@dR-Green.Hi
I re-read my previous post and can see that i am only adding to the confusion.Try this.Get a 2' lengh of 0.6mm maplins bell wire and fold it in half so you have two wires.Wrap these two wires 5 times around your cfl toroid.Cut the wire at the fold and connect one of the cut ends to one of the starting wires so it is end of coil to start of coil.This will be your Battery + connection.
I just did this with another cfl torroid and it worked so hopefully yours will too.
Here is a good joulethief tutorial which may make thing clearer.
The Joule Thief!
I think the output voltages of the simple sec and joulethief exciter circuits would be comparable.
I have had a circuit for a trigger coil led driver sitting on a breadboard for months now and you may find it useful.Here is a circuit diagram and vid.It will run down to 0.3v and you can use high input voltages on it too so quite versitile and a good joulethief alternative for a torch.Happy experimenting.Jonny
‪Led driver‬‏ - YouTube
The Joule Thief!
