing! after +++)
correcting errors of judgement
Hello again,
I think I have made several errors in my initial "test " build of Don's Tesla based circuit. First, My layout has been all over the place. where do I start and stop measuring the relative inductances? Next, capturing the radiant pulse requires a very close connection where it can be trapped - if that is the best term. My diodes are a bus trip away from where Don has placed his Diodes. Next, I think, due to my casual layout, I have been unable to work to a resonance - quarterwave. No wonder I have failed. Maybe, my non working replication, it is not specifically an earth problem yet. Clean up the original circuit then test that hypothesis.
I have ordered some HV caps from overseas. No-one here seems to have them. So it will be a while before I can recommence/ finalise my new build.
On the EV Gray. I was of the understanding that his workable knowledge of the circuit operation was limited. Even later builders did not get it.
It is a truism, I think, to state that there is a specific connection with Gray and Don. This has to be Tesla related phenomenon.
Have to go.
There are some great posts on this thread.
Dwane
Originally posted by Dwane View PostI think I have made several errors in my initial "test " build of Don's Tesla based circuit. First, My layout has been all over the place. where do I start and stop measuring the relative inductances? Next, capturing the radiant pulse requires a very close connection where it can be trapped - if that is the best term. My diodes are a bus trip away from where Don has placed his Diodes. Next, I think, due to my casual layout, I have been unable to work to a resonance - quarterwave. No wonder I have failed. Maybe, my non working replication, it is not specifically an earth problem yet. Clean up the original circuit then test that hypothesis.
All this has to work well enough to get a few watts of power through the diodes into the storage caps. Based on Don's build it probably doesn't have to be more than a couple of watts to do some good, but the more watts available the easier it will be to run something useful from the output. Also, adding some ferrite toroid cores inside the coil form increases the inductance and the coupling ratio, and improves the power transfer by around a factor of 2. The power gain (if any) won't appear until the output of the isolation transformer, and it will run cold as power is tapped from it if all is working correctly. For better results, you can use a beefier HVM and put more watts into the input to get more at the output. I think Zilano once mentioned that her input was something like 60 watts (12V at 5A). The efficiency of the step-up or step-down coils is not very high in my experience with experimentation, you might get something like 10%-40% of the power transfer into the secondary and through the diodes into the cap bank. You can measure this by the charging rate of a known cap bank, or with a suitable load resistor. I made myself an HV resistor bank that's up to 2M and 10KV rated, you'll have to calculate the necessary resistance for your setup using Ohm's law. If the output is DC then a standard voltmeter across the load resistor (with a cap of some kind to smooth out the pulsations) will allow you to compute the power (using P=V^2/R), assuming you can get a voltmeter to work properly this close to an oscillating Tesla coil. A scope works better because the probe and the instrument are grounded and shielded.
FINALLY, once all that is operating properly but no overunity magic power gain is showing up, it's time to worry about your grounding provision. This is where I'm stuck too, I am fairly confident in my understanding of the device operation and how it is supposed to work and yet no gain is happening even when I use any of various arrangements to take current from the cap bank and send it through an inverter or transformer. I think the last piece remaining is a good enough ground, but you have to have all the other pieces in place first. Keep building!
Originally posted by Dwane View PostOn the EV Gray. I was of the understanding that his workable knowledge of the circuit operation was limited. Even later builders did not get it.
confusion to order
Hello Tswift,
Thanks for the comprehensive reply. I am mindful of John Bedini's comment about the "Capture" connection for the radiant pulse directly it leaves the coil. The working examples of Don's 160 Kw design that I have seen show a very well ordered and closely coupled devices. It is perhaps, that like myself, when doing rudimentary tests that others attempting Don's set up, their approach is somewhat a loose arrangements of components!! Failure is instantaneous!
It would also appear to myself that we are looking at combining the "Standing Wave" phenomenon with resonance in combination with the coupling of LC tuned circuits!! If true, this is the minefield that has to be traversed and understood. At the moment I am trying to formulate this theoretical mud pie into some sort of order. The only way I can see where a standing wave might exist in L1 is between the pole of the spark gap and the return point to the centre tap of the NST coil. Or vice versa if the spark gap is in the return leg to the centre tap. If I am correct, then the use of Caps to reduce the frequency is the combination two theories on L!.
Does that make sense?
Edit: with regard to Ed. When Marvin cole did not show up for work, this is where it all fell apart for Ed. His knowledge was superficial at best, if I read the information available correctly. and, especially that information as researched by Mark MacKay.
Dwane
Originally posted by Dwane View PostThanks for the comprehensive reply. I am mindful of John Bedini's comment about the "Capture" connection for the radiant pulse directly it leaves the coil. The working examples of Don's 160 Kw design that I have seen show a very well ordered and closely coupled devices. It is perhaps, that like myself, when doing rudimentary tests that others attempting Don's set up, their approach is somewhat a loose arrangements of components!! Failure is instantaneous!
Originally posted by Dwane View PostIt would also appear to myself that we are looking at combining the "Standing Wave" phenomenon with resonance in combination with the coupling of LC tuned circuits!! If true, this is the minefield that has to be traversed and understood. At the moment I am trying to formulate this theoretical mud pie into some sort of order. The only way I can see where a standing wave might exist in L1 is between the pole of the spark gap and the return point to the centre tap of the NST coil. Or vice versa if the spark gap is in the return leg to the centre tap. If I am correct, then the use of Caps to reduce the frequency is the combination two theories on L!.
As far as bench experimentation, I have had the best success using the Zilano-style step-down coil where the HVM oscillates an L1 coil of something like 160 turns on a 1-1/4 inch PVC coil form, with an L2 of just a few turns around the middle of the coil. For power transfer, it seems to make little difference whether there are parallel caps with L2 or not. When using ferrite cores in the coil form the coupling ratio is enough to get decent power transfer into the secondary even without resonance. Hopefully just improving the grounding will be enough to get the desired unconventional results from this configuration.
Originally posted by Dwane View PostEdit: with regard to Ed. When Marvin cole did not show up for work, this is where it all fell apart for Ed. His knowledge was superficial at best, if I read the information available correctly. and, especially that information as researched by Mark MacKay.
Speaking of understanding and explaining the physics at work, here is my latest attempt at explanation. This is my hypothesis about how the radiant effect works. It is an intrinsic property of any dipole, a fundamental symmetry of nature. Now I'm going to get all Tom Bearden on you. By merely establishing the dipolarity, we are engineering the quantum vacuum. Even with no charge carriers present, I think most people would agree that the presence of the dipole changes the structure of spacetime SOMEHOW, such that when any charge carriers show up they feel its presence. But the structure of the quantum vacuum is ALREADY changed before, and independent of, any charge carriers.
Here's my theory: as charge carriers (such the conduction electrons in a wire, or the ions in a plasma) move up or down the voltage gradient of the dipole, they appear to change character. The dipole has a "hot" end, and a "cold" end, and this has to do with action and reaction, not necessarily with "plus" and "minus" polarity. You can demonstrate with a Tesla coil that the color of the streamers changes along the path, even of a single streamer. It turns white for a section in the middle for no obvious reason. Thinking about it logically, this only makes sense if the electricity on one end is of a different character than the electricity on the other end, or else they would merge seamlessly and the color would not change.
Tesla's radiant energy receiver patent #685,957 shows the method to capture just the electrons at the cold end of the potential gradient caused either by a natural source (the ionosphere), or by an artificial source (high positive voltage of any kind). This is all a Don Smith device does. For the Gray device, the dipole is established across a high voltage capacitor, and then a very short pulse of electrons is captured from the negative terminal, while the full dipole voltage is still present in order to cause it to be the desired "cold" electricity.
If this theoretical model is correct (no guarantees), then essentially BOTH kinds of electricity are present at every part of a circuit, or even in empty space around an open-circuit dipole. In order to achieve the desired overunity results like Don and Ed, what is necessary is a kind of fractional distillation of electricity, if you will. We have to get just the sliver of electricity nearest the cold end of the dipole so that it will be very nearly 100% cold electricity (using Ed Gray's terminology). It seems that even a very small fraction of hot electricity in the mix is enough to spoil the show, which is why your grounding has to be very good for a Don Smith configuration to work properly.
As they say, a picture is worth a thousand words, so I submit this for your consideration:
To illustrate this further, I finally managed to take a picture of the white spark. It was as difficult as I expected, with lighting, exposure, and focusing all being issues to contend with. The setup is my small benchtop Tesla coil, powered by a ZVS driver. Power is about 20W. The coil is 3" diameter and about 14" long, resonant frequency about 700 KHz. None of the particulars matter, any Tesla coil should show the exact same effect. It's just that with a low power coil like this it's easy to get closer to it for observation while running, which is how I noticed the white spark effect in the first place.
While the coil is operating, any conductive object brought near the coil will show a fan of sparks leading back towards the coil (the "reaction"). Likewise, there is a fan of sparks coming off the coil (the "action"). When the object is brought near enough, then the two sets of streamers will start to meet on the stronger discharges, and you will find that the small region of overlap right in the middle is where the sparks turn visibly white.
Here is a still picture of the coil in operation with a grounded wire near the hot end of the coil. I tried to capture the white spark effect with still photos but was unsuccessful due to the exposure time. This at least shows the setup.
Here is a still frame from the video I took, it's much darker but the short exposure time allowed me to find a few frames which show the white region clearly. This is unretouched and it really does look like this to the naked eye while observing.
Let's take a closer look at the spark itself. We can see the white region approximately in the middle, but it's not centered. This makes sense when you realize that due to ground impedance, the tip of the wire is not at zero volts. In fact it's quite far from zero, as you can see from the glow around the alligator clip holding the insulated wire in the first still photo above. Some of the voltage drop, the dipole, is happening IN THE GROUNDED WIRE. WE WON'T GET RESULTS FROM A DON SMITH CONFIGURATION LIKE THIS. We have to get down much closer to true earth potential in order to be capturing pure cold electricity at the reaction end of the dipole. How close, I don't know yet.
Ok, now let's put all this together. Here are the theory and experiment side by side, so hopefully everyone can understand what I am attempting to explain:
White spark and more?
Hello Tswift,
Once again, thank you for your comprehensive reply. I think I have been oscillating the L2 at around 10Kv. I have made a pick up for the scope using a 100mh coil and r/c network. This clearly shows my HV activity. However, I am reading the same reaction on both sides of the isolating HV diodes - rated at 100ns. This is disconcerting as I am unable to rationalise this. I get the impression I am nullifying the output - no rectification of signal into the caps. I do not have the L2 to what I suspect should be the tuned resonant frequency. I'll know better when my HV caps arrive. I have calculated the L1 and L2 caps as almost the same as Don's! L1= .2uf and L2 = .046uf . The frequency the new coils are optimising at is 221Khz with the output from the function generator. More on that later when my components arrive.
I have found your observations on the white light intriguing. Very astute observations. I have taken the liberty of expanding the image to a much larger size. To my mind, I am seeing a "whorl" appearing that has more than one white spot - more like a gradual change of temperature about the emmission. And, I might also suggest that this whorl is being created within the confines of the field Hot to cold you have created. That is, the phenomenon might be indicative of a median field demarcation- a sort of "free" or "buffer" zone between the poles.
I hope that is not too elaborate an explanation!
DwaneAttached FilesLast edited by Dwane; 10-16-2017, 02:56 AM.
Originally posted by Dwane View PostOnce again, thank you for your comprehensive reply. I think I have been oscillating the L2 at around 10Kv. I have made a pick up for the scope using a 100mh coil and r/c network. This clearly shows my HV activity. However, I am reading the same reaction on both sides of the isolating HV diodes - rated at 100ns. This is disconcerting as I am unable to rationalise this. I get the impression I am nullifying the output - no rectification of signal into the caps. I do not have the L2 to what I suspect should be the tuned resonant frequency. I'll know better when my HV caps arrive. I have calculated the L1 and L2 caps as almost the same as Don's! L1= .2uf and L2 = .046uf . The frequency the new coils are optimising at is 221Khz with the output from the function generator. More on that later when my components arrive.
Originally posted by Dwane View PostI have found your observations on the white light intriguing. Very astute observations. I have taken the liberty of expanding the image to a much larger size. To my mind, I am seeing a "whorl" appearing that has more than one white spot - more like a gradual change of temperature about the emmission. And, I might also suggest that this whorl is being created within the confines of the field Hot to cold you have created. That is, the phenomenon might be indicative of a median field demarcation- a sort of "free" or "buffer" zone between the poles.
As far as I know, the white spark observation is original to me. I didn't read about it anywhere, and I have never seen pictures of it. Most Tesla coil hobbyists seem only to be concerned with turning Mr. Tesla's most important invention (the magnifying transmitter) into a science toy and wasting more power producing ever bigger sparks. I noticed it a couple years ago, essentially by accident because I was running that coil with my head only about a foot away from it, something you can't do with a much bigger coil throwing large sparks. Anyone can build a coil like that for almost no money, the secondary is a 3" cardboard mailing tube wound with scavenged wire from a microwave oven transformer secondary. The primary is 3.75 turns around a 5" cardboard oatmeal can. The primary capacitance is 10 nF, I had to buy those but they're cheap (9 needed for an MMC). Then another $20 for a ZVS driver and you're in business.
What the white spark region clearly shows, by logical thinking, is that there are at least two different kinds, or characters, of electricity. If the electricity were the same all along the length of the spark they would flow into each other smoothly with no change. There has to be some kind of difference. Then we have to start speculating and theorizing what that might be, and I have offered a proposed theory that's hopefully more than just speculation, but there's no guarantee that anything about my interpretation is correct, more evidence is needed. The only thing we can say unequivocally is that when we do this experiment, the middle part of the spark turns white for reasons we don't fully understand. But that's always when progress gets made in science, when new things turn up that we didn't know to expect. For something as purportedly well as understood as ELECTRICITY in the 21st century, for gosh sakes, how is it that a home experimenter with virtually no money and simple apparatus built mostly out of scrap can produce visible results that aren't predicted in any textbook?
Or even better, build yourself a small tabletop Tesla coil and experiment with it yourself so you can see it first hand.Attached Files- vlcsnap-2017-10-14-22h52m00s927.png (255.1 KB, 21 views)
