Hi Guys,
Finally I can POST!
Never had a clue what a Bedini motor was (kinda googling about "floating heatsinks" <hovering,diamagnetism,levitation>) when this subject apeared on one of the lists at utube...
I saw imhoteps video on making a simple ssg using PC fan, looked simple enough to build w/o spending too much, besides I had all the parts laying around so I did give it a go
>>>here is the modified PC fan, guts(electronics) removed and made connections for 4th wire...just making to make it work, and it did! though I did not make ANY charging connections, jusdt wanted to make it run..
>>>2nd and 3rd pic is another motor.. rotor coil used was from a cheap "grip" type dynamo LED light... originally it was just a single coil, estimated to be awg #30, maybe about 0.3 ohm DCR, then wound another coil OVER the main coil, for feedback.. estimated awg#45(it was just laying around my bench)... well, it worked also.. this time I hooked a diode so I could extract the BackEMF.. connected it to a 12V PS(was taking 50-60mA input), the "charging" output was 40mA max (and could sting you if your hands where wet, if you had to hold it
)... tried placing a 1uF/600V cap AFTER the rectifier diode, and YEP it stores about 150Vdc and gives a nice spark when shorted..
so basically, 12V 50-60mA input ->>> 150Vdc 40mA output , not bad I think for a first timer
another thing I have noticed, when I charge a battery, the spinning lowers BUT input current STILL stays at 50-60mA...
another TEST, I SHORTED the charging terminals, IT STILL IS ROTATING.. WOW
and still just eating 50-60mA...
>>>now here is another motor I hope to use.. its from a sony tape head motor... it has 2 sets of coils (they are wired ACROSS each other)...
my question:
#1>I was thinking, would I just SERIES connect this coil as MAIN coil? for the feedback Im just going to wind a VERY thin wire over the existing ones
#2>If I wire the other coil (as slave, and add br diode), would it still output the same BEMF as the primary coil with "tapped" output<for charging>?
#3> or what is best to do here? 2 sets of coil.. my goal is I could recharge the main battery AND should also have a "charging" for another battery...
thanks!
Finally I can POST!
my question:
thanks!
