CosmicGnarler's chaotic oscillator
  • CosmicGnarler's chaotic oscillator
    YouTube - EarthBattery to SCOPE 0200 22 Oct 09
    Now if we amplify this signal and broadcast it via RF, then capture it again
    YouTube - Jeannacav
    Using this diagnostic tool sitting nearby
    YouTube - poor man's spectrum analyser theory of operation
    that would be interesting.
    Some great work going on
    Thanks for the links Inquorate.
    I have 6' of copper tubing in the earth below my mobile home on the north end and 6 - 1' x 1' sheets of galvanized plates in the ground on south end of my home. I have magnet wire bringing them into my lab for between 1.2-2.2 volts continuously. Can't wait to try this.
    Thanks.
    Edit -
    Hooked up my scope 200mv range @ 100ms across a 22ohm resistor (was smallest i had) and this is what i could read. It is resonating, if i'm not mistaken. Here is a screenshot.
    EnergeticTube.com - Where technology goes Live!
    ETaffairs.com - Your Portal Here on Earth
      Jeez, thanks for naming it after me
      I thought about taking earth signals and amplifying them, using near-field antenna science in the earth, which is basically the properties of resonance. However I would imagine that Stubblefield knew this too ;-)
      I would think it would be hard to find a transistor that could operate at the frequencies of the earth, however that would be the only roadblock to making the thing, right?
      Take it easy Inquorate.
      @ thedude - Earth ground in room is very fun indeed - almost better then a solar panel for the price!
        Interesting idea.
        Agree that finding the transistor can be a challenge.
          @The dude. Whats the arrangement with the plates. Are they stacked or separated and connected with jumpers? How deep is the 6 foot copper pipe? Is the magnet wire buried,laying on the ground,or aerial? Thats the highest voltage Ive seen with a simple copper and galvanized Eb.
            I still think that if you start a signal in the ground it will bound back at you, if this is the case then stubblefield wound be using a signal made by a relay(its in the patent) sorting the coil out and triggering the coil again with the third wineding.
            this would give you a path of no resistants(sorted) then and hign resistant when triggered.
            everyone try this
            clap your hands together bring your hands apart.
            now put a ballon inbetween your hands and this is the coil triggered?
            i may be incorrect but sound good
