Originally posted by LtBolo
@Zilano
Originally posted by zilanowell energy of a resonant circuit
w=0.5.C. V(SQRD).HZ(SQRD)
SAY W1 IS UR PRIMARY COIL ENERGY WITH CAP
AND W2 IS UR SECONDARY COIL ENERGY WITH CAP
NET ENERGY GAINED FROM RESONANCE
W NET= W2-W1
AND THIS W NET IS TAPPED WITH THIRD COIL DEPENDS UPON NUMBER OF TURNS AND THICKNESS OF GAUGE.
rgds
zelina
Originally posted by dragon View PostThere is a lot of thought provoking information here but I certainly wouldn't rely on Don's "fuzzy math" as any representation of what you could expect from your circuit.
Originally posted by T-1000 View Post"Rigorously, the efficiency of a motor or system may be defined as (total useful output) divided by (total energy input from all sources). No inert system can have an efficiency of greater than 100%, for that would be a violation of energy conservation."
Again, you can measure exciter power source and you cannot measure input from external source. Unles you invent tools for measuring atomic charges and stuff in state of resonance....There are many types of energy involved so won't be easy.
calculate efficiency. We are all hopeful to see more output than we input.
If I see more out than I put in in any of my setups and I can measure it, I will claim
it.I'm not a skeptic, or a troll.
But I do know for a fact it is very difficult to get power measurements that
are accurate with pulsed systems and even more so with spark gaps around
the area.
I can't make any claims from a few devices because I can't measure output reliably.
Anyway good job, I think I'll try it if I can find the stuff. I always say never look a gift horse in the mouth.
It does look interesting, with the feed back and all. It is different. And different is good.
The drawing is a little unclear though, what coil is pulsed ?
Any chance of a better drawing ? Maybe this topic needs to go to another thread.
If I make a drawing and post it will you comment on the drawings correctness ?
Originally posted by zilanoWell there are not many energies involved. the extra energy is from resonance and its just V^2 X F^2 we use the induction effect of this resonating system and thats xtra energy we get. we have to maintain resonance to keep system working.when static is converted to dynamic electrons gain momentum and thats a plus advantage. if we loose resonance then we r at the reality of simple induction with eddy losses. high voltage and high frequency helps to overcome the resistance involved so less energy needed to run the whirlpool. when running a minimal energy required to keep it running and energy fed back. resonance is the key and spark changes from static to dynamic.
rgds
zzzz
Sympathetic string - Wikipedia, the free encyclopedia
Sympathetic strings or resonance strings are auxiliary strings found on many Indian musical instruments, as well as some Western Baroque instruments and a variety of folk instruments. They are typically not played directly by the performer (except occasionally as an effect), only indirectly through the tones that are played on the main strings, based on the principle of sympathetic resonance. The resonance is most often heard when the fundamental frequency of the string is in unison or an octave lower or higher than the catalyst note, although it can occur for other intervals, such as a fifth, with less effect.
The musician retunes the sympathetic strings for each mode or raga, so that when the corresponding note (or one an octave below it) is played on the main strings of the instrument, the sympathetic strings (called tarabs in Indian music) will vibrate in response, providing a lingering halo of sound.
"I consider this extremely important,. said Mr. Tesla. "Light cannot be anything else but a longitudinal disturbance in the ether, involving alternate compressions and rarefactions. In other words, light can be nothing else than a sound wave in the ether..Last edited by MonsieurM; 10-15-2011, 08:07 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
OK Zilano, back on page 31 post #917 I made this post. Saying the voltage control
shunt could be a varistor.
Originally posted by Farmhand View PostThere is one point I can make I think might help.
If the center tap is connected directly to ground at Mhz frequency I think it
would be counter productive, I think there needs to be one of those transient
doohickies (varistor I think) or something there to give some kind of partial isolation or something.
And if no cap is used in the secondary still the FWBR will affect the secondary
frequency and so this is why I think it should be tuned while an equivalent load
to that which is desired is connected to the FWBR.
Uploaded with ImageShack.us
Then you made this post, yelling at me that the voltage control shunt was a variable capacitor.
http://www.energeticforum.com/160535-post924.html
VOLTAGE CONTROL SHUNT IS A VARIABLE CAPACITOR
http://www.energeticforum.com/162375-post1132.html
And post this drawing. Saying the voltage control shunt is now a varistor like I said, in post 917.
Please explain !
What is the significance of this post ? How do we know how much power it is
using to light the lights ?
It looks like a fancy 12v -220v or a 12v - 110v inverter to me.
Without knowing how much it is draining the battery it tells us very little.
THERE R TWO KINDS OF ELECTRICITY DYNAMIC THAT WE USE IN DAILY LIFE AND STATIC THAT EXIST IN ENVIRONMENT. TESLA RADIANT USED STATIC ELECTRICITY TO DYNAMIC. ITS HARD TO MAKE AN ANTENNA 300 FT LONG SO WE MAKE STATIC ELECTRICITY FIRST AND MAKE IT DYNAMIC BY PULSING AND CONVERT IT INTO KINETIC ENERGY ELECTRICITY. HIGHVOLTAGE IS SAME AS STATIC ELECTRICITY WITH ALMOST NO AMPS YET VOLTAGE ONLY. WE CHARGE CAP OR CHARGE INDUCTOR AND PULSE IT TO MAKE DYNAMIC ELECTRICITY. STATIKA IS ONE EXAMPLE OF STATIC TO DYNAMIC ELECTRICITY.
STATIC HAS TO BE STORED OR PULSED DIRECTLY
OR RATHER CHARGE TO LIGHT UP AND LIGHT UP TO CHARGE! SPARK!
RGDS
ZELINA ZILANO ZEIS ZANE
Originally posted by zilanoeverything works fine. no probs at all. am off grid now its been months.
rgds
zzzz
Is your true goal to spread the idea and concept so people become energy independent or just to seek attention with no constructive progress being made?
Originally posted by zilanobasically sitar is 7 strings instrument. orginally created in india and the modern version of it called guitar.
great sympathetic vibrations
music is resonance
and dance is overunity!
rgds
zzzz
just fyi
Sitars are plucked stringed musical instruments, originating from the lute family. The sitar originated in the Middle East originally. In fact, the word "sitar" is Iranian in origin and means 'three strings' (seh means 'three' and tar means 'string') although it is a multi stringed instrument. The History of the Sitar traces its origins to an instrument first built under Medieval Muslim influence from the tanbur, a Middle Eastern lute with a distinctive long neck as well as from the vina, a narrow, intricately crafted Indian Zither. Although images similar to the sitar date back to 1800. Delhi, the more well-known form of the sitar had become prominent by the mid nineteenth century. The long hollow neck and gourd body produce a rich resonance and harmony, and is the dominant instrument used in Hindustani classical music and is played as an accompaniment to dance throughout India and Pakistan. Sitar Music is ubiquitous in these and other Middle Eastern countries.Last edited by MonsieurM; 10-15-2011, 09:19 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by zilanoan invertor does not contain cw or ccw windings. try to make one and let me know wot output u get. well here we see resonance playing at low voltage. the JT acts as oscillator and secondary is in resonance with oscillator. and rf charges the battery and thats the hidden feedback. so 247
HOW MANY BULBS U CAN LIGHT WITH 9 VOLT ONE? OR 12 WITH SAME BRIGHTNESS?
PLZ DONT TAKE MY CAPS LOCK WRITING AS SHOUTING OR YELLING.
rgds
I already have built an inverter with cw - ccw windings the output was zero.
I've wound a toroid core with almost every different winding I can think of for
two phase and one.
The device you showed now that I look is a JT yes and the secondary is two
coils joined in a funny way. I still see no power input to make any decision
about it's efficiency. Where is the battery ?
Anyway I agree with you Zilano that all these systems are based on the Don Smith device.
The Capitals don't really bother me. No probs.
I drew this and it looks like a Don device with the secondary negative going back
to the flyback. I added a FWBR, the secondary can have CW-CCW coils if you
want them.I see what you mean about the voltage control shunt. So in
this setup it's not needed ?
T1000 hows this look ?
I also see a MOT has three coils .
EDIT: My preference would be to put the spark gap after the load.
CheersLast edited by Farmhand; 10-15-2011, 10:16 PM.
