hello laurent, so glad you like it dear friend!
i have not made the experience with regular primary, i know that you allready tryed arround 20V in your exiter plasma spinner setup... just get thick plate of copper, solder it to bottom pin of a 15W fridge bulb, and then you must touch the outside shell of the bulb with your fingers, and put the plate close to the tower, just like i show in the video!
but try it with your regular exiter primary!
if you dont have sucess then wind 4 turns of 3mm thick wire, in half bottom of the tower!
put a resistor between positive and base (1k to 3k), and put another one from negative to base (100 to 200ohm), also try your diode from emiter to base!
please share your setup in the "Brovin/Ketcher Generator" thread... because altough this is very similar to sec/slayer exiter... this particular setup have some differences from the device we are talking in this thread!
hugs
hugs
Originally posted by woopy
