Opposed Halves go into OverUnity it would need to be spinning @earth-equiv speed 1st
We need to keep always in mind
Reason: when an object/planet is spinning it's adding to the horizontal mixing of basically straight incoming radiations.
Sector-Partitioned Spinning Record Dialectric Platters = Magnetic Field Pulse-Plasma:
how the capacitor could operate as an
Reason: Momentum of the platter should impart enough inertia to counter and overcome any attraction-slowing problem.
Just been studying a vortex. Could the earth, and all spinning masses, be behaving as a vortex? Spinning heavier air and water toward the upper reaches of it's limit, while at the same time drawing lighter air,gases toward it's center? After a while it would have to equalize, causing it to expel material(volcano), thus throwing out lighter gases which it had accumulated. Also could cause some effects of the phenomena we call gravity. Is it possible that a vortex could be produced by a spinning solid mass? Maybe there is more to gravity than just a single centrifugal force, centripedal force, or even a ionic force. Maybe a combination of joined forces working to make one detectable force. Just a thought. Good Luck. Stealth
The infamous old “Lifter” and Biefield-Brown theory got much more than many thought/believe.
Ionic wind – yes that seems to me actually a great part of what I am trying to achieve. Exactly just that; but let me rephrase a little.
Not ionic-wind to lift, but ‘ionic wind’ to shield against the pressure of ‘gravitons’. So using the ionic movement, we can re-direct the gravity elements to pass around the device, rather than through the device. Now, make these ‘capacitors’ not a one single item as in the J.L. Naudin lifters, but make them in many small packets, place around crafts surface and then use on/off to determine which ones will be active – should enable steering too.
I have to go step by step to verify certain facts first. On later stage in my experiments I foresee the possibility of such cell consist of SOLAR unit to supply HV energy (Low Watt/Amp) to each ‘capacitor’. Each capacitor will be a larger negative plate, smaller positive plate and about 60% of surface as dielectric. Considerations are to make each cell a total of no more than 8x4 cm.
Add into the whole equation still comes the requirements of rotation/vortex – will work on that later; after directional ‘lifting’ sorted out.
I am all getting excited. At least my building plans for the new lab is now approved – Took them 4 months!!!! Now we can legally build.
I would dare to say "Negative'
Yes, spinning will put heavier matter on the exterior and lighter matter to the center; but in the issua of the universe such is just the opposite. Heavier matter is to the core and lighter matter to the exterior.
In general it has been found that spinning/rotating objects do produce some anti-gravity results. Just about anything you can try with, spin it fast and it reduces weight, if magnetized it actually reduces a higher percentage of weight.
Thus I would accept the possibility that a spinning device does reduce the pushing effect of the aether since it somehow re-directs some of that aether sideways. This is something that would need much more thinking and experiments - one which I am presently preparing in my bedroom - to the dismay of Ms W.
RESONANCE
I have three questions, maybe someone can really give a straight answer – other than the only one I have at present: “Do not know” Oh, by the way – the answer must cover all three questions in one!
1. What is the resonance of Aether? (Or Cosmic radiation in general)
2. How was/is it verified other than theoretical mathematics?
3. The most tricky one: How about Aether/Cosmic harmonics?
FREQUENCY COILS:
Now another question for those into sound and communications: A standard choke type of coil is wound for specific frequencies; therefore linear. So if I wind a coil in conical shape, does each winding enable it to transmit/receive different frequencies?
Anyone with a sort of table of reference about this magic of coil winding – re. diameter and number of windings for certain frequencies?
The aether is in another dimension which we can't interpret. We can only identify matter in 3 dimentional context. If we are to study aether, in all it's complexities, we must find a way to bring a 4th dimention into our 3 dimentional reality. Only then can we realize what aether really is, and how it reacts to matter in our 3 dimentional world. Aether must have the ability to cross all dimentions of space, matter, dark matter, and every thing in between. Until we can devise a device to intrepret these other dimentions, I'm afraid studying aether is out of the question. Good Luck. Stealth
