Hello Jeanna,
its good to have a fellow woman experimenter in this man dominated field
I have little experience with the JT circuit although some so i am not fit to comment your setup.
By the way, i am way more fascinated to the energetic nature of things and hence i prefer the high voltage disruptive capacitative discharges.
Regarding the "hairpin" effect, I had a conversation with Mr Mckay, and he has the perception that a "mass oscillation" takes place or put in other words, from the constant taping of the cap discharge on the thick (0.5''+) bent copper bar (that's the original "hairpin") there are created two frequencies.
I will quote the all time classic book "The inventions, researchers and Writings of Nikola Tesla" by Thomas Commerford Martin.
In pages 190-197, he describes the energy conversion apparatus as Tesla said it in the lectures. Those pages seem a little confusing regarding its structure and some references are made regarding excess energy capture problem. Again, this method of conversion from capacitative discharges on the one hand is described as best for
"stepping down currents of high voltages" - true and also for the production of novel phenomena as that with the copper bar.
In regard to this experiment with the copper bar (i.e. hairpin) - the thicker the bar the best for the production of the effect - and he says that "In reality, the analogy is not quite complete, for in the disruptive discharge we have a fundamentally instantaneous variation of comparatively low frequency, and a superimposed harmonic vibration and the laws that governing the two currents are not the same for both"
Interpreting, the former may well be the RLC resonance of the circuit that may ranges from, say 500Khz to 10 Mhz (depends capacitor value and thick copper bar inductunce) and the second may be the "mass oscillation" or the natural resonance of a single thick coil of wire that can go well to hundreds or even Ghz range.
If Tesla was able to spot nodes upon the thick copper bar, and the nodes are spaced few inches far, then be assured its 100's Mhz range.
I continue reading, Afterwards, pages 193 (end) -194 says "When the currents charging the condenser are of the same direction (DC), and it is desired that the converted currents also be of one direction, the resistance of the discharging circuit should of course be chosen that there no oscillations"
IMO he talks about the RLC ringing elimination by inserting resistance or we can do it with a diode across the cap help at avoiding reversals of current.
For sure this kind of book has ambiguous meaning, and its up to competent experimenters to find out why oscillations (RCL I think part) shoould not be desired?
Finally Tesla concludes the lecture by saying the disruptive cap discharges bear an enormous potential in many aspects of the electro-art and makes the most skept to be optimist.
Baroutologos
Baroutologos
