Gravity - just pure plain GRAVITY
  • Aether Fluid versus Ocean Fluid + How-to Make Dial-up Gravity Boot Material:
    Aether presses down on matter, holding
    • The 4th Dimension? Not by chemical alchemy but physical alchemy.
      obtain the desired mass~density change zzzzzzzzzzzzzz
      • Aether = Creation Ramming Speed forming times of solar systems would need readjusting
        being that these
        • Why are most "stable" things in the universe either a sphere or a ring?
          What "force" separates elements of varying density in a centrifuge?
          Why do planets spin faster at greater orbital distances?
          What determines the orbital spacing of planets(and does anyone feel a twinge of ridiculousness when they show CG planets "colliding" in mainstream science periodicals?)
          By what principle are living organisms growing upward and overcoming horizontal equilibrium?
          Why do clouds "float"?
          • harness the power of aether we could repel all incoming meteors and asteroids
            • Great questions!
              We don't know anything, we can only observe what happened in our environment and try to model or theorize them.
              What has been a curiosity for me is the action of "rotation" or "spinning", what is it? I have looked at it as the dancing of existence. Rotation is still a mystery I think. And most of the questions you asked is related to this phenomena. Rotation has something associated with it which is called the Centrifugal Force (What is centrifugal force?)
              I suppose that because the basis of existence is rotation and a mysterious force named the centrifugal force is associated with it, makes stability in "round" (rotated) objects. Maybe rotation is a key component in oneness.
              This is a mystery, and I feel sorry when I see that it is called a Fictitious Force (http://en.wikipedia.org/wiki/Fictitious_force).
              I think that rotation causes the aether to push elements outward.
              The centrifugal force causes the most dense to be pushed more outward, so one should ask if Earth is rotating, then why is it thought that the most dense is at the core?! This may confirm the hollow Earth theory.
              I ask you a question: Why do planets spin?? And orbit?? I don't know.
              Stan Deyo has an interesting video explaining this phenomenon. You can find it at peswiki.com. What this is is the same thing causing the planets to orbit.
              Victor Schauberger has talked about the levity force, which causes this to happen. Living organisms have the capability to utilize this force. This may be the upward push of the Aether. (Dan Winter has interesting theories about this)
              I had never thought about this, I am glad you brought this to attention.
              Maybe there exists a some kind of Aetheric force which does this. This reminds me of Wilhelm Reich's work, which describes clouds as concentrations of Orgone (Aether) Energy. (The Cloud Buster)
              Some interesting thing about rotation, is that it is not relativistic. In other words, it has a point of reference (May be the Aether), otherwise a spinning object would not have the Centrifugal Force acting in it. So there is an "absolute" velocity when we spin an object, and it is not like the velocity it travels space at all, which is not absolute and it is always relative! So rotation is something that has not been understood clearly.
              Elias
              http://blog.hexaheart.org
              • Girls like them <> maybe girls make clouds.
                Clouds floating is probably more than
                • adds to all the other
                  • Anti-Asteroid Aether Weapon <> also would repel incoming meteors (ICBM missiles?)
                    zzzzzzzzzzzzzzzzzzzz
                    • The not so secrets of 369
                      On the 3 and 6 and 9, and explain the significant ZERO
                      ZERO: that was the true beginning, the time when there was nothing but darkness. Time before and after light. Zero is also the nothing that connects the 9 to the 1, the ultimate force of rotation and cycles.
                      One: For of there is only ONE, then there can be no other, no conflict, no harmony, one is the fullness of everything, no dimension, no growth, none other than just ONE.
                      Two: The Paradox. A binary is in perfect harmony, it is linear, binding force between 1 and 1, it appears to be in opposition, but it is not because it has no judgment.
                      THREE: The force of judgment, the balancing point. For now this is the point which became between the 1 and the 1 which is the two. Only when the THIRD is present does the TWO realizes there is a balancing point and they become true oppositions. Conflict enters the realm, selfishness reigns.
                      Four: in the four directions of the compass you will find the four seasons. Suddenly it is not only the white and black, but you have the grays of dawn and sunset.
                      Five: Time to review the creation. The elements of life is in five energies – Water, Earth, Wood, Fire, Metal. From the Water came forth the Earth which brought the trees to grow, they in turn gave fuel to the fire which melts the earth to metal.
                      SIX: The creation is completed and everything is in the ultimate state of conflict, one pull on the other, all going in their own ways. Expansion of the forces that is our universe. Six is the binary directions of the three dimensional existence. Six is opposition for it is two triangles which point in opposing directions.
                      Seven: The perfect number, Spiritual perfection, there is no other number with the properties of seven. The time of building and creating is over. It is time to take a rest and enjoy the creation for coming is the time of destruction in 8 and 9.
                      Eight: Abundance, plentiful, expanding, infinite. The expansion of the universe, time for exploration.
                      NINE: The magnificent final, the most remarkable. The ultimate judgment. The nine is only true to himself, all others leads to the ultimate number nine. Beyond the NINE lies the ZERO. Destruction is in the sunrise, death is on the horizon. It is like the six, but the final conclusion for in the factors of 6 lies the 3x3. Putting the Balancing Judgment of 3 and the 6 of the Completions of Creation together gives you the ultimate judgment of NINE.
                      Nikola Tesla: “If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe”
                      Now we should use this key to the universe:
                      The THREE to balance and get results from the 1 and 2
                      The SIX to get the dimensions – results in vortex, the ultimate of all creation/energy
                      The NINE to judge the results.
                      So when we make a coil, the first (+) and second (–) lines should create oscillation in the third line. By having a binary pair of 123 we will get the ultimate completion of SIX. Take a piece of paper, now make a 3x3 block grit, let us number them from 123 on top, 456 in middle and 789 bottom lines. Inside # 1,3,5,7,9 draw a red circle with arrow clockwise. In blocks # 2,4,6,8 make a blue circle anti-clock wise. Now we know the right hand rule of energy waves in a conductor. Imagine this block a group of nine electric wires and you are looking at them head-on. You pulse the wires with AC current through a bridge rectifier + all on the red, - all on the blue. The current between the wires are complimentary!
                      See upper two sets of 9
                      BUT – you have five red wires and four blue wires. Thus to balance, we need to make another set = 5+4 and 4+5 – that is 12 in total, 1+2=3. At any position you have 3 neighbouring wires where the outer two affect the balance point in the center.
                      See lower two sets of nine:
                      Then there is off course the expansion of the universe and the ultimate judgment of NINE.
                      Let us redesign our coil, but now we will use the 9 as center axis. Immediately we have balance!
                      Nine is black! Now we have four red, four blue, each alternating current direction, and each time we have current flowing – we have alternating results in our pick-up of #9.
                      Off course there is a lot to expand on this, for instance by pulsing the wires in different sequences, by winding bi-filar 147 and 258, or wind single 147258 etc.
                      Lastly: Where is the omni present ZERO? It is in the full glory of a circular toroid coil. All and everything - the whole universe - is encompassed in the donut coil!
                      Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
                      • Originally posted by Aromaz View Post
                        I thought Tesla was refering to frequency and harmonics with this statement. As in chords and tripplets etc, like what Keeley was doing, not so much about the bible and creation.
                        Steve
                        You can view my vids here
                        • Everything in the universe is in perfect harmony. To get OU or FE from our machines, we must break this harmonius cycle. When something is out of harmony in frequency, or resonance, it causes the forces of aether to intervene to bring back these into a harmonius cycle. So the aether is the real energy we are trying to capture to use as our workforce. Only through out of balance inharmonius machines do we have a chance of capturing some of the aether to turn our wheels. Good Luck. Stealth
                          • In this forum the question was asked “What did Tesla found in the Bible” and answering that question also comes with a result that is applicable to magnetism, energy fields and gravity – so I placed this document above.
                            Personally - and I might be either way right or wrong - I think it is in harmony we will find the superior energy. ALL our current systems are working on disruptive energy; all are creating un-balance; that is why they need so much energy to succeed in anything.
                            Tesla was quite obsessed by the number of three, even to such extend he will count his steps and divide by three; food he ate to be in sets of three …. We are looking at a ‘law’ that spans all applications. This law is much bigger than just that of sound and energy; it is cosmic. In the same sense it will also come down to the smallest atom.
                            Read again:
                            "If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe."
                            The bible comes into play with another statement that Tesla made: “The gift of mental power comes from God, Divine Being, and if we concentrate our minds on that truth, we become in tune with this great power. My Mother had taught me to seek all truth in the Bible.”
                            • the future would have to
                              • The hexagon is basically the middle section of two intersecting triangles. Now hexagon is not a solid structure, an equilateral triangle is. Good example is kid toys with metallic ball joints and magnet rods between them. Any other structure will flex but not the triangle. Also the the tetrahedron does not flex but a pyramid does, until you make it to a octahedron, again surrounded by triangles.
                                I think nassim haramein is not far off with his stuff. About the numbers I'm not sure yet, but I think there is lot to be learned from the 10 numbers we use. It's just a matter of perspective. I think aromaz is on the right track and three is the beginning, but it seems to me 9 sits in the middle of these two separating chains as well as zero sits in between of all, 6 is the reverse.. Oh well, I guess it's easy to mess your head with this stuff
                                I like to think of it the following way:
                                6
                                9
                                7 4 1 3 2 5 8
                                0
                                [edit]:
                                or maybe more like this: can you see the 3 triangles forming?
                                6
                                9
                                3
                                7 4 1 0 2 5 8
                                Tetrahedron is formed by 3 triangles, fourth side is the byproduct. Just one idea I've been playing with, not trying to claim anything as I don't have the sufficient data or knowledge.
                                PS. interestingly after mentioning octahedron, one is formed between two intersecting tetrahedrons in a star tetrahedron. Consisting of 6 vertex points and 12 edge vectors. These are the repeating patterns that can be found in fibonacci sequence and its mutations for example.
                                Anyway, if it's helpful feel free to use it, if not, just drop it and move on
