Resonance- nice & simple
  • #16
    @ Armagdn03,
    Thanks for taking the time to answer my queries about your circuit. I have played around with inductive coupling circuits and others employing a 555 timer switch, observing the wave forms on my scope. I've watched the wave forms as the coils have gone into increased levels of harmonic resonance, and would like to investigate whether they can be used to draw in energy from the aether if properly employed. That said, I'm still very much a neophyte in this area.
    Briefly, I believe more can be done with LC configs, by taking a cue from the great work of Doc Stiffler, and 'pinging' the "energy lattice" for an augmented return of energy, tho' it might be cold electricity - a different kind of animal than the electricity going in (e.g. DC in, pulsed DC out). I believe this would involve incorporating an AV plug into the setup. I want to respect the integrity of this thread, so if someone lets me know whether it would be better to run with this idea in another thread, I can say more elsewhere.
    Bob
    • #17
      more rants.. on L,R,C...
      >Voltage seem to be more of a static component where current
      >is more of a magnetic component.
      Well not exactly.
      Voltage is more of a measure of "potential energy". There is
      not work happening with voltage. Its like water in a tank ... ready
      to spill when you let it ... but you haven't flushed yet.
      Current is the water flowing in the pipes as it were -- work is happening --
      heat occurs -- magnetic waves are sent out -- electrons are in motion --
      although very slowly in the wire ... incredibly slowly. I was shocked how
      slowly actually. The wave that travels is more like electrons bumping
      each other down the line ...or another view is they jump into the next
      atom ... pushing a corresponding one out to jump into the next --
      and so on.
      But so called electron drift velocity in a wire is
      explained here:
      Speed of electricity flow (speed of current.)
      I too am fascinated by LRC circuits.
      There are some thoughts I have about this topic.
      * How does one go about making L as big as possible and yet
      at the same time keep R small.
      This is ideal for a high Q.
      Answer: Large gauge wire or super-conducting wire or
      introduce something else into the geometry that affects
      the reactance.
      * How does one go about getting high Q?
      In a series LRC, the Q factor affects how long it will ring.
      If you want the ideal "tuning fork effect", you want Q high
      so that oscillations occur very long w/o damping.
      Answer: Need L large, C small and R approaching zero.
      * Is there an energy transfer that can be established between coils
      and capacitors?
      Answer: I think so. See the "coilpacitor" thread I started on this forum.
      If you place a capacitor INSIDE a coil, which appears to be what
      Hendershot did in his fuelless generator, and what Otis T. Carr
      did to power his flying saucer ... and what the Hubbard coil
      may exploit implicitely with the self resonance, the tank circuit
      and its Q may be enhanced. I'm hoping that is the case.
      We need a room temperature solution for high Q and a passive
      component approach -- exploiting geometry -- would be fantastic.
      I think I've proven to myself that you can create a sort of
      "cheap" Van de Graff generator in this way.
      I wonder if the capacitor -- and its electric field -- helps to ionize
      the coil so as to improve its inductance.
      When a coil has a core, its inductance is non-linear.
      Putting a coil in an ionized electric field has benefits as well.
      So I encourage a repeat these sort of resonance effects with
      LRC ... but let us not limit ourselves to traditional off-the-shelf
      inductors and capacitors.
      The "black art" here is in new geometries -- new interactions --
      ionization -- electric fields -- mutual induction -- non-conservitive fields --
      optimizing geometry using the mathematics of Faraday and Maxewell.
      I encourage also reading up on "Magnetic Amplifiers". I think
      this lost engineering art form has some major clues for anyone
      experimenting with over unity power amplification....
      not to mention the thrill of audio tones coming from a huge
      magnetic vibration!!!
      Resonance is really really fun stuff.
      If you haven't seen this ... this is a must see.
      Someone sent me this URL yesterday:
      Marcos Dancing Magnets
      • #18
        Has anyone tried..
        Originally posted by rave154 View Post
        Hi all, just a side-track to my Rodin studies here about something thats been bothering me,
        after watching this video demonstration... YouTube - Energy Propagation
        when at the resonant frequency, there is no (very little ) current flowing through the primary as evidenced by the bulb going out, while at the same time there is 'full' current flowing through the secondary as evidenced by the 2nd bulb lit fully.....well......unless im missing something REALLY stupidly simple here....isnt THIS very situation what were all looking for??????????????
        IE :- little or no draw ( current wise ) on our 'input' side....with a lot of 'Output' on the other side????
        As far as i can see ( lets assume sig gen is putting out say 10V )....when at the resonant frequency, the draw on the input would be ..to all intense & purposes.. w = v x i = 10 x 0.001 = 0.1W
        on output side w = 10 x 0.1 = 1W ( im assuming 10V & 100mA acorss and through the 2nd bulb as evidenced by its brightness )
        so, this resonant system is 10-1 OU?
        What am i missing?
        David. D
        Has anyone tried to make a motor that uses a cap to bounce energy back and forward from a coil?
        If the core of the coil was adjustable, or the capacitor was adjustable, one could vary the motor's speed.
        But it could possibly be efficient enough to drive magnets past other coils and generate more energy out than we have to put in right?
        I gotta get well enough to start doing experiments; I'm having too many ideas to follow through with them all.
        • #19
          it seems connected to "magnetic vector potential"
          effect
          Experiment on Vector Potential by Jean-Louis Naudin
          • #20
            @ Inquorate
            You just saying what Hector Perez in his resonant 3 pH alternating current motor s is doing the last 20 years.
            This method maximizes efficiencies on idling or working of motors. Are they OU? another story..
            Baroutologos
            • #21
              What an interesting experiment. I bet it has to do with Schuman frequency.
              has anyone any experience with resonance of electric circuits or magnetic ones at schuman frequency to share?
              Baroutologos
              • #22
                heres another interesting video there are three parts.
                The swirling shapes at certain frequencies are very interesting.
                YouTube - resonance
                • #23
                  YouTube - resonance
                  as Spock would say........... Fascinating
                  Ive seena couple of cymatics vids before....but ive never seen the spiral galaxy effect shown in that one, interesting the reversal of direction at a different frequency.
                  • #24
                    function generator
                    Guys there is a function generator here for Ł12.99
                    function generator : Maplin Electronics
                    • #25
                      That's a fantastic price.
                      I was curious and went looking for USB interfaced devices.
                      I found this 5 in 1 function unit for $200 with power supplied from USB port: (500ma).
                      The PCSGU250 is actually a combination of 5 PC based test instruments in 1 compact unit!
                      Functions include a PC oscilloscope, function generator, transient recorder, bode plotter, AND a spectrum analyzer.
                      PCSGU250 USB 2 Channel PC Oscilloscope and Function Generator
                      • #26
                        The Good, the bad and the ugly of Resonance.
                        YouTube - Ground Resonance - Side View
                        YouTube - Ground Resonance - Rear View
                        • #27
                          Hi all,
                          just came across this by accident ( as usual )..... dont quite know what to make of it...neither does the guy in the video, he seems as puzzled by it..
                          i have placed this in this "resonance" thread because.....well...im not sure really..
                          YouTube - FREE ENERGY FROM RESONANCE, I THINK! WHO KNOWS WHY!
                          hopefully somebody out there has two or more of these shake-lights and can have a play with them.
                          David. D
                          • #28
                            another update from the same guy...
                            YouTube - 12 hour update free lights
                            • #29
                              Originally posted by Inquorate View Post
                              God I wish I had a signal generator - though a 10mhz xtal sig gen I do have..
                              @Inquorate; See my posting at -
                              http://www.energeticforum.com/renewa...html#post78906
                              This might be more practical.
                              • #30
                                Hi all,
                                David. D
                                Debunked.
                                This gent is a fake; so are most (if not all) his attempts to draw attention.
                                There are two kinds of 'Shake Lights' the original that you need to shake
                                - have a small coil moving over a bar magnet and charging a small capacitor
                                which then discharge to a LED light. Their shine is only few minutes.
                                Off course you can make it longer by adding capacitors and windings on coil.
                                Though a little expensive, but real handy little tool. Over time it gets to be
                                in-effective as residue builds up in coil and cap. All you need to do is installing
                                a reverse effect switch - to change polarity and degauss coil.
                                Use neo magnets….
                                Then there is another 'shake light' it has Lithium batteries hidden out of sight.
                                The shake coil and cap is only acting as a switch. These last for 40+ hours.
                                What is presented in this video is one of the later models - with Li batteries
                                and use of magnet is only acting to 'switch on'.
                                You have to look, then look at what you are looking at:
                                then you have to look at yourself looking at what you are looking at;
                                lastly you have to redo all of the above from 16 angles - only to begin
                                understanding at what you are looking at.
