Originally posted by Slider2732
Originally posted by Slider2732 View PostIncredible run voltage there.
I noted you said about availability of such an old NPN. One place has them, 30 of them in fact, at $5 each.
2N4077 NPN Bipolar Power Transistor: In Stock Buy Now | West Florida Components
Originally posted by boguslaw View PostI tend to wind coils always when looking at film on computer, though it has to be not much interesting or winding is taking hours.
1.5 lbs mass 750 feet, 22 ga copper = 1875 winds.
Now to mirror that on the other half........
MORE COFFEE........
Jim
The secret is a coil with a feedback winding with many times more turns than the primary. See my blog.
Using a solar cell indoors, under a CFL is a good way to tune toroids. If you know you only have 1V and 2mA, then if it runs it can only be using that. We know digital meters can confuse the heck out of themselves when HV is present, so knowing full well the capabilities of the power source removes any meter errors.
@Jim, that's crazy, sounds like a mad idea...a great mad idea.
@Jake. Have enjoyed your crystal radio foray and then into the Tesla tower work. Have you tried one of Lidmotor's 'Penny' oscillators ? ( PENNY's circuit diagram.ASF - YouTube )
I have one on my backyard fence based radiant collector system, that runs from 0.4V and <1uA ( Radiant Energy Collector - Low Height - YouTube )
They'll fire up by human energy, no battery at all - piece of copper on the positive, piece of steel on the negative and hold both in your hand...the LED will begin to flash.
Have just completed a 1000 turn 30 gauge tower, wound on a 3" PVC pipe, 12 1/2" tall. I was impressed with Seth's use of the printer wall adapter, so have used a 30V 500mA adapter. Getting an LED to light 6ft away, with no human capacitance
To do that needed the old pop bottle 22 gauge tower that JonnyDavro showed about a year back and a Pentium III heatsink. AV plug to the LED, AV plug input is from the pop bottle, one leg of actual LED is then connected to the metal mass.
But, no flouro at that range yet. Transistor is an A1941 PNP, 2K Base resistor.
Primary is inside the tower - 5 turns pancake. With the Primary being of about 18 gauge copper the input wire bends and stays in shape to make the pancake sit slightly raised inside the tower. Looks like NCC-1701 lol
Pics/vid soon, if it goes anywhere.Last edited by Slider2732; 04-11-2012, 05:30 PM.
Slider and All:
I have gotten my home made power cells to produce about 60 mA, and up to a volt or so, from each cell. And, I would like to have a Dr. Stiffler type oscillator going, off of these cells, as the main base coil circuit from which other satellite circuits with leds can feed from. Do you think that the 60mAs output can get me in the ball park, or not? I can also place more cells in series, to obtain lets say up to 12 volts or higher, but with the same 60 mA output, as my cells don't add up very well in parallel? Any ideas?...
I just saw this video, about the 13 crystal sculls, and it blew me away.
I thought that you guys might like to watch it too:
Bashar the 13 Crystal Skulls - YouTube
@NickZ
60 mA is plenty for low light, yes. You can run LEDs with a conventional SEC-15x or SEC-18x, or you can play with the coil size dimensions and run CFL's even from that, as jonnydavro showed, and I also did. I even got plasma and decent light at 12.XV / 20-50 mA here. Just as a resonant circuit, even despite not having "nailed" any coherence, it is still quite economical and useful.Last edited by kcarring; 04-12-2012, 12:36 AM.----------------------------------------------------
Cell Rejuvenation with a Slayer Exciter
This is for Nick and others who have dead salts cells from all the months of making these.
You might remember a vid, where I rejuvenated a salts cell with water, back in February. That cell finally died off again the other day and so I tried water again. The thing fired up for a few minutes and then died off again. Ah well, another for the heap eh ?
Well....I thought i'd try something...HV straight into the cell and with the hope that it may be a way to either realign crystals or blast cobwebs like ya do with a NiCad.
I put the cell on the top of my 1000 turn 30 gauge tower, placed the tip of the output wire very close to the positive copper of the cell and switched on.
The plasma launched out and frazzled the heck out of the cell for about 3 minutes. During this time the Ha'Penny LED oscillator was still connected, but not flashing.
Oh well, switch off eh, nothing gained.
I switched off and....blink... blink..blink the oscillator started up and gained in strength over about a minute !
That was half an hour ago and it's carried on with good strength, just like a rejuvenation with water did the last time.
The old cell carries on
Sorry for the awful pic, my camera isn't too great indoors. But, it shows the tower, the way the wire ran up to near the side of the copper in the middle of the cell and the circuit now running.
Slider and All:
Its possible that the HV can help to polarize a cell, especially if the cell is specially made for it. Yes, to open and reline channels so that ions can flow. If energy can't flow and is only voltage, it would be considered useless, but when I see what the Dr. does even without any input, it makes me wonder.
Slider thanks for posting your video, I had seen it before but it was good to see it again.
I've got a couple my low draw oscillators working well with my cells, but I'd still like to do the Stiffler type of circuits, and his way of making some leds light, but with input from coming from the cells instead.
Interesting about the effect of the plasma on the aluminum cap cell. Keep playing around with that effect, there may really be something to it.
I just made a cell that looks just like yours in that picture, but even smaller, and puts out 50 mA, but won't hold it for long, as it's so small,
so I put two cells together and they are lighting the 6 leds through the oscillator. Both cells together are the size of a single AA battery.
I'll show some pics, soon.
It's one of those experiments, where we need those 1930's black + white film knife switches !
The cell is one of your cap can types, hence why I thought the aluminium/burnt copper may be of interest. Magnesium or carbon electrodes might work just the same though.
I remember a lot of talk about HV polarizing, in August or September, but thought that was just at the time of cell manufacture, not when the things had died off.
A couple of caveats would be that there was water added the day before and that every cell will have different ingredients. Still, seeing plasma whack into a cell and it actually bring it back to life is quite the experience.
I've had Dr. Stiffler SEC 18 self builds run from an AA and lower. It's all about tuning (of course). They can be troubling to start, often needing a tap of some connection to a battery terminal to fire them up...but then they stay running unless overloaded on the HV side. That's my builds, actual units from the Dr. may function very differently. Lidmotor or Inquorate are two guys with much more experience.
All very different to Slayers simplified and elegant solution.
I'm sure that an SEC can run from Tesla tower field energy, via AV plug, but also that in doing so, it draws the conclusion that the SEC could close the loop and return some power to that Tesla tower. With having no physical connections, the loop is actually open. There's only so much available power within the proximity of the tower range, but that's not to say that the receiving device has to be passive and only collect energy..
I'll be doing similar tests with salts cells. My cells, though, only ever produce up to 20mA short term. Usual running figures for a couple of months would be 0.6V @ 2mA...and then water them and fry them with high voltage lol
THANK YOU WOOPY!
DC filaments work grrrreat with exciters. Firstly I want to post Woopy's video, which I watched 2 hours ago (I think he has already posted it in the Don Smith thread, but just in case you missed it here....)
amazing coupling between kacher and incadescent bulb 1.wmv - YouTube
It really is this simple. Exciter, 1 steel loop, and a DC filament bulb.
And my replication, with a receiver tower showing the same effect, but at about half a metre distance from the transmitter
Exciter lighting DC filament with Steel Loop - YouTube
Get your filaments ready, and put your gloves - its really put me in a good mood, after hours and hours of trying to get the same effect as the Russians get with their 'Kachers'! I think Woopy has solved the mystery.
UPDATE - One of my small DC bulbs has blown! I must remember NOT to use 32V with the smaller DC bulbs.
UPDATE 2 - Halogens work also. I can't believe I havent tried this before! In fact, I have tried this, but I just left the primary at the bottom of my receiving coil, thinking it had to be in the same place as on the transmitting coil. Well, it seems to only work when I hold the primary half way up. I get nada when its close to the bottom.
Heres another video
Exciter lighting halogen. Wireless transfer - YouTube
Definitely 'lovely jubbly' !
I've built a tower like yours now and it's on a 32V supply, erm like yours now, so will give that a go. It's one thing to get 6ft wireless range with an LED (which was cool in itself), BUT, if we can light filament bulbs at that range then that's even better.
Update
Ha, how easy was that, 2 minute thing and this 6.3V bulb lit up on the main tower !
Next, to see what happens further afield.
Very cool Woopy and Seth
Just found out, that if you put a tiny 12V 'ear of wheat' also on the loop (the bulbs for Bedini wheels) then the main 6.3V bulb doesn't seem to lose any brightness.
2x 6.3V bulbs light well, more can be added to the same loop as well, in parallel !Last edited by Slider2732; 04-13-2012, 03:28 AM.
Guys:
That's really good news, about the regular filament bulbs working off the exciters. As I don't really like the light from CFL or LED bulbs, but I love the golden light given off by the regular old fashion bulbs that we grew up using.
Thanks for sharing.
