Mini Tesla Self charging?????
Hi to all
Lidmotor,
Ive just replicated your mini tesla and run it at 12 v dc car battery 70ah
L1 29 awg 25 mm dia 140 mm tall L2 6 turns 21 awg 2 Mpsa06 2 IN4148 and one led Slayer circuit
voltage reading load( no charging done on the old battery)
12.59 9am 12.56 6pm 20 w fl lamp 20 Jul 90 ma
12,63 9 am 12,65 6pm 8 w fl lamp 21 Jul 40 ma
For an 8 w lamp there was voltage increase by 2 millivolt
The mini tesla sits on top of the used car battery
this must be overunity or something else
work in progress and will update later
totoalas
Hi Lidmotor,
Thank you so much for the prompt reply and detailed information.
I will fiddle with the L2 coil as suggested.
Kind Regards, Penno
Coils
Originally posted by penno64 View PostHi Lidmotor,
May I ask how many turns and what gauge on your L1 and L2 ( 6 turns ?) coils.
I am not having any luck in getting my setup to work.
Also, is your L2 just magnet wire and if I may also ask about the diameters of your winds?
Kind Regards, Penno
I hope that this helps.
Here is a video of the lastest configuration:
YouTube - Mini Tesla coil with 110v LED bulb.ASF
LidmotorLast edited by Lidmotor; 07-21-2010, 06:30 AM.
Hi Lidmotor,
I might add, I followed gbluer's circuit, though I fear I may not have enough turns on my L1. I used
one complete spool of 0.5mm enamel copper wire.
Bringing my hand near L1 greatly affects the waveform I am seeing on my scope reading from base of MPSA06.
Some times the voltage measured at the 6v battery pack drops but other times it is stable.
Any help greatly appreciated.
Kind Regards, PennoLast edited by penno64; 07-21-2010, 06:17 AM.
Mini Tesla Coil --- finished
@All
I took a break from the electrolysis experiments and finished up my Mini Tesla coil (which really isn't). It made a nice small test platform for these experiments that we are doing. I used the Slayer Exciter circuit and basically copied EM devices tower design. I decided to run it off one of those one AA battery cell phone chargers and it worked quite well.
Here is the video of it running:
YouTube - Mini Tesla Coil ---Finished.ASF
Lidmotor
Gas shortage
@ Bob
Thanks for the excellent description on what we need to look for and the precautions required. I built a small HHO electrolyzer awhile back so I know a little about this already. That is what is so puzzeling with the "diode-in the-water electrolysis" setup. This isn't doing what it is supposed to do ---at least the way I'm doing it. I don't get the H "pop" OR an increase in burning as from O2. I don't get anything!! The only thing that I can attribute my failure to is inadequate gas production. I'm just not getting enough gas to see anything.
Lidmotor
Thanks Jonny
Thank you sir !!!, I now have a running circuit , fun fun fun .
Now how do I strip a peltier unit ? hmmmmmmmmm.
Thanks heaps .
Robbo
Doubts about hydrogen flame
Hi.I may have leaped before i looked with flame experiment as i have been looking at it again this morning and it may be an arc from the needle which ignites the plastic as it is very flamable and burns with an orange flame and i can draw a 1cm arc of the needle although i think the gas contributes to the flame but i am pretty sure there must be an arc to the plastic.Sorry if i have misled anyone but i will keep trying.Jonny
Originally posted by jonnydavro View PostI checked with a neon, held close to the output wire and it lights noticeably more on one side than the other but add a croc lead to the other side and they both glow bright.JonnyLast edited by xee2; 07-19-2010, 02:48 AM.
Originally posted by Lidmotor View Post@ Jonny, Woopy & All
I worked all day trying to get something to burn and had no luck --again. There is something very strange going on here. Jonny you might be right about a "combustion chamber" being needed. Woopy my needle setup was about like yours and I got nothing to happen.
This is the kinda thing that keeps me awake at night.
Lidmotor
As we work with HHO and Hydrogen in large qty (15 to 20 LPM) all day, might I suggest a few things....
1. Put a bit of clay in the end of the needle to allow a "SMALL" bitt of pressure to build up....then pull it off and with LOTS of safety precautions, light it.
2. Don't let the pressure build up past 15 PSI, just in case it has any oxygen in it. It WILL go BOOM!
3. If you have any "air space" above the liquid, remember it has to displace or at the very least mix to a combustible level.
4. One of the test we do to determine (crudely) if O2 is in the mix is to fill a ballon with the gas....if it poooofs, (yes that's is a lot of o's), then it is H2. If it has a sharp bang, it is HHO, I will see if I can put a vid together Monday to demo if needed....The point is, a ballon might be the better way to test, by letting the system fill one up, then light it. If you are getting only O2, or higher concentrations of O2, then it will simply light with a "bright" burn and ignite any surrounding plastic etc, i.e. the ballon.
Once again, PLEASE be careful, and I am speaking from EXPERIENCE, wear ear protection as well as eye.... One day, when I want to review it again, I will release a vid (our internal cameras) of me pushing one of our systems to 20X past its limit...the blast threw me 8 feet in the air...Lost my hearing in my left ear....and when I woke up....you get the idea,...so please take care.
Safely,
Bob
P.S. Didn't mean to sound like I was lecturing,...just , we need your ideasLast edited by TheCell; 12-19-2013, 09:02 PM.
No fire ----No fun---one more day gone
Lidmotor
johnny,
great find, am keeping a close eye on this thread, even though my humble attempts at replication didnt quite make it( i did try the rodin coil with the slayer circuit btw, it seems the talents of the rodin coil lies in other areas)
keep it up
Hi Jonny and Lidmotor
wow!
It is good to know that we have all tried to fire this gas at the and of the needle without succes.
i tried with 10 X 4148 and got a lot of electrolisis but no flame out of the needle.
Yes Jonny perhaps a confine chamber is the key
Anyway bravo and thanks for sharing
good luck at all
LaurentAttached Files
@Lidmotor.Hi This experiment has given me great hope that we can burn the gas in a reliable way.I think the key to getting the hydrogen to burn is the combustion chamber so we need to think about burning the gas in a captive space and not as a jet out of a needle.The flame acts like an hho torch and makes quick work of anything burnable so it is going to take a bit of experimenting to get a reliable working prototype but what i also found interesting was from memory,i would say that the higher input voltage did not equate to higher gas production,looking back at my first vid on this so a few things to mull over.
The water was ordinary tap water and the syringe was new and unused so no contaminants.Cheers.Jonny
Great Find!!!
Originally posted by jonnydavro View PostHi folks Here is one of those lucky accident experiments which we have all experienced I started of this morning on a mission to increase plasma output using Slayers exciter without blowing transistors using my existing pop bottle coil though any one starting off should think about replicating Bob's coil as he has great plasma at low volts and current draw, anyway the small signal transistors can't take much stick even though the mpsa06 seems to give great results,it is easy to blow them so i decided on the 3055,sat in a cap of water for cooling and a Lidmotor style L2 and using a wall adapter which outputs 35v I got great plasma at 180mA.So that sorted i decided to try this setup on Dr Stifflers one diode electrolysis and decided on trying to get the gas to burn so i used a syringe that was left over from a printer ink cartridge refill pack and not used to feed my cat when ill like i say in the vid jeeez.I half filled the syringe and dropped two 4148 diodes inside,they fit through the exit hole and attached the steel needle.
I fired the Slayer exciter up and the current draw was 330mA at 35V and tried lighting the gas with a candle but had no luck so i sat down and had a brew and all off a sudden,smoke started coming out of the needle and i could see an orange flame inside the small chamber at the base of the needle.It self ignites and burns with an orange flame and after a short while it burnt through the plastic so a better combustion chamber is needed.I can only think the self ignition is due to the close proximity of the metal needle and it may arc to the water due to its close proximity and in the process ignite the gas which is looking like hydrogen or could it be a mix?
Here is a vid.Jonny
YouTube - Dr Stifflers one diode electrolysis.Self igniting flame using a Slayer exciter.
Well done Jonny.
This success should draw lots attention from everywhere.
Lidmotor
