You can use a NST with success at charging capacitors at high voltage. You gonna need a full wave bridge rectifier also. Bear in mind that the FWBR has to be fast (because NST work at Kz range) and withstand the max NST voltage.
Microwave oven diodes are decent for the job. I use fast rise diodes 20Kv, 100nsec for me.
A must is to have chocking coils after your FWBR and before your capacitor. This "detail" i have not meet and my NST went straight to trash can.
Ouch. Its "little" details like this that can ruin and already complex experiment.
I do, but it's written in broken Russian... Do you want me to translate it?
ABC
Yes,please. I know Russian just a bit but was unsuccessful in translation. However that document contains some very interesting informations about Don Smith method.I think so.
I don't think that Google did a perfect translation, but it was worth a laugh.
Good morning from the gospoda.Nachnu INTO collect and repeat this ustroistvo.nesmozhet no Kako builder, caretaker klkdbisch, architect, villa, ......... i.td.i. Tp.Sdes need some navoki, knowledge, opytnyi luggage panetie electrical and electronic radio evlenii and prtsesov. I INTO nashei Discussions such as MORE lyudei participated, and more especially what did you have to have Horshoe familiar with all the material Donald Smith (Before melochaishih details) MELNICHENKO (just barely) and kaneshno about the wave frequency INTO Epher where and how (in most mene sore spot). DIMA will lay out the scheme (you do we draw well) neonika Smith Cator Chiba I sent. Dalché will use such word combinations (coil to) the availability of the core inside, and vasho lyuimoe word spark, replacing IONOVYI conduction channel. While everything I write slowly like a turtle, and plus I'm at work so ische INTO will be with pereryvomi.
Well, start as usual at slevoi pravo.Pervym should we Lattre. fallacy INTO mnogiedumoet INTO he adjusts and Notice NAPREZHENIYA neonnika, it is not pravilno, well, I have not seen rf preobrozovateli BP or other that they did, they have the turnover problem is that they INTO when changes are input naprezheniya rabotaliSTABILNO AND NOT PLAVOLI, and ie if we take our network of 220 (U.S. 110), they usually begins rabotatot 150 and 300 Volt, takzdes should not nor argue. As Smith's meth izmeneli you constructive neonika on INTO he atvetil with ulybkoi NO, and rightly it is небыло need menet. Come dalbshe, we plug it was there he was crafty, but one that is not ro sprshival question vsaaet dle what, I'll answer simply, neonnik purse rasmatrivatKAK CONTOUR and someone does not prevent us from his leads have the same frequency and OR SEVERAL vnem not nothing but izmenitse in dalneishem he can change course in a different direction and find it out, and dle What is it doing so and not otherwise. Then we have the AMU NEONIK prineshy us a lot of controversy and issues, pressuring will review his constructive close as it makes its proizvoditeli.Na zapode in vsei bytovoi (and only) hardware connection osuschestvleetse trime wires, ie WORKING STAGE AND WORKING ZERO iZAZEMLENIE, zero and phase may menetse places as they can's turnover (in America are not much more await vzmozhno and linings rozetki) and zemle ostanetse land. INTO kasaetse dolneishem because Smith To be used akumuletory and converter for 110 (220) and ustonovku neprvezoval at this stage to ZEMLENOMU wire, INTO he mended freedom destvii Connection neonnika. I want to pay heed to vsei INTO likely to connect vyhodnoi coil middle point on the Earth. (THIS WHEN SHE ISPOLZUETSE NORMAL POLZAVANI) and gives us HERE WMOs drugoi frequency of 50 NZ per coil in dalneishem INTO it will be very important, and yet we can adjust the amplitude Lathro 50 NZ. Well, right now we come with 2 e frequencies and by the way sharply to the alleged TESLA nashei the primary, but it continued .....
Quote: temptemp dated 09 April 2010, 14:54:34
algo, if I understood correctly, the point is that at the midpoint of the output transformer in neonnike served 50 Hz, whose amplitude can be adjusted. Do I understand?
Furthermore, what gives us these 50Hz at the midpoint?
Katuha Smitty I have, but it's not just high-trance medium point.
Sorry a lot of work in the evening finished, zabigaya in Peret tell INTO katuhu predetse puts CORE and it will Ferit and iron and good thought for some reason ..... have Cavot on zagnuvshom matrix had a dream to get 8 klvt and at least 1-2 amp .. .. Well this is getting somewhere noverno vosmozhno to use
So while talking about neonikah I want to say that when we zozhgli bulb Ilyich Meanwhile in the USA in LOSVEGAS svetilse all neonnikah and argue in their linings makes no sense, they just osertiment bogatyi.Nasschet otsepki zozemleniya iee razveski (who is in the tank) Rosebery microwave and see how INTO and there (pathfinder you tyknul) important belongs in komyutereom BP ...... INTO kasaetse SMITOVSKOGO he just had podstroiku frequency, this will be cut so that the words obezatelno Switching feritovyh rings, then that podoidem later. Weekend Provadiya soon in the meantime neoonikah were with the resistance, that is held inside a tungsten filament. And so we approach LC circuit that is the primary, if all podkluchat according to Smith as he suggests (and it offers true) that our system does not even zavoditse, that is just iskrovik ionizes and no oscillations are not proishotit because INTO my reel Let them. Then we willingly or not willingly think INTO Smith oshibse all meneli constructive and dle enough one end of the capacitor to transfer to dougoi end iskrovika and our fascination zavoditsa and UTB poluchaetse chistyi TESLA but there is little joy, to high may be enough but as always Amp Nema (you can see my video in the branch of Smith Tolley 1 or 2 stranittsa). Let's go Conder place where he and place, especially INTO SMITH very similar describes how to calculate the length of wire, how to calculate cut Switching and Kako Conder guess. But here to see prices opet lepsus nekak does not go well, the calculations coil (pervychka has averaged 3.5 turns) Conder 1 mF (2e their stuff) ie poluchaetse 2 microfarads, and all if you count the cut chastottu, it poluchaetse relatively small and not as not vezhetse with chastotoi neonnika Cator, he recommends, what kaneshno all written off at the old man say oshibse ...... No gentlemen all right calculations must be carried out with 50 NZ they have the same Unas PROTSESE we do have them, too, admitted on the same prvodu! Dalché on nashei chain SPARK GAP, if the primary poTESLOVSKI strained to avoid, there are MRAC strelet, the sound .... and INTO We are here not only predumali, zduvat, interrupt, mognitnom field destvovat ......... etc. and etc.. HERE DOING NOTHING AND DO NOT HIS PROBLEM IN THIS PLACE VOOBSHSCHE OTHERWISE, A Autologous creators IONIZIRUSCHII PROVODESCHII CHANNEL !!!!!!!!! Let's put the gentlemen Conder opet place, and try to incorporate all of smitovski, look and nothing like those of on iskrovike is ionaya arc, twist Lattre from a designated place arc starts singing under 50 NZ spruce fir Heard and kaneshno little bit tonsevat (that one does on the forum who said INTO 100 square arc setting Tansu under 50nz) opet look INTO have nothing but as always nol, and why the answer downtime and COIL OUR EMPTY. Well dobrolis before Tipo PLASTMASOGOI PIPES ...... To be continued ....
And so the Lord calculate INTO imem, Unas works trance channel is open along the chain is already poking 2 chastotty 50 NZ and frequency neonnika already something INTO (q At the Lord is acknowledged to have no one did so only chesno). Yes Grandpa Smith offers the following neonika hang diodes, then the frequency umnozhitse probably 2e you do is assert in postranstve Ineta, well, it must proveret, but my grandfather is shschitaet and obezatenom. His main words Consult. Before I Go to Page to a pipe, let's talk about the secondary housing. According to witnesses grandfather vzel clippers and from zakaznoi (she is made on order, have it on sale and seichas) and accurately from the mid-wound off there for a few turns, and took a bite kusachkomi, because supposedly it was easier to calculate the resonance secondary housing, there are no gentlemen with them, we wake up to be filmed good and znachet resonance uidet, say premo it did dle 3 eu coil Stoob Nei not over who is not hung and Nemeshaev resonance, yes Owned by 3 eu we have not even videm (some one has to resonate. our primary cell hammer) and semachnye coil Stoob were on the edges (as proposed melnichenko). Well, here we have osnovnoi reproducer energy ...... trouble nashom minds say we love the emptiness and the presence of something is the wrong word, Udoreem of bells, the sound is Al a few miles and all the shouting that's resonance, and BELL TO PUSTOI , but he did not have to get kagda but longer heavy (moshschu) not as nehochu ponet, where it voditse and what direction dvizhetse ...... smoko
And so PIPE (the Cator in Smith is mobile) here to see prices trouble INTO nshi replicators all shakes under thick layers (but not electrical tape and then all spalitse and vonet be) Well I do not know for Rooskey this material, Unas it on another call, and grandfather SMITH steeper all made Pokras all under white color, and vot you tube is pipe and some one of the translators said she INTO plastic, even given the size. Let's look at the photo carefully vnematelno, see INTO there are rings in the middle of where our inductor and at the edges, INTO trouble at all photo tube is shifted, and we all tverdet INTO so they say catches resonance, and these rings lish Stoob coil holders do not talk. In fact, it's not, It is the Lord FERITOVAE RINGS, yes, they have dedyushki tonenkie very best, and they are responsible for the intensifiers, their frequency should correspond to the frequency NEONIKA, or if the Hang diode PERVYCHKE HOW Runshaw mentioned, it Cator POLUCHITSE AT the primary. Start the system and mold opet, opet nol.Esli and put the compass near it will display the INTO are not MPs. The question of where is this dolgozhdanyi resonance, and where to get hot kokoe MP. And these two gentlemen have forgotten the primary INTO nashei poking 50 NZ, and the pipe we incoherent or who did not show side, and if the INTO Nei rod pihnut stalnoi transformer? Zasovuem it includes both always zero, cut it in pieces, ie the middle of the floor inducer, and at the edges through a gap under semachnye, run opet zero, well, not quite. What is hvotaet is NAVODESCHAYA, IS SEMACHNYE, where RESONATOR ....... Smoke break
I'm not sure if I understood that text but I found interesting what it states about neon transformer dimmer.It seems it is used not to change voltage output but rather to set pulsing frequency send to capacitor in Smith primary circuit. That alone and schematic from this article was enough good information, maybe there is more...
I don't know if this has been said, but the first part of the D.Smith device is exactly a Tesla Hairpin Circuit (a.ka. Tesla Impedance Coil)
Look the pictures:
There is other option, and it's using a Bedini Solid State. You can charge a cap with radiant energy, and then discharge it into a tesla coil. The secondary of the tesla coil (radiant energy amplified) then is sent to a capacitor bank.
Remember that radiant energy is the only kind of energy that can be amplified (COP>1). In the electromagnetic energy you will have the same problem--> Amperes and Voltage. But radiant energy is pure voltage.
