Originally posted by Mario
Yes, John has said that a few times regarding about not running the energizer on batts that were charged with spikes. I think the idea is that spike charged batteries were best for inductive loads (EDIT - I MEANT RESISTIVE LOADS). People can believe what they want, but resistive loads like incandescent bulbs seemed whiter and brighter for the same draw compared to normally charged batteries.
He was never doing short swaps that I know of - only long because of the idea of doing long swaps to give the batteries enough time to do the chemical conversion of the potential - or for the battery to "absorb" it. I don't know how absolute he was about that, how much was based on belief about the spikes creating holes (the quantum idea of holes being filled by hot current with normal chargers or cap dumps before it can charge in the forward direction). Bearden gave his own ideas about that particular idea.
For short swaps, I'd have the batteries charged and rejuvenated as possible. I think they just happened to go down to those voltages, then would maintain, then after turning off, would jump back up to x voltage and that would repeat between that upper resting and the lower discharge while staying fairly constant in terms of those upper and lower ranges.
AGM is deep cycle typically but what is the impedance compared to starter batteries?
They definitely charge faster after conditioned with spikes. The conditioning process does do that and countless experimenters have experienced that over the last 25 years. Inverter maybe, not sure about lamps - I have seen resistive loads last longer than charged by normal hot current charging. That was with the 20 hour discharge rating and was like Battery discharge 101 many years ago. Bedini called the cap charging (with spikes) as "forward conversion" because it converts it to normal, forward energy.
I didn't "back pop" the primary. It did not sustain itself. I'd run the trifilar on a different 12 v battery and would do cap dumps to the 2 x gel cells, put them back in my scooter and would drive it around including riding it down to John's shop maybe 100 yards away for a visit and then back to my work.
