  • Just did a bit of quick research on this after I realised I didn't really have a clue what I was talking about.
    It seems that Jonny has corona discharge... sorry, I made that sound like a medical condition... I meant that Jonny's cct exhibits corona discharge, which is something quite different from the arc jumping from my ignition coil to ground.
    It seems that this phenomenom occurs when, well here's a piece from Wikipedia which sums it up nicely:
    In electricity, a corona discharge is an electrical discharge brought on by the ionization of a fluid surrounding a conductor, which occurs when the potential gradient (the strength of the electric field) exceeds a certain value, but conditions are insufficient to cause complete electrical breakdown or arcing.
    This maybe just what I need to induce ionisation of the water in my WFC... cct build time!
    Farrah
    • slayer 007 avramenko electrolisis
      Hi all
      I tried this setup with my new pancake L2 (10 turns of plain plastic insulated copper) On the Slayer 007 exciter.
      It works well, and as you can see the electrolisis is much stronger on one carbon rod than the other. Why ?
      And somebody can say what get out , is it pure H or HHO or only O ?
      Than the problem is that the 2N2222 A get very hot . Perhaps some idea to improve that problem ? I have already fried a bunch of them.
      Thanks and good luck at all
      Laurent
      • Hi Woopy
        The obvious explanation is that you get twice as much hydrogen evolving at the cathode than you do oxygen at the anode:
        2H2O = 2H2 +O2
        But I've seen some odd things when it comes to these circuits so it might not be the whole story.
        Have you tried using a MOSFET, or using the 2N2222 to trigger a power transistor, or does this destroy the operation of the cct?
        Farrah
        • Slayer Sec @12 V Warm Circuit
          Slayer,
          I just want to report on the replication
          12 Inches tall 3 inches dia power 13 v dc from ac dc supply
          L1 26 awg L2 9T 21 AWG
          Variable capacitor set at 0.69nF range (2 nF)
          with MPSA06 and 2N2222
          160 mA transistors are hot with plasma arc on L1 which easily burn my skin
          can be tested in air with ac voltage tester / screw driver
          After 20 minutes transistors fried
          at 200 mA can be used as wart remover
          With two 2N2222 the circuit is warm after 2 hours @ 160 mA
          With 20W lamp tied with a rubber to L1 coil ( no flicker)
          Ac voltage tester cab detect L1 output in air
          Run the circuit at ,098 A for the 20W lamp Great results
          Will start to test on the led.s with reflectors
          Thanks again Slayer
          • Originally posted by woopy View Post
            You can cool the 2N2222 with a standard computer fan pointing at it or maybe soldering a piece of metal with a comparatively big surface area to it.
            I managed to prevent them from frying by putting a 20-30 Ohm resistor in series with the positive of the supply (AC adaptor). That will limit the current to about 100 mA. If that´s a too low current for what you are doing, you can only cool it.
            EDIT: Just had the idea that you might get around the problem of frying them if you parallel a bunch of 2N2222s like 3 or 4 of them. That´s the way it´s being done in inverters to distribute the current over all of them to prevent an individual one from frying.
            • Xenomorph
              I will try your advise on the 2n2222 to make 4 o5 in parallel ..also add a 30 ohm resistor
              After I finalize the circuit , seal it with black epoxy will the temperature affect the sealed circuit???
              thanks
              totoalas
              • Woopy
                It seems to me that you need some sort of variable component in the cct, so that you can tune it better.
                The obvious problem as the cct stands is that L2 is too low a resistance and needs to be upped by either adding more turns or reducing the wire gauge - or both.
                However, I would have thought that Slayer and JD will instantly be able to tell you how to rectify this problem by some form of tuning, whereby the reactance of L2 can be made to restrict the current flow drawn through it regardless of its dc resistance.
                I'm sure one of them will be along before too long.
                Incidentally, the electrolysis effect you are seeing is the exact same effect I'm attempting to achieve on a somewhat larger scale with my Closed-Loop Electrolyser. Energy from your one transmission wire is causing the water to ionise, and the Avramemko plug on the end is acting as a charge exchange bridge. So you will have a small current flowing from the water and through the diode cct - a closed-loop!
                Farrah
                • @Farrah Day.Hi. That was very interesting info about the corrona discharge.I had a look at wiki and the fact that you can get both positive and negative corrona is interesting as it may be possible to configure the circuit so you can create both as they have different properties and maybe different uses.How would you tell what type is being produced?Any idea's?
                  It is great that you think the Bedini exciter may be of use to you in your experiments as these variant circuits have only seen the light of day due to the free sharing of ideas here and long may that continue.
                  If you want to replicate,it is probably best to mirror my setup first and then try different things.This is how i would go about it.
                  1.First of you need well matched L1 and L2 coils.The easiest way to ensure this is to build a Slayer exciter and obtain maximum output by tuning the L2 to the L1.Mine is not yet optimised as Slayer has found the pancake coil config best for L2 but it is simple enough to make both types,Pancake and a loose wrapped coil.The pancake type is on my to do list regarding performance optimisation.
                  My L1 is made using 26swg enamell mag wire,wrapped anti-clockwise onto a plastic pop bottle starting at the top end.The use of plastic as a former may play some part as plastic can store a high charge and there is a static crackle when i touch the windings on the bottle with my hand.Start the L1 wind from the start of the flat surface of the bottle to the end.Mine measures 205mm.The L2 is 8 turns of 18swg mag wire.
                  2 Use the circuit diagram posted here and in my vids.The first vid i made i had the L1 coil open circuit and in the 2nd vid,i tied one end to the positive rail as this increased plasma output.
                  EDIT- 3 The Bedini coil is wound with a 1:1 ratio with two,250 gram rolls of 26swg mag wire.This induces a high voltage in the trigger side of the circuit and is this is needed to create corrona discharge.
                  4 The four most important things are the coil,mpsa06 transistor(Mine are Fairchild), relay coil in the trigger circuit and the earth ground to the 100 ohm resistor on the base.It won't create plasma without the 1:1 coil,relay and earth or V ground present although the exciter circuit and motor will run.The earth ground can be replaced by an aluminium baking tray as a virtual ground but output is stronger with an earth ground and the alu tray or kitchen sink is excited as a bonus.
                  I have quite a variety of relay coils and each one produces a different frequency and type of plasma so dig all your relays out and try them all.My favourite one at the moment is a 6v relay coil and i am getting some interesting effects with this in regards to plasma and how the Bedini motor operates.
                  Also try running it of a variable wall adapter as it starts producing plasma on the 6v setting and spews it out on 12v or you can use a 12v battery.
                  This is also a motor so maybe you could use some pickup coils to supplement something?
                  My next step with this is to wind a bigger L1 coil and pancake L2 and see what happens.
                  Keep in touch as you go and you should have what i have in no time and then we just have to make it better.Good Luck.jonny
                  @Xenomorph.Hi Nice battery charging experiments.It always amazes me the amount of batteries that are thrown away at the local tip probably due to sulphation so this is a great find and like you say,when you think about it,Slayers circuit is always at resonance so tailor made for this application.It would be interesting to compare Bedini charger to Slayers exciter on an equal input basis.Nice work.Jonny
                  @totoalas.Hi Heat is a problem but it is one we are going to have to solve as i think the mpsa06 is good for about 200mA and the 2n2222 can vary depending on the manufacturer but most fry around 200mA so we are running them at their limit now, so we need to ideally find a power transistor which behaves like the mpsa06 or like Xeno say's,spread the load or use heat sinks,on the mpsa06 you can rest a copper penny against the flat face and that is quite effective but not with the metal case 2222.I am pretty sure Dr Stiffler uses a copper pipe heat sink in some vids so he also has heat.
                  One other thing you could try is the "Tranny mod" put another transistor with the collector of the new transistor to the base of the existing one and the base of the new transistor to the emitter of existing one and leave the emitter of the new transistor floating.This is not the same as putting a diode here and this more than halfed my amp draw using mpsa06 but not sure if it will work with 2n2222,worth a try though.
                  Strangly,i find i blow most transistors when switching the circuit off.Anyone else find this?
                  Dr Stiffer has said that the magic happens with the mpsa06 transistor's and i must admit that performance wise,mpsa06 are hard to beat but there has to be an alternative that will allow us to experiment with higher voltages and current.We just have to find it.Thanks for posting .Jonny
                  @Woopy Hi.Thanks for sharing your experiments with us.One wire electrolysis is a pretty new area of research i think so you may have some exotic gas mixes.Have you done the old glowing splint test?
                  I must admit i am quite fascinated by electrolysis and i hope to try a few things out,namly the production of a flame.Dr Stiffler i think has done this and i also read somewhere on this Forum about somebody adding 1 drop of pure alcohol to water and this allowed a constant flame to be produced and i think it lasted till the water was gone so that sounds like there is something unusual going on.Thanks for sharing.jonny
                  • Thanks for the info JD, based on your (and others) experiments I hope to be putting a few JT variant ccts together over the weekend.
                    I'm sure getting some real insights into things around here. There's just so much to be inspired by - though I've got so much catching up to do in order to get up to speed!
                    Yep, I would think that it comes down to whether or not your antenna is of -ve or +ve potential compared to the surrounding air. If it's negative then the air will be negatively ionised by taking electrons from the antenna, (wire, or coil), while if it's at a positive potential, gases in the surrounding air will be trying to give up electrons and so positively ionise.
                    If one part of a JT cct has a potential difference of 1000V, compared to another part, it may not necessarily mean that the potentials are at +1000V and 0V. It may be that one part of the cct is at +500V, while another part is at -500V. In both scenarios there is a pd of 1000V.
                    Brilliant stuff JD.
                    Farrah
                    • avramenko electrolisis
                      Thanks to all for the response and proposal.
                      Will have a hard weekend to try a lot of things.
                      I just received some MPSA06 , and they work well.
                      I go now to buy some electrolite to improve the electrolisis
                      will report later
                      Good luck
                      Laurent
                      • Originally posted by Farrah Day View Post
                        If one part of a JT cct has a potential difference of 1000V, compared to another part, it may not necessarily mean that the potentials are at +1000V and 0V. It may be that one part of the cct is at +500V, while another part is at -500V. In both scenarios there is a pd of 1000v.
                        @Farrah Day.Thanks for this info,it helps a lotThe science behind some of the things going on with these exciters is fascinating and lets hope there are a lot more discoveries to come.
                        Regarding electrolysis,here are a series of vids by Dr Stiffler which you and woopy may find interesting.It is quite amazing what the Dr's sec exciter can do and there is a good chance that Slayers exciter will do this too..Not too sure what a coherence converter is though.
                        Electrolysis is the least explored aspect with the variant exciters so plenty to get your teeth into.
                        YouTube - Can Water be Burned
                        YouTube - Can Water be Burned #2
                        YouTube - Can Water be Burned #3
                        Also Farrah,I added an edit to my previous post regarding coil specs which is important.Happy experimenting.Jonny.
                        • @ Woopy
                          Thanks for posting your results.
                          You may want to try running your setup with just the MPSA06 transistors.With 12v or more the 2N2222 are still easy to burn out.
                          Also a Variable capacitor will help with the current intake and tuning along with tuning the L2 coil to the right spot.
                          I was only showing the 2N2222 transistor in the circuit because people using smaller coils might have a hard time running this without the 2N2222 transistor.
                          But the best trasistor for this is the MPSA06 transistor.And if your using larger coils like mine you should just use one or two MPSA06 transistors.
                          @ Totoalas
                          Thank you for posting your results.
                          You may want to try a larger Variable capacitor to help with tuning and your current intake.
                          @ Xenmorph
                          Great video, Thank you for posting it.
                          • Good morning everyone,
                            Does this is a Slayer's exciter ??
                            It looks same, but power is huge
                            http://www.hvlabs.hu/zpe/Gruz/overun...320 x 240).flv
                            Comes from here: Index of /zpe/Gruz
                            • Originally posted by Jules Tresor View Post
                              That video is an admitted fake. Stefan should actually take it down from youtube.
                              Too many people take it for real. And it has really nothing in common with Slayer´s Exciter (except that two coils are being used if you wanna find a similarity).
                              • Hi all
                                Thanks to all of you for the important info and very intersting videos.
                                Just a little report of today's work.
                                I tried different water. plain tap water than salted water than baking soda water and pure distilled water.
                                the best result is plain tap water. with the baking soda both electrode are producing gas ? With distilled water it seems to need far more current for less electrolisis. Salted water get yellow and smell not so good.
                                Than i tried the MPSA 06 which work well and also the 2N3904 which is very good too.
                                The frequency around the glass is between 550 up to 670 khz (measured with the green loop on the probe of my scope)
                                Than something very INTERESTING i made a coil of some turns (0.8 copper insulated see pix) around the glas , one end of the coil is connected to a long wire and than to the house ground, the other end is free.This have a dramatic improvement on the current consumption.
                                For instance if the voltage is 9 volt and the current with the coil at the upper water level,is at 10 ma , if i simply let the coil fall at the bottom of the glass, the current goes to near 60 ma and if i put the coil away from the glass , the current goes to 120 ma ?? any explanation ?
                                Than i got problem with the carbon electrode. Some time ,not always , the non producing rod get black and than the whole electrolisis strongly diminish ?
                                OK that all for today Ho! i forget to mention that this experience is a real transistor frying machine
                                Good luck at all
                                Laurent
