  • Johnny,
    great work
    have you ever experimented to try and power any other kinds of loads..specifically resistive/small motor etc? using all the various ways & means that youve demonstrated with the neons & flourescents.
    Thanks.
    • Hi johnny and all
      Thank you very much for your circuit. It works great.
      As i am now working on Kapagen, and as a lot of replicators i am scotched probably due to resonance problem. So i tried to make a mini kapagen with your circuit.
      And by doing this i made a small discovery , And i wonder if you have already seen this effect.
      So i built your circuit with a MPSA 05 a resistor in serie with a potentiometer.
      the exciter is a small coil with 5.3 ohm and the outer wire of the coil goes to the ground (a steel bar1 meter deep in the garden, it works also with the house ground).
      the receiver is exactly the same coil (5.3 ohm). With the 2 wires simply directly connected to a white led. I have noticed that the coil resistance and probably inductance must be the same as the exiter.
      so as you see on the pix 1, the receiver is at about 10 cm from the exiter
      and the led is dimly lit and the current is at 20.3 ma. Than i approach the receiver to the exiter, and the led become very bright, but the current goes down to 20.3 ma (see pix 2).
      The voltage is at 14.5 volts
      I have tried it also with 2 receivers, one each side of the exiter and the effect is also present, when i approach the first receiver the current goes down and when i approach the second receiver the current goes further down.
      I have tried with different coil resistance between exiter and receiver but same dimension. And it did not work
      seems to be an interesting effect
      What do you think ?
      Good luck at all
      Laurent
      • Hi all
        just to complete my previous post
        i redo my test and i took 4 identical coils all have 5,3 ohm and 3.9 mh. same wire and same dimension
        same lenght wire to same led quality.
        one of those 4 coil is used as the exiter and of course one wire is connected to the Jonny's circuit, and the other wire to the ground as mentionned in previous post.
        So, in pix 1 you see the exiter in the midle and the 3 receivers all around.
        the distance is enough so that no receiver work at all, at this moment the current is 20.8 ma.
        than i approach the 3 receivers until they light a bit. At this stade (pix 2 ) they lit dimly but the current is always at 20.8 ma. ( no load curent surcharge )
        than i organised all the 3 receivers so close as possible from the exiter, and as you can see in pix 3, the led are very bright and the current goes down to 20.0 ma.
        Than i disconnected the ground and the current surged at 260 ma .
        than i reconnected the ground and back to 20.0 ma
        is this coupling interesting, or i am puzzling in something normal ?
        thanks
        Laurent
          Originally posted by totoalas View Post
          Output of L1 connected in series to HV wire of microwave radiator( from microwave oven)
          hello, what is a microwave radiator?
          thanks
          Laurent
          hi laurent, dont know if it is something new, but you really are showing interesting results!
          i made a video of my kapagen replica, please visit the kapanadze thread!
          hugs
          • @totoalas
            howto increase voltage of secndary 35T toroid to L1 to increase range of rectangular coil
            either install a cap and diode cross 10T or 35T???????
            or another 10 T in toroid ith cap across collector and emitter????
            Hi totoalasThe easiest thing to try is just change the turns ratio on the torroid by adding or subtracting turns from each coil a bit like tuning a joulethief .I had a quick try and 7 turns and 28 turns seemed to work quite good on a 37mm torroid and after you have maximised the voltage by tuning the torroid,you can try adding some of slayers cap mods but the best way to maximise output is in the reciever as if the reciever is in resonance with the transmitter then more energy is transferred.
            Also you need to have a way to see if any changes you make increase the output.Dr Stiffler made a vid of a field strengh meter which may be useful for this.
            p.s Great experiments you are doing.Any chance of some more pics as i am a bit curious about your microwave radiator too Jonny.
            @rave154 Hi .I have powered a dc motor using a circuit kazm posted a while back which lit a bulb but this was not wireless but i think i may try and run the dc motor wirelessly of my rectangle coil as the energy transfer seems quite good but i think these circuits work best with leds and fluorecents.Cheers.Jonny.
            @Woopy.Hi Laurent.Very interesting experiments and results.Thanks for sharing them
            In my own experiments,i have seen the current draw go down when the exciter is loaded by for eg a florecent tube but you have a different setup as i am usually holding something and so become part of the circuit and yours is more "hard wired" and small so i would explore it further,maybe adding leds and also see what happens to the current draw when using an av plug led detector and is the effect still there when using a larger L1.The earth ground current reduction is interesting also.Happy experimenting.Jonny
            @All. Just a quick update on my rectangle coil experiments.I have managed to light a neon bulb at 1.730m and over 2m using a 2nd rectangle coil as a repeater and and led at 3m.I have found that you can tune the coils with a ferrite rod and also they work a lot better if sitting on a metal mass like a filing cabinet.Cheers.Jonny
            • Sec Toroid Microwave Output
              Uploaded with ImageShack.us
              step up transformer 220 to 2kv with caP output to microwave radiator
              if i can increase voltge input to L1 coil the output will definitely increase the microwve radiation and hopefully wireles trnsmision......
              thanks Jonny for the response i ill try your toroid turns and separate the microave from L1 coil and will see next result????????
              Juju this unit I removedfrom the microwave oven pls see pix ty
              totoalas
              • hmm
                cool, i have one of those you are showing on my microwave... i have allready take out a small motor, the cap and the transformer...
                but i have not seen any use for that radiator, and i am not understanding clearly what you are doing, can you draw a easy diagram?
                you are actually feeding the 220->2kv transformer, with 12V? and your transistors can handle that voltage output?
                sory for the silly questions, but i have no idea of what you are really doing!
                anyway, keep it up!
                hug totoalas
                ps: if you can, please post pictures with less resolution in the future, so it dont mess up with the size of the thread!
                • rSEC TOROID OUTPUT
                  Juju
                  sorry for the confusion that description 220 / 2kv xfmr to microwave radiator
                  is for the microwave oven circuit .........but will try this in place of toroid
                  I used the the Jonny SEC toroid recently posted and just used the L1 output
                  to connect to the HV side of the microwave radiator with the other end open
                  Instead of another coil the microwave radiator acts the same way but with stronger field
                  will try to install cap/4148 diode across the microwave radiator as a RECEIVER as Jonny suggested and use a. toroid 7/28 turns b.oven transformer in place of toroid
                  Update
                  w/ L2 pancake and toroid current draw 180 ma
                  with toroid alone 70 ma
                  load 3 8 watts on L1
                  1 20W fl on the microwave radiator
                  connection of microwave radiator -- output of L1 to avrenko plug on 400uf cap parallel to the coil of the radiator
                  transistor MPSA06 EBC nd the other MPSA06 C TO B and B TO E 12v dc supply
                  cooling the trnsistor with THE COPPER OF TERMINaL BLOCK for 10 amp the temp drop from 30 to 26
                  cheers
                  totoalas
                  • Hi guys
                    i made a wonderfull video of my tower...
                    im playing with CFL'S, neon, led, and plasma discharge!
                    my earth battery was arround, and it becomes exited with the wireless presence and stays steady, if i touch the ground connection to the base blinks more fast that with the tower off.
                    Enjoy!
                    YouTube - TESLA WIRELESS - JJ
                    "Im playing the game, the one that'll take me to my end...
                    im waiting for the rain, to wash who i am!"
                    • HiRave154 wondered if Dr Stifflers one gas "electrolysis" experiment could be replicated using Slayers exciter and it can and works really well.
                      Here is a vid showing similar results to Dr stifflers and Lidmotors and also gas evoution at a distance.
                      YouTube - Dr Stiffler's gas produced with a Slayer exciter
                      @Juju.Wow:Great vid That is a great setup you have and the transistor change has worked out good judging by the plasma output and i love that little spark gap,amazing.Cheers for the vid.Jonny.
                      • Wow cool Jonny!
                        • Seclightplus Gas Wow
                          Juju
                          Very strong output at500 ma nice show
                          Jonny
                          great HHO i will try with lye or baking soda
                          Other application wart removal already fried some on my leg he he he
                          totoalas
                          • Johnny,
                            thanks for doing that with the wireless "Electrolysis"
                            i guess 1 question would be, would the gas production increase if the surface area ( or even total mass ) of the anode was increased?
                            also..increasing the size of the cathode such that the outside diameter of the cathode puts it closer to the inside edge of the glass tube such that there is only a thin layer of water between the two... and see if this increases or decreases the gas.
                            between these two you might be able to figure out more about whats going on.
                            p.s an idea just occured ot me as well, how about adding parts onto both the anode and cathode to make it into the form of those "Stan Meyer" cells where concentric rings of alternating cathode - anode - cathode - anode... are formed?
                            Thanks again.
                            • Yes jonny
                              very nice video
                              i did not understand which circuit you use for this experiment. And if i understood right you use distilled water. What is the magnet under the test tube for ?
                              Sorry but english is not my mother tongue and i have some difficulties to follow you when you speak in your video.
                              But the result is very good and i can't wait to replicate.
                              bravo
                              Laurent
                              • Hi JD, great video as per usual.
                                It's quite all right to call it electrolysis, because that's what it is. The term 'Electrolysis' does not just apply to the breaking down of the water molecule, it can be used to describe the chemical reaction at the electrodes due to the passage of current though any liquid ionic medium.
                                A diode is in effect two electrodes - a one-way valve. A charge exchange medium.
                                Did you read my take on this over on the Doc's thread. I don't think he was too impressed, but I'm fairly confident that I'm not far off the mark. I'm much more in my comfort zone with this.
                                You, Woopy and Slayer also make it quite evident that you don't specifically need a SEC to do this.
                                The reactive tin coating on the diode leads is somewhat misleading as we will be getting tin oxide (SnO) and hydrogen - no oxygen. Also somewhat misleading is what is happening on the diode leads.
                                To evolve as gas, the H+ ion needs to pick up an electron, but electrons only flow through a diode in the direction from the cathode to the anode, so the electrons will be taken up from the anode. Hence the H2 evolving from the anode, not as some people might expect, the cathode. Remember that the diode markings indicate conventional current flow, which is positive to negative – opposite to electron flow.
                                So the hydrogen is being evolved, while the oxygen is going into making up tin oxide which is dropping off the cathode.
                                While I find this all immensely interesting, I don’t find it to be as enigmatic as other people seem to do, simply because I’ve long believed that water could be ionised by a pulsing electric field. So to me, this is all simply confirming what I’ve long thought to be the case.
                                Nevertheless, it’s extremely exciting times.
