I just moved to Cyprus from the UK and finding components out here is like finding gold on the pavement. I asked for a selection of NPN's and thats what they gave me. I looked up the specs and like you say its a very high voltage and pretty low hfe but it seems to work very nicely. I was wondering if anyone knows a way to boost the dc current gain without another transistor. A capacitor on the base maybe?
Hi Zooty
This looks interesting and I'd like to give it a try. Is there a reason you used the BU508AW? I have seen these in TV's Ive scavenged parts from in the horizontal deflection circuits and they have a very high voltage rating to them. I was wondering had you tried other NPN's and found this one worked best?
Big Bedini/JT with Tesla Switch Style Recovery
This is a Bedini type coil wired like a Joule Thief except the recovery diode goes back to the positive of the charging battery. The Charging battery is also in series with the coils so you need a higher voltage than the charging battery for this to work. The source is 24v and it draws 125ma. The Charging battery charges very quickly and nothing in the circuit gets hot. I am still conducting load tests but i can already tell the battery is doing very well.
Originally posted by xee2 View Post@ Seth
That is really good performance. Thanks for posting the video.
PS These results were all obtained with a TIP 31C (i hadnt discovered the joy of the mosfet at this point) on about a 350 Ohm resistorLast edited by seth; 10-31-2010, 06:04 AM.
Originally posted by xee2 View PostLager coils seem to work better. My first experiments were with a 1" diameter coil. It would not light the fluorescent tube wirelessly without using a cell phone charger. If I make another coil it will be 5" diameter.
YouTube - 1.5V wireless exciter.flv
Low input @ high output is always a delight to see!
Originally posted by totoalas View Posthave you tried on a smaller scale of coils
to limit the cost of building one ???????
Single Wire Transmission Test Slayer Exciter
I thought I would test the new setup and see how far I can transmit energy by single wire.
YouTube - Single Wire Pancake
Originally posted by xee2 View PostThis is not much of an improvement, but it does help some. I changed the 1K resistor to 200 ohms and the L2 coil diameter from 4.5" to 5" and moved it to about 2.5" from the end of L1 instead of 1". This gives a small improvement in the distance from the L1 coil that the 4 watt tube will light when using a single 1.5 volt AA battery without a cell phone charger.
YouTube - 1 5V battery no cell phone charger
No cellphone charger WOW thats my dream
less parts ... have you tried on a smaller scale of coils
Will try with a 20 mmdia by 200 mm height paper tube from a toilet roll
This is a great enhancement
cheers
totoalasLast edited by totoalas; 10-30-2010, 05:03 PM.
small circuit improvement
Wire measurement formulae
Alright for all of you folks who have good hands and an electronic measuring scale, aslo a good side for maths. I have conjured up a formulae to measure how much wire you need, so basically what you do is you measure the weight of the wire you have. Get the tube you want to wind it to and take simple measuerments (it has to be a circular shape) diameter, height and radius (just half the diameter). Also look up the data sheet of the wire you had bought.
Follow the formulae, the key thing is at the top.
diameter (tube) dt 5 gpm= grammes per meter
height (tube) ht 20 g = grammes
diameter (wire) dw 0.3 lwn= legnth wire needed
legnth (wire) lw
lwn=(ht/2dw)(2dt pi)= 105.
33.333 X 31.41=104.719
grammes > wire length (lw) gpm/g= legnth (meters)
500g > 250m 2gpm/500g= 250m
Everything is measured in meters and centimeters. Feel free to comment on my maths (I'm only 13!)
Cheers, WETissues.
Thanks Jonny,
I got to the point where I felt I was not growing and that spewing electricity in the air was not what Tesla intended for his invention. Working with everyone here feels good and you never know what could come from it. Thank you.
The top loads are chrome metal and they cost $6.79 ea from Save-on-crafts.com I looked around and that's a great price.Last edited by Jiffycoil; 10-30-2010, 03:20 PM.
