  • @soundiceuk
    Logged in, link still doesn't work.
    • Originally posted by soundiceuk View Post
      @ MR CLEAN
      Give those caps a slight spray of blue and they look very much like Don's caps!
      What is the spec of the caps?
      Great videos!
      You are a true warrior, you just don't quit.
      A true inspiration!!!
      What high voltage module are you using now then?
      Have you tried 6mm pure tungsten electrode spark gap that Dynatron is using yet?
      @ GSM
      The LEDS have been lit since the battery was used to charge the capacitor to start the circuit.
      As far as I am aware the circuit is still running
      I will try to get the lengths, AWGs & time base.
      It would make good experimenting experience for someone with a scope to replicate. Without a scope I guess little to no chance.
      @ All
      From my corner I am starting to witness a culmination of experiments coming together in a very positive direction.
      There are a growing number of us waking up from our slumbers and wanting that freedom so badly things are pulling together in our favour.
      When things are out in the open more (and they will be) this movement is going to start advancing at a monumental pace. I can feel it already.
      Maybe I'm not the only one
      Just released publically. YOU MUST HAVE AND BE LOGGED IN TO YOUR YAHOO EMAIL ACCOUNT TO VIEW. IF YOU HAVEN'T GOT ONE, GET ONE.
      THE ACTION IS ALMOST ABOUT TO START HAPPENING
      http://f1.grp.yahoofs.com/v1/4KTfT6a...Generation.pdf
      Caps are 2000v 10uF each, 4 in parallel so 2kv 40uF there. my volt setting on the meter was getting cooked, just squealing and beeping and screen flashing.
      but it charges them fast
      i actually built that for another person who invited me, but i would still like to play with those big juicy caps
      So i hope he is playing safe with it
      hey im havin problems with my login on your site, any way to check it out? sorry to add to the pile (yahoo site all good, its the other site u have)
      -Shunryu Suzuki
      • A very Good Man on a very long journey
        Gentlemen [and maybe one girl??]
        Regarding our friend David and a moment of Angst ,We all know he wishes no ill,Some may not know he has been at this a very long time,much more dedicated to making this world a better place for "ALL'. He has spent Thousands of hours of his time as well as Thousands of his very hard earned dollars for all to share in not just himself!
        His contributions to this cause are enormous!!
        He is a man apart ,I am proud to call him friend ,and I do understand his frustration as well as an occasional moment of Human emotion ,
        We are all Human and subject to these moments.
        We are also few ...and we need each other,more now than ever!
        Something is coming down the road ...
        We need each other and we need good men we can trust!
        David Fine is such a man.
        Chet
        BE that change !!
        • Originally posted by RAMSET View Post
          Chet
          I aggree I stand behind David hes a hell of a guy.
          -Altrez
          • Thanks Ramset & Altrez!!!
            I've been very frustrated here for a while now. Daemonbart was right when he said, "When you start getting close to a solution there is a lot of noise from the other side of things." We are extremely close to getting this DS device perfected. We must keep our eyes on the ball at all times and that is not so easy with all the interference.
            Thanks for your encouraging words!!!
            • Originally posted by drak View Post
              Ah, I see. Thanks.
              What about the cap values?
              Hi drak,
              please read this page with full attention. and replace interrupter with spark gap.
              Mad Teddy's introduction to electromagnetism
              and also this(ruhmkorf induction coil)
              primary interrupter
              thanks and regards
              dunfasto
              • Hi Dunfasto.
                Magnetism is the effect we observe from the charge (current) flow induced alignment of free electron orbits in a conductor, and from thence induced electron spin alignment within any coil core. A permanent magnet atomically holds the alignment of electron orbits, so that as you look down into a pole face you could imagine peering into an electron spin field.
                Electrically or induced alignments of electron spins polarise and coherently direct (as opposed to random when not aligned) the photonic quanta (EM) radiation radiation events resulting from induced charge change, as via a radio transmitter or spark gap.
                Likewise, photon impingement upon an electron orbit converts that energy to electron charge, and with a multiple coherent photon-electron event, then voltage charge development or current flow/magnetism may be observed.
                Thus the back-EMF of a coil results from the sudden release back into electron charge from the previously flow aligned electron spin fields: a charge carried by previously conducting electrons trapped within the winding wire, until that charge is dissipated or used.
                Cheers ............ Graham.
                • @ All
                  I echo Altrez's and Ramset's words about David Fine.
                  He is a hard working, very fine gentleman and without his direction I would not have been able to bring to you my input.
                  Thank you David
                  I'm looking forward to our next chat
                  For those of you having problems with the link and Radiant Energy Group.
                  Please try:
                  radiant_energy : Radiant Energy Power Generation
                  Click on "Join This Group"
                  Please report back on your findings
                  • Originally posted by Patrick Kelly View Post
                    So, you're just going to have to rate me as a fan of his.
                    Patrick
                    Dynatron make the "White Elephant". On our forums, this is an epidemic called "dinatronofiliya". A pack of lies, soap opera with a lot of series.
                    Personally, I can get almost nothing out of Russian language videos or documents as the translator programs are hopeless. I have never been contacted by Sergei, and as he doesn't speak English and I don't speak Russian, it is most unlikely that he ever will.
                    Patrick
                    Not one of the automatic translators can not translate correctly a very strong Russian language slang. We are now English words have become part of the Russian language in the last 20 years. This is a very dynamic language, I have greatly simplified phraseological units of Russian language.
                    Therefore, none of the technical translators are not able to correctly translate the positions of our forums, live communication can only remove the obstruction.
                    English is much weaker in this sense, but the most common.
                    If someone comes out of our forums, let him write only in English and respects you here.
                    It is unfortunate that many have found my warnings in vain, especially upset Patrick. I do not know now whether or not to acquaint you with our work, after I was called a troll.
                    • Originally posted by VasiliyBuslaev View Post
                      Dynatron has working circuit and he does not say if it is OU device. The capacitor charge can store even megawatts of energy and the proper way of use of it is power amplification as N. Tesla was using extensively.
                      In regards of your opinion it will stay it stays as just another one without your personal experiment with all proper measurements captured on camera...
                        @ MR CLEAN
                        Great videos!
                        @ GSM
                        @ All
                        Hi soundiceuk,
                        this link
                        does not work. can you post working link?
                        thanks and regards
                        dunfasto
                        • Originally posted by GSM View Post
                          Hi Dunfasto.
                          Hi gsm,
                          i am not that knowledgeable as you are. all i wanted to let everyone know that whenever we feed a pulse of current that is not continuous set up electrical oscillations in the coil with a resonant frequency. these oscillations are not continuous and they die due to resistance of the circuit.
                          ruhmkorf coil acts like a nst/ or flyback without diodes.
                          read useful info
                          DC Tesla Coil design
                          Rob's DC powered 5kW Tesla Coil
                          dc tesla coil in operation
                          Tesla Coil DC 24 V - YouTube
                          thanks and regards
                          dunfasto
                          • @ Mr Clean
                            All sorted now brother
                            @ All
                            No restrictions on joining www. energy . team-talk .net now.
                            @ GSM re: Romero's answer.
                            I am not sure about the AWG, it looks like 0.8mm... I am at work now, don't know length and timebase.
                            Check out www.energy.team-talk.net
                            Things are about to go from warm to HOT!!!
                            • Thanks for Posting this
                              Originally posted by dunfasto View Post
                              Hi mainsen,
                              i have edited try using diodes. hope it works. oops! the flyback written with 0.5 mkfd dont means anything so omit it.
                              note: please try and test with diodes with whatever caps you used that produced short sparks.
                              caps in my opinion must be flyback voltage rated.
                              thanks and regards
                              dunfasto
                              How do I get 12 volts 16 amps from this set up at the output?
                              Ged
                              • Originally posted by Gedfire View Post
                                Ged
                                Hi gedfire,
                                this is not my circuit. i just edited it. it was posted on here i just tried to help user mainsen. am not sure it will work or not. i feel the circuit lacks some important parts. i wont recommend you. i think the user zilano always dont specify important part of the circuit like don smith. we have to find it out ourselves whats missing.
                                thanks and regards
                                dunfasto
