Jonny's 2cm "Micro Slayer Exciter"---replicated
@Jonny, Slayer, and All
I replicated the 2 centimeter micro Slayer Exciter today. Winding that super fine wire was not all that bad and the build went well. Jonny It worked right away and would slightly light up an FL on 1.5 volts. When I tried 3 volts it really performed well and I made a video of it. Slayer I put that variable pf cap that you have been using between the output of the secondary and the negative rail and it worked great there. I don't know why that position worked so well but it did. At the output I attached my Dr. Stiffler SEC tower with the 27 Leds in series and it lit that up super bright. That setup made a strong excited field around the circuit. All that out of the tiny coil.
Thanks Jonny!
YouTube - Jonny's 2cm Micro Slayer Exciter.ASF
Lidmotor
Thanks Jonny!
Lidmotor
