Orgone is the ether
General D.Eisenhower
http://www.nvtronics.org
Guys here are images of a PYAC (pyramid orgone accumulator) we are building , ill have the full construction PDF ready for all soon. Its both for health and CB testing.
its also based on PI dimensions, dont forget the GEOMETRICAL relevance of Ether/Orgone WITH the capacitive material, its helps resonance.
Imageshack - pyrac2
Imageshack - pirac
Imageshack - piframe
Many layers its going to be a 10 ply -
Imageshack - geetandpirac
Imageshack - flexibelmetalconduitfun
Also check out the Cloud Buster course on the uni sire, it has a lot of background info on the Ether and orgone.
Ash
Peter Brock's Energy Polariser
At around the time of his death in 2006 I learned that Peter Brock, a well known racing driver in Australia, had been the subject of controversy in the late 1980's when he planned to install a device called the Energy Polarizer into his Holden Dealer Team (HDT) vehicles, whom were the unofficial racing team for Holden, the GM-owned Australian car manufacturer. Brock claimed that the Polariser would "realign the molecules" of the vehicle, which would improve the performance, handling and fuel economy of the vehicle. Holden told Brock that if he went ahead and sold his vehicles with the device that they would cut all ties with HDT, which is what ended up happening. Brock and Holden eventually made amends a few years later; Brock never mentioned anything about the device again in public.
I found a post at another forum from a person claiming to have contacted and visting Peter Brock at the time of the controversy which gives further insight into the device and Brock's treatment by Holden:
Peter Brock Conspiracy - thescene.com.au
The Energy Polarizer is quite a collector's item and usually sells for over $1200 when it appears on Ebay.
Here is a Youtube clip summarising the controversy:
YouTube - Peter Brock Energy Polarizer
@blackchisel97
I think I am wrong about the outside having to be metalic. I misread labeling of diagram of my attached image. You may have done the same? It is bad labeling, the bottom being different than the sides. Going back to the source description by WR, metal is on the inside.
I also came upon this build of the water container in the forums here:
ORGONE ACCUMULATOR PUBLIC FORUM 2001
"ORAC Forum
With this Orgone Accumulator I accumulated orgone in water in a four litre jar. With this water I turned small metal objects into magnets. Also this water was very refreshing and tasted very good. My plants that were watered grew healthier stronger and faster.
I simply layered the outside of the jar with 35 alternating layers of metallic and organic materials. For the 35 metalic layers I used household tin foil. For the organic layers I used two sheets of news paper, all put together with masking tape. Then I filled the jar with water and it was done. The outside layer (which must be organic)collected soft electrons in turn released hard electrons into the metallic layer. As the metallic layer becomes saturated with hard electrons they jump through the next organic layer into the second metallic layer. This continues on with each successive metallic layer accumulating more and more orgone energy. The water on the inside wich has a great affinity for storing orgone energy becomes very potent. Drink the water, feed it to your plants and animals, use it in your cooking, experiment with it's magnetic inducing effects, but most importantly, share your results with the masses."
I assume he lined the bottom of the glass container also?
"ORAC Forum
I have finished water jug @ 3amI've got 40 layers of Al with double layers of wax paper in between. Instead of wrapping jar with it, which I thought wouldn't be practical (easy to damage or shorten layers) I wrapped ice tea can which is thick paper with Al layer on the inside. I have removed metal bottom. Lining bottom and top cover puzzles me too. It's not a big deal to make laminated bottom after wrapping 40 layers
My better half could feel some vibe when she put her hand over the top, but she's sensitive (can see aura around ppl) Unlike me - I feel tingling sensation while holding 110V terminals but nothing under
I'll get a pic when I charge my batts. Just tried my cam and they're low
Gotta plug into my SSG. My bedroom is getting noisy, I should measure EMF around since there is a few devices running and lots of magnets spinning
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
Originally posted by ashtweth View PostGuys here are images of a PYAC (pyramid orgone accumulator) we are building , ill have the full construction PDF ready for all soon. Its both for health and CB testing.
Imageshack - pyrac2
Imageshack - pirac
Ash
right i have got 25x 12metre by 50cm roll (£25) lots of news papers (out of recycle bins) 2 plexyglass boxs inside diamita 610mm x 377mm with 4mm gap for paper (£80) fibeglass (£10) 780watt generator (£80)I have removed the fuel tank and it has a choke.only need tubing
start build tomorrow
wish me luck sorry pray me sucsess
@blackchisel97 will do a video about it......look at the computer screen tilt your head till so this / is straight and ad a bit more then day dream.....
love and light
Originally posted by Bodkins View Postright i have got 25x 12metre by 50cm roll (£25) lots of news papers (out of recycle bins) 2 plexyglass boxs inside diamita 610mm x 377mm with 4mm gap for paper (£80) fibeglass (£10) 780watt generator (£80)I have removed the fuel tank and it has a choke.only need tubing
love and lightwith your building project.
I did laminate multilayer bottom for my water enclosure as well. Now I have to figure it out different tests.
YouTube - Wilhelm Reich - 'Man's Right To Know' Orgone Orgonite Energy - Part 2 of 3
water has a suction effect on orgone. box it in air but water i dont think you need a box.
watch all the videos good stuff I need a farm hehehe
water has a suction effect on orgone. box it in air but water i don't think you need a box.
Just washed my crystals and left the outside in a sun for awhile. They like washing by hand and sunbathing
Water ORAC
Hello everyone,
I got mu ORAC water jar done. First dose of water was tested without multilayer bottom added later today. Water was left inside undisturbed overnight. I have made a short clip about plus description -
Small jar beside has some crystals inside, after being washed.
Originally posted by ashtweth View PostGuys here are images of a PYAC (pyramid orgone accumulator) we are building , ill have the full construction PDF ready for all soon. Its both for health and CB testing.. Look forward for the result.
Soem suggestion:
- Don't test it on people, use plant or flower first. Compare it with untreated plant.
- Test it under the sun, under the moon and under isolated places covered with loosely woven fabric.
I still think that cloud busting is cloud killer. If that pyramid help cloud busting then it shouldn't be used for people.
I found out some original Reich plans and description on how to make an accumulator, the first page is in spanish, but all the rest is in english:
El acumulador de Wilhelm Reich
edit: can be found here as well:
Orgone Accumulator Building Plans -- Wilhelm Reich vs. the U.S.A. by Jerome GreenfieldLast edited by digitz; 11-12-2009, 02:24 PM.
