Originally posted by gotoluc
Hi Folks,
My take on the LaFonte setup in the video is that it is very much a paralell path variant, except the moving magnet has permanent poles while the Flynn setup has electromagnets in the middle and their poles can be changed at will.
Yes all three permanent magnets are magnetized length-wise, the poles face to the bars sides. The upper and lower magnets should have their like poles on the same bar side and the moving magnet has the opposite orientation, this is what I think, otherwise the effect he shows cannot happen like that.
Yes, this setup could also be used for the Paul Noel setups, combining them is ok but how would you move the middle magnet, Luc? maybe with linear motor you started this thread...
On your question to replace the pm with a coil across the bars, if it were an air core coil then it would conduct flux when you switch current into it, but if it had a iron core too then it would conduct flux always in itself, except when you switch the current on so that the poles work against that flux. So it would be better to place the coils onto the bar as Flynn shows, not across.
rgds, Gyula
