  • totoalas
    SEC at 1 meter WOW
    Johnny great find on the coil
    Wrench attached video showed the painting on the wall with hidden coils
    I will try the rectangular coils of the microwave to see ???
    Can you show us the circuit ?????
    totoalas
  • Farrah Day
    Brilliant stuff as per usual Jonny!
  • jonnydavro
    @Juju
    Originally posted by juju View Post
    you should experiment with both rectangular (emiter and receiver) towers, to see the difference, what do you think?
    That is a great idea .I should be able to make an exact copy and lets see what happens.
    I also love plasma but not to keen on the smell and i will try the rectangular coil in the Bedini exciter and see if it behaves differently to the round coil regarding plasma output.Cheers.Jonny
  • juju
    yeah jonny
    i thin k you found some kind of "sacred geometry" of wireless electricity!
    now im focused in the plasma that you showed to us, all the people are talking about plasma, the 4 state of matter... if there is free energy, plasma is the secret!
    hugs
    EDIT: by the way, i love the smell of plasma!
    Originally posted by jonnydavro View Post
    @Juju.Hi
    Its funny though how the rectangular coil recieves energy and the round one dosen't don't you think?Cheers.jonny
    @Kazm.Hi I cannot see any change in the amp draw .Jonny
  • jonnydavro
    @Juju.Hii tried grounding one end and it killed the effect but i will try sitting it in an alu tray and see if there is an increase in recieved energy.
    Regarding the position of the wire's.The 26swg is a very bouncy wire and when you move the coil they bounce and move a lot and i saw a neon flash so it was just a question of moving the wire's around until the neon stayed lit and the "C" shaped shape in different plane's seemed to work best.
  • kazm
    @jonnydavro - is there a visible effect on the amp draw when the bulbs are lit at the receiver?
  • juju
    spectecular jonny!
    how did you remind to make that type of shapes at the end of the wires?
    very interesting...
    have your tryed to ground the down end of the receiver to see if you got best results?
    hugs
  • jonnydavro
    Hi I did an experiment tonight using a modified Slayer exciter which uses a rectangular L1 coil with the L2 coil wound on a ferrite torroid as i have already shown in a previous vid anyway the rectangular coil works very well as an exciter and what i like about having the L2 on a torroid is it allows you to experiment with some really crazy shaped coils that it would be hard to wind an L2 on,i'm thinking starship etc as i think the next big performance jump is going to be in the L1 coil so if you can imagine it and wind it,using the torroid you can easily try it.
    The experiment i did was in regards to energy transfer between two coils,the exciter coil and a receiver coil and i stumbled onto a configuration which will fire fluorescent tubes and neons from 1m away when normally the tubes fire at about 4" away from the exciter.
    If i move the reciever coil closer to the exciter,there is a plasma arc on both outputs of the rectangular L1 but what i find really interesting is for the rectangular coil to recieve energy,the output and input of the rect L1 have to be orientated a certain "C" shaped way.One wire in the vertical plane and the other,horizontal.If they are not orientated like i show in the vid,the coil can be right next to the exciter and it is dead.I don't understand this so any idea's here would be most welcome.Thanks.Jonny
    YouTube - Slayer exciter-Rectangular coil and wireless energy transmision
  • wrench76
    YouTube - The Gadget Show - Wireless Electricity
    just an interesting video I found. Also ,try the tip3055 it is working much better then the tip31 for me
  • juju
    my exiter
    Originally posted by woopy View Post
    By the Way Juju how about your your 50 cm coil any datas ? Because i intend to wound one , but as you said is it worth the big work? Thanks
    good night
    Laurent
    Hi Laurent...
    Using the TIP 31 C, my amp draw is 0.4A at 12V... as more as you go up in the tower with primary coil, more output, but more consumption... at the middle it draws 1A but high plasma all arround the primary and at the end of secondary!
    with the MPSA the consumption is 350mA ... But the field is nothing compared with the TIP 31 (5 times more power/distance).
    the output at the end of secondary (avplug) without load is 220V... i think my small tower was 300V... how much do you get with yours woopy? and what is the resistance of your coils?
    im using earth ground at the base, if i dont use it the consumption go up 20 or 30mA! i dont get any plasma with the MPSA!
    im using 4 turns at the primary of network cable (0.5mm) with 0.5ohm resistance,, the secondary is 140ohm resistance!
    thanks wrench, you get the same amp draw as i get but with more thicker wire but less resistance... interesting!
    hugs
  • SkyWatcher
    Hi Xeno, thanks for the reply to my thoughts. So your thinking it would have to be along the lines of what Armagdn03 is talking about or use a dual toroid design. I just have this feeling that if the size of the fine gauge secondary is properly matched to a given primary magnetic field strength and pulse frequency, that it may have similar effects to the perpetia mechanical model. As usual, only way to know is to build the sucker. Maybe I will give it a whirl.
    peace love light
    Tyson
  • Xenomorph
    Hi folks, i have an idea and was wondering if anyone thinks this might be able to function in some way like Thane Heins perpetia generator. I am aware of his dual toroid model, could with the right frequency and such, could the secondary thicker wire wrapped over the fine gauge secondary provide power without reflecting back so much to our main self oscillating bifilar coil as does his mechanical version. The fine gauge secondary is short circuited upon itself. Let me hear your thoughts. Here is a pic of two different designs, though i'm sure many other designs are possible.
    http://img815.imageshack.us/img815/1...neheinidea.png
    peace love light
    Tyson
    You need a closed magnetic path and a path of lower reluctance and i am sure that the 2nd toroidal core is vital for it, it wouldn´t work otherwise.
    The Tesla method to do what you propose would be simply to bring the secondary out of the near field of the primary tower.
  • SkyWatcher
    peace love light
    Tyson
  • wrench76
    @ juju, my L1 is only .1 ohm, 14g 1.628mm and L2 is 92 ohm 30g .245mm. L1 controls amp draw and plasma, less turns=higher amp draw,more plasma.more turns less amp draw less plasma. I have 3 turns now just to play around with the plasma, and lights are very bright, but amp draw is up around 500ma. The plasma is fun though.hope that helps
  • woopy
    thanks Totoalas
    good work with your many coil test, could you give us the inductance and resistance of the different coils you tested for info ?
    I tried the MPSA06 between ground and base of the parallel or multi 2N2222 and it works very nice big current drop
    But with my L2 at 3 turns i can not go above 10 volts and as i did not receive my transistors i am now very carefull with my last ones.
    OK today i tried to couple the straight Slayer with the conical.
    So i tried to connect the free L1 directly to one of the free conical end and it works
    Than i tried to instal an Avramenko plug at the end of the free L1 and connect the L2 of the Conical on both side of the AV plug ( leaving both free ends of the L1 conical free) and it works I can light the FL easily without touching anything.
    I dont know the electrical lost yet but what seems possible is to use the free L1 of the basis slayer coil to repower a second stage of slayer exciter
    Perhaps we can couple more ? What do you think ?
    good night
    Laurent
