Hi Jay I have been working on these thing sense 1969 also thaelin and matthew are right You are one of the pioneers of these things the younger people that have
no interested in doing these things for themselves but are eager to down the Very bright thinkers this makes them fell less obscure to themselves as they are less in themselves obviously
Your transformer design is very creative in thought but has a flaw in the design Most would rather not know any issues that relate to their work
So I will leave it at that.
But as one to another doing this type of work _ kudos - Of course you can always ask what the flaw is Thanks Tom EttCm tech.
Lunke Free Energy Generator
Originally posted by thaelin View PostLunk: This is how it starts just ignore the trash talk. Work starts with an idea, theory and progresses from there. Not all things will work, but hey, it only takes one great thing to come of it for the greater man kind. You have a gift of vision and need to keep allowing it to prosper. There will always be the naysay's in the crowd. Every forum I have been in it is the same.
thay
thay
I want to thank you for all the responses.
I have unpublished my last two books now.
I will only post test results of the prototypes
I am currently testing on this site.
I am so sorry for the trouble I have caused people here.
Lunkster
To the author
All 3 expensive books received and I can tell you, it's a waste of money, all 100% theoretical, my advice is to test your theories yourself before you waste other people's precious time and money on your ideas. The question is, who is pushing this, as it costs a whole lot of money to publish these books.
- 1 like
This is another version of the MEG, Gromov's physics (though in Russian, I think the translator will help)
https://rakatskiy-blogspot-com.translate.goog/2022/09/blog-post.html?_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=ru&_x_t r_pto=wapp
https://translated.turbopages.org/proxy_u/ru-en.ru.864f4e7c-63188241-941ef5ae-74722d776562/https/rakatskiy.blogspot.com/2022/09/blog-post.htmlLast edited by Rakarskiy; 09-07-2022, 11:55 AM.
This looks a lot like the MEG, which uses additional coils to switch the magnetic flux between the two legs:
http://jnaudin.free.fr/meg/megv21.htm
It seems to me your approach won't work, because a magnetic field actually get's "stuck" in one of the two possible paths and won't automatically switch between those two possible paths. This effect is used in the electropermanent magnet:
https://en.wikipedia.org/wiki/Electropermanent_magnet
In this video by the original inventors of the MEG, they explain their thinking and a/o demonstrate how magnetic flux switching works with some small magnets and pieces of iron:
https://youtu.be/no50_5iSr2Y
An interesting detail in this video is that (pretty much at the end IIRC) they say they wanted to go to higher frequencies, but lacked the electronics skills to do so. In case anyone is interested in experimenting in that direction, there are TDK ferrite EE cores available that could be used:
https://www.ebay.com/sch/i.html?_fro...0&LH_PrefLoc=2
Since one would need to insert a magnet in the middle leg, one would need to create room for that, which could be done by filling the gap in the outer two legs with flat bar ferrite cores.
Thanks for sharing,
I've purchased your other 3 books, as your newest isn't available on Amazon.
I do hope all your concepts are not purely theorical....
Looking forward!
Hello all;
I have a theory for an electric generator that will produce electrical power
with the small power needed to operate two solid state relays and a NE555
timer circuit to drive the switches.
Power if you toggle the two switches by hand. The control circuit
to drive the two switches would be minimal in a power system.
I will only show one drawing of the latest generator here because
you can easily find the other ones, most on this forum.
My latest generator design called “Lunke Free Energy Generator” functions as follows:
It is like a three-post transformer with the following features.
The middle leg is a permanent magnet.
The other two legs are output coils.
The output coils alternate the way they are configured in the circuit.
Configuration 1 has the left leg output coil shorted by a switch
So that both ends of the coil are grounded. This is producing
The maximum load on this leg of the generator. The right side
Leg has its switch that is across the coil in the open position. The
flux from permanent magnet flows in the path of least resistance
For the flux flow. So, with the two switches in this condition will
Flow through the right side of the generator.
Configuration 2 has the right leg output coil shorted by a switch
The maximum load on this leg of the generator. The left side
Flux from permanent magnet flows in the path of least resistance
for the flux flow. So, with the two switches in this condition will
Since electrical power generation occurs with changing flux
Through coils of wire, I alternate between the two configurations.
A NE555 time is one simple way to do this with a low power requirement.
These simple circuits can be duplicated in a power system.
This generator is in theory form. I would like to see replicated over and over
Again, by people like you. It is so simple to build and test.
Seeing the drawing helps to understand the operation of this generator.
History of my “Free Energy” overunity work:
I started working with FE in 1969 to design magnetic motors using
unique designs I came up with. It has only been the last few years
that my interest changed to FE generators. With FE generator,
the need for FE motors is less needed. With FE generators
we can use all of our current low efficient electrical products.
This means people only have to purchase one generator instead
of several products to begin with.
When I design devices, I try to look at ways that have not been
Researched yet. This means I have to come up with new technologies.
For motor designs, I have developed the following technologies.
One “Flow through technology”
Two “Three-layer electromechanical movement”
Three “Permanent magnet chain reaction”
For generator designs, I have used the following technologies.
One “Indirect induction”
Two “Permanent magnet chain reaction”
Three “Output coil rerouting”
I have a few generator circuits on this forum.
Most of my designs are in the four books I have written
And sold on Amazon.com along with other places.
The generator “Motionless Switching Magnetosphere Electric Generator”
was my best design because if uses one electromagnet to reroute the
flux paths of 128 or more permanent magnets.
Now this latest generator could be even greater than that generator.
I believe that the “Lunke Fee Energy Generator” will be even more
Popular because is easier and cheaper to build into power systems.
Jay Lunke known as Lunkster
Attached FilesTags: None
