Two days running Slayer007 Joule Theif non stop.
  • Two days running Slayer007 Joule Theif non stop.
    I have used 2 12 Amp hour batteries with my battery swapper Got a little more out than the rated 12 amp hours. The Battery monitor you see is attached only to the primary side every 6 hours the battery is swapped between primary and charging side. So Since I was pulling .5 amps to run the JT and I had 24 amp hours, it is no surprise it made it for over 48 hours of run time. I am not testing out the JT on conditioning batteries, I have found a new method of conditioning that I should share soon, but Looking at the graph, I believe my batteries need a work out, they normally when fully fit yeild 13 amp hours.
    See my experiments here...
