  • Originally posted by ilandtan View Post
    This picture is inaccurate. Once you transmitter is broadcasting, even a nearby pipe can harvest the energy. My RX/TX slayer are wound both the same way. We need to peel the BS and rattle shaking to experimentation.
    However Helical coil direction does matter when you set up your transmitter. I had two primaries, both wound with the same diameter just in different directions. No matter how I tried to get one to work, I couldn't produce the same power with the other. My L2's are wound CW, my primary worked the best CCW
    the ETBC is a very flexible device ... it's not inaccurate , you just don't understand it ! it's a model not just a device , for a Tesla wireless transmitter to work in such a compacted area we need other requirement to fill ..
    when i say a model it can be beyond what you see it ...it's not my fault you see it inaccurate.
      I may not understand it, but then again I haven't seen results that want me to understand it. I call em as I see em med, and when people see that pic, and think that's a requirement for TX/RX, and it's simply not true. So shake that rattle... If the goal is power generation, I'm not buying any sacred geometry.
      You'll have guys wasting years trying to build spark gap resonant coils and winding them CW and CCW, back and forth, on and on... more years on the blasted exciter.
      Please don't take it as a personal attack. I have told you before, I am willing to abandon any branch of my research when a learn that there is really nothing there. I'm a hermit crab moving to better shells. If you want to live in yours forever... more power to you. But it's my right to challenge you on experimental grounds and propose sanity checks.
        if there's a result with it you will use it even if you don't understand it ..
        when you work with an ETBC you have too many options , you can work with a Mixed ETBC, you can choose the serial ETBC, you have the dual one ( D-ETBC ) or if you are good enough you can try the T-ETBC
        the beauty here even if you try a T-ETBC you have at least two configuration !! the most successful device is the S-ETBC , now i ask you did you built such device and test it ? most people built such device say it has a kind of hidden power.
        i spent at least a 5 years developing the ETBC, the final model which describe it as a compacted Tesla wireless power transmitter is the key to fully understand it , i can share a photo show some test :
        i was trying the possibility to use stainless steel as a core for the ETBC, heating effect was very tiny compared a normal coil ( i used Mazilli driver which put significant current inside it ..) this tell us it's not a classical electromagnetic device..
        some strange test i was able to light a small incandescent light bulb without using a coil , as i said it's a very flexible device , i just opened the CD connection and put another small ETBC ( with ferrite core ) inside the big ETBC that work as a capacitor only and i can take power !
        in all test there is energy consumption when a load is attached even in a capacitive induction ! this lead me to think there's another parameter should be discovered .
        • Med do you have a video of constant output of parallel loads? Incandescent bulbs are fine, LEDs are fine => 10W.
          Basically something that stays on for up to 10 hours with 8Ahr battery?
            i didn't arrived to this level ! i just compare the IN versus the OUT , in HV there's always an extra power but not to the point of constructing a self sustaining device..
            i use a capacitors and see the discharged power ..
            from time to time i take some studies and try low voltage experiments .. since it's very safe and easy to change the configuration in the fly , this allow too many variation in a small time, in my opinion the same law will work in HV or LV because we are dealing with current and voltage they exist and no way to run away from this fact
            Don Smith video always lead me to think there's more .. he say the output don't affect the input in any respect which seem to be very difficult if not possible to some of us
            i was very upset in an experiment when using a capacitive induction mechanism , the input is 3W when attaching a 3W bulb the consumption increased to be 6W
            i tried to benefit from Lorentz forces without success , i tried the ETBC in the most advanced config but we always learn from mistakes !
              This is definitely true once you have a RX/TX capacitive coupling. Output does not effect input. Once you get your EBTC to resonate, and place another coil nearby, you'll have achieved it.
                can you explain an example about a capacitive coupling ? the question remain why we can't achieve high power ? a few watts can't do a great job !
                • Hi med,ilandtan,
                  https://en.wikipedia.org/wiki/Capacitive_coupling
                  wikipedia does a very good explanation of it. and provides examples too.
                  maybe the reason why we can't have high power is because were not aiming for it..
                  sticking with 12 volts..
                  sticking with slayer exciters..
                  maximizing the geometry..
                  etc..
                  on don's smith table top device, the primary capacitors are 4uf and it looks like a tank circuit.. at 2KV that's about 8 joules..
                  If you guys have ways to eliminate the output affecting the input power.. I think you just need to cycle larger amount of energy..
                  If a resonant tank circuit at that rating is maintained by a source of 12v..
                  and the output does not affect input.. technically you should be able to make a high power devices by now.. don't you think?.
                  • Originally posted by ricards View Post
                    Hi med,ilandtan,
                    etc..
                    Hello ricards,
                    low voltage is very safe to work with since i don't have a clear method how to replicate Don Smith effect ( not the device ..)
                    about the output don't affect the input i think yes there some sort of methods but it's not easy to do !
                      Gentlemen, Tesla was doing this at high power, over great distances. So we know that capacitive coupling at higher power is possible.
                      The transmission is only a secondary effect.
                      If output does not affect input, doesn't it sound logical that you can create an independent circuit that contributes to the input power?
                      Ric... the reasons for Slayer Exciters are because they are cheap, turnkey resonant systems. They're power can be ADDITIVE.
                      For Example: Slayer primary L1TX consumes 6W, L3 of RX produces 3W. I should be able to create the drive for another whole Slayer, or why not just drive a second primary?
                        well that is quite interesting.. I've tried the Idea wired and capacitive coupled to capacitors not really like TX/RX..
                        have you tested if multiple receivers is possible without affecting input? or without diminishing output from other RX?..
                        edit.
                        oh and what is the efficiency of your RX?..
                          edit.
                          My input uses 12.6VDC@470ma and my RX output I measured 297VDC(open across a bridge rectifier)@115ma(when shorted across bridge rectifier).
                          I'm not claiming I get 34W of power, because I can't light a 30 watt incandescent.
                          But I have 15W LED that I can barley get glowing if I harvest the slayer L2 coil, but I can make it probably 70-80% bright on my RX, and that is a 100W equivalent so it throws off a good clip of light. Not bad for 6W of input.
                          I know I can run multiple RX, but soon as I start grounding them together it affects the output of my first RX. The best way is to ground them is to different sides of the battery terminals, so one RX will ground to the Neg, one RX will ground to the positive. If you ground to the battery you eliminate the capacitive effects of nearby objects and increase efficiency. That is the only way you can place an un-grounded metal plate between the two and still transmit the energy.
                          There is a science to all of this and DS knew it. Let me give you and example, I was using 20 inch jumpers, and decided it was too messy but when I moved to 16 inch jumpers, there was a reduction in output. Much of it has to do with the power of your Slayer Exciter, and that is all about tuning.
                          With my 12V Slayer, I can pull about 1.3cm of an arc.
                            there's no problem with high power or great distance if we could compact the same mechanism.. ( we don't need high power and we don't need great distance if we could change that system to work locally )
                            the transmission is a secondary effect but in the ETBC system the two work together , this mean we have a kind of energy balance
                            i think we are using a totally different system this is why we can't understand each other properly.. anyway i just give an opinion to something that may change our view to the electrical laws according Tesla ..
                            regards
                              regards
                              Yep, I agree. I fail to understand what you are trying to accomplish with the EBTC.
                              When you get a self running device. Please message me directly.
                              Thanks!
                              • What I am trying to do is what DS said would be possible:
                                Originally posted by Don Smith to NuEnergy Yahoo group
                                The 02 Device in the 1600’s Chair has three separate coils tuned to the same frequency as the Tesla Coil from the center. A limitless number of separate coils, each duplicate the energy present in the Tesla Coil. This does not draw down or limit in any way the original energy source, however it duplicates fully the source. Magnetic Waves which spin the remote electrons duplicates the original energy source without reducing in any way the source. ( Physics as prescribed by the establishment is 100% wrong ) Feedback from the remote Coils supplies excess energy, some of which can make the Device self sustaining. The 03-2 Device uses the same system for feedback. See upper left end of Device for the dual Coils on a ceramic rod center mount
                                If it's what I'm thinking you should be able to use capacitive coupling to separate input and output, thereby using the output to drive the input harder or maybe even be self sustaining.
