Carlos F Benitez
  • Carlos F Benitez
    Hi all,
    Here are some interesting patents from around 1915-1918:
    esp@cenet — results view
    One of them is definitely the TS:
    esp@cenet — Bibliographic data
    A picture of Benitez version of the TS:
    /Hob
    Hob Nilre
    More on Carlos Benitez
    Hi,
    Check this page for more diagrams: Zero Point Energy - Carlos Benitez - MDG 2007
    Take care,
    Michel
    http://www.youtube.com/watch?v=jeYscnFpEyA
      Originally posted by nilrehob View Post
      Hi all,
      /Hob
      Very interesting. Thank you for sharing
      Vtech
      General D.Eisenhower
      http://www.nvtronics.org
        just the same i posted in the tesla switch thread a couple of days ago
        Benitez seem to be knowledgeable of many things, as Tesla's energy conversion, resonant motor operation (rotovereter) etc
        All back to the start of 1900.
        Baroutologos
          Baroutologos
          Yes, I gave you credit for this find in two other threads but i forgot to do it here, my apologies.
          I just made a thread of its own for it and dug up the original patents.
          The patent in which the picture above is found mention an "interrupter", what is that and where in the circuit is it:
          "...the primary 15 of an ordinary induction coil provided with an interrupter..." ?
          /Hob
          Hob Nilre
            If you are clever enough you will see at once that it's a circuit which was developed from the same source as Edwin Gray switching element tube circuit.
            It has the same structure and is revealing that spark gap in Gray tube has magnetic not electric nature.Carbon rods are used to pick up radiant energy which is then converted into DC.
            Check Edison notes on etheric force.
              Sorry, I'm not clever at all, isn't that obvious?
              Later in the patent he refers to the spark-gap as the "spark-gap",
              so i figure the "interrupter" is something else but the spark-gap?
              I don't know the source to Gray's circuit,
              but i do see similarities in Inquorate's circuit "something for nothing".
              /Hob
              Hob Nilre
                Sorry, I was thinking about this patent :
                http://tesla3.com/free_websites/zpe_benitez_121561.gif
                  From patent 14,311, the TS alike above:
                  "Of course the current furnished by the discharge of battery 1-2 alone, would produce a smaller charge in the batteries 3-4, but that current can be increased by any of the methods already described in the aforesaid Patents No. 17,811/14, and 559/15, and by these means it is always possible to charge and discharge alternately each battery 1-2 and 3-4, from one to another, keeping constant a predetermined charge, and furthermore producing an excess of electrical energy, that can be employed at will."
                  Intriguing!
                  /Hob
                  Hob Nilre
                    What kind of usage of transformers is this?
                    Benitez patent 17,811 is full of it!
                    e and f are diodes, allowing current only in the direction of the arrow.
                    It reminds me somehow of the hex-converter.
                    Can someone explain this please?
                    /Hob
                    Hob Nilre
                      Is it maybe related to the Avramenko plug?
                      /Hob
                      Hob Nilre
                        /Hob
                        So it looks like a magnetic pickup rather than an electrostatic one, coupled to the AV-plug configuration.
                        I did not read the full patent (on my to-do list) - I guess I should now.
                          /Hob
                          I figure the interrupter is just a switch.
                          /Hob
                          Hob Nilre
                          • #14
                            /Hob
                            Hi Goolge "Mercury Interupter". A Rotary switch that used the rise and fall of Mercury to make and break contact. Tesla spent lots of time during the 20's designing many of these.
                            this link has many interesting apparatus: The Turn Of The Century Electrotherapy Museum Tesla Library
                            ( perhaps it should be apparatii ?)
                            enjoy
                            Rob
                            • #15
                              Hi,
                              I don't want to get into this here, because I am in consultation with someone else on this topic. The Gray device that you refer to does not work at all like you suggest - Only in the patent description and in literal translation of the patent. The Gray tube is an extremely complex piece of equipment. Only a superficial rendering is made in the patent drawings. Commonly referred to as the CSET.
                              Anyone who has attempted a replication of the Gray tube has discovered, the power losses through the circuit are similar to those being experienced by those in another thread attempting to replicate alleged results from the "telsa switch" - I wish these people luck working with solid state materials and the TS.
                              One final comment, regarding the supply of excess current, you will only ever get that which is there. Free energy is a much maligned term. Etheric force , as per Edison, is a tangible asset if you know what it is and how it works. I would also suggest that it is not quantum physics either, but something far more simpler to manipulate.
                              Rob
