One magnet Bedini exciter
@Lidmotor and all.Here is a circuit diagram and vid of my One magnet bedini exciter.This is just a prototype and there's still plenty of work to do on it but as it stands,the rotor spins like crazy and there is quite a good sec output.There is a smell of ozone and the open circuit L1 hisses and you can see a purple glow and it will light flourecents and Lidmotors flicker flame bulb which are a lot harder to light than the small neons.
I am not using a charge battery at the moment and i will have to experiment to see if it will charge one or hinder the circuit.
This circuit may run on a standard Bedini coil but i don't have one to test it with.I wind all my Bedini coils with a 1:1 ratio to induce high voltage into the trigger circuit when the power coil energises.This may be important for this circuit or it may not.What is important though is to use a relay coil in the
trigger circuit and an earth ground on the base of the transistor,it will not work without both.The earth ground can go before the 100 ohm resistor or direct to the base.I have tried a virtual ground and that works too but needs to be close to the slayer L1 as it behaves like the simple sec with the triggering through the air but if you can,use earth ground.
I use slayers large L1 and L2 in the sec part of the circuit.The Slayer L2 is in series with the power coil and the slayer L1 is left open circuit.I have not experimented much with this yet so this may not be the optimum layout but it is a good point to start.Here the vid and circuit.Jonny
![](http://img203.imageshack.us/img203/1218/bediniexciter.th.jpg)
YouTube - One magnet Bedini exciter
![Thumbs Up Smiley](http://www.energeticforum.com/core/images/smilies/thumbsup.gif)
