I know alot of people here have been playing around with "Exciters" for quite some time, and tons of variations have come about.
Has anybody successfully designed an exciter which has 90 degree phased outputs? one is High while the other is off, and vice versa?
SEC Field of Dreams Now Showing
Jiffy
Getting more intense and suspense hehehehehe
Your coil specs and circuit please I ll try them too
Your Flicker Pics are great the one thing I admire and learn from you
your Quote"EVERYTHING HAS ITS PLACE"
No compliments can describe your modest work
totoalas
This is the high voltage setup 24volts. Thanks for the compliments. I learn so much from you all.
Originally posted by Jiffycoil View PostI ran one of the new coils tonight.
YouTube - Getting ready for more experiments with the Slayer Exciter
TIP31, TIP31A, TIP31C. The video was made using a TIP31. Im curious as to what is going to happen when I run 3 and 4 coils at the same time.
Nice one Xee2.. Looks like your getting very good performance of the AA battery.
@Jiffycoil.
WOW.. The field around your exciter is amazing.
What are you using for a transistor?
Sorry if this has lready been discussed, but is this guy lighting an LED on an AV plug with NO EXCITER but just a ground connection???Last minute of video:
YouTube - Light circuit - Big light from small battery
I am truly shocked...its only a little light, but with just an AV plug and a ground rod.....Well, it certainly needs to be confirmed - i'll try after ive been to a birthday party.
Is this just stealing energy from the mains, or telluric currents, or something else?
Hi Citfta,
They read right on the transistor just a different run date and maybe run location. The good and the bad are all manufactured by ST. The good thing is the TIP31C works fine, so that's a good thing.
Originally posted by Jiffycoil View PostHas anyone ever run into variables with same spec components?
Wrong part number
Hi Jiffycoil, I have run into that problem before and found that somehow the wrong part number got put on the part. I suspect you didn't get the right part. I have even had resistors with the wrong color code on them. I would contact Mouser and see if anyone else is having a problem. It is also possible the manufacturer had a bad run of parts and did not catch them in the quality control tests. Hope this helps.
Carroll
What? the ha ho!
Im building the exciter boards for the 3 coil experiment and I have run into something strange , bad, but worked out. The TIP31A's that I just got in from Mouser are blowing seconds after powering up at 24V. I can put the original one Ive been using on the setup and it works fine. ST the manufacturer must have changed something. They spec out the same but something is clearly different. My solution is to use the TIP31C, it works fine. Has anyone ever run into variables with same spec components? I'm taken aback by this, I blew through 8 TIP31A's.
@Xee2
Wow, thats a nice setup there. I think you guys are on the right track with low in high out.
4 watt tube without cell phone charger
This video shows circuit working without a cell phone charger using only one 1.5 volts AA battery.
YouTube - 1 5V AA and 4W tube
