Carlos F Benitez
  • #16
    Carlos Benitez
    Originally posted by ourbobby View Post
    Hi Goolge "Mercury Interupter". A Rotary switch that used the rise and fall of Mercury to make and break contact. Tesla spent lots of time during the 20's designing many of these.
    this link has many interesting apparatus: The Turn Of The Century Electrotherapy Museum Tesla Library
    ( perhaps it should be apparatii ?)
    enjoy
    Rob
    I've used mercury switches with the Bedini circuits that was triggered
    by a lobe on a pulley that comes around and thumps the mercury switch
    that caused the caps to discharge into the charging batts. Works just fine
    but I like copper contacts better.
    The Benitez circuit works. It is similar to the Tesla Switch in concept.
    I independently developed some circuits about 7 years ago that I later
    found were almost just like Benitez in concept.
    In the Tesla switch, do you see the load is connected by 2 grounds of
    different negative potentials and they have a common positive?
    The difference between the negatives can power a load with no voltage
    but all the benefits of amperage, cold amperage. If you use the wrong
    frame(s) of reference, you won't get it. In splitting the positive you have
    common ground with a positive potential difference.
    Originally, after learning of the concept of splitting the positive, it was
    a common sense deduction to look for splitting the negative. That isn't
    completely what is happening but that is how I stumbled upon my own
    circuit variations that take advantage of the concept in the paragraph
    above.
    RPX & MWO http://vril.io
    • #17
      above.
      Hi Aaron,
      I don't think that many people understand what Ed Gray was saying regarding splitting the positive. I think he was confusing part of the CSET process with outcome. That being said, it follows that if we are talking about the same thing, then I would personally disagree with the concept a split negative. The incidence just could not appear.
      I hadn't seen the Carlos Benitez patent until a couple of days ago. That it works is good news. I have been experimenting with a similar arrangement. The TS that I built some time ago - before I realised this thread was running a few days ago - used the schematic originally supplied by Ron Brandt. There are a couple of interesting things regarding this circuit. I used 40 amp SSR's driven by a common mosfet driver TC4427 I think. I have blown a few of these SSR's. By interesting, the current would surge up through the SSR's and over heat them. At $16 a pop to replace them, I persevered.
      The Surge in current had to be from the battery as the drive to the SSR was controlled and the scope showed no signs of variation. The batteries, IMO, were charging and storing the charge and then burst releasing the built up reservoir of current. I also set up a series of fans to the heatsinks. The most current that I could draw through the SSR's without using a freeze technique on the heatsink, was 25 amps.
      Now, If I duplicated the output across the positive terminals to the flip flop arrangement series parallel of the TS, that is I put capacitors of exactly the same size and type in series to the pulse - as per those on the output from the negative terminals, hey presto!! 400 ma across the SSR's. Output still working and no blown SSR's . No Heat problems. Batteries drain very gradually. Also, I am able to pulse the SSR's up to 1000hz. Maximum rating for this particular cheapie. I also used the sg3524. worked for me. Good circuit from John Bedini. Importantly, no build up of storage current!
      It was at this point after a couple of weeks - also waiting for replacement SSR's from China - that I realised that the old auto batteries I was using had to be the source of the problem. they are the lead paste type. I am currently - in my spare time!! - looking at making some NiFe batteries. Previously called Edison Batteries. I think they will be like hens teeth to obtain.
      Hope this helps
      Rob
      • #18
        I've used mercury switches with the Bedini circuits that was triggered by a lobe on a pulley that comes around and thumps the mercury switch that caused the caps to discharge into the charging batts. Works just fine but I like copper contacts better.
        How much amp a mercury switch can handle? Have you ever use it to switch coil? I really want to know if it's sparking.
        • #19
          Benitez concept, ts, similar
          I agree it isn't splitting the negative, that is why I said that isn't what
          is happening. I was simply playing with the idea and looking at everything
          inverse and then stumbled upon something else, which is similar to Benitez.
          I had the Benitez patents in my archives for 5 years but never really looked
          at them until the last couple months - and to my surprise, it is similar
          to the TS and similar to what I was doing and there are others that
          apparently have stumbled across similar concepts.
          Anyway, I can't confirm the Benitez circuit working as the patent shows,
          but I can confirm the concept or variation of the concept. When I said
          it works, I need to clarify that I mean the concept.
          The back and forth flip flop, I was using a mechanical oscillator as the
          switch to
          do the flip flop. I never did anything with the sg3524 but last time I was
          at John's he said I could use those for my concept.
          You can get the NiFe batts from China...from small to really large industrial
          size. They still make them. Last spring-summer I was investigating all kinds
          and came across those.
          • #20
            mercury switch
            I don't know. It is a mercury switch similar to what is in the old thermostats. Just
            a few ml's of mercury in a glass tube with contacts and 2 wire leads.
            I was discharging up to a few hundred uf's charged to a few volts above
            batteries. This was 8-9 years ago or so and I can't recall if there was
            sparking.
            • #21
              Originally posted by nilrehob View Post
              From patent 14,311, the TS alike above:
              "Of course the current furnished by the discharge of battery 1-2 alone, would produce a smaller charge in the batteries 3-4, but that current can be increased by any of the methods already described in the aforesaid Patents No. 17,811/14, and 559/15, and by these means it is always possible to charge and discharge alternately each battery 1-2 and 3-4, from one to another, keeping constant a predetermined charge, and furthermore producing an excess of electrical energy, that can be employed at will."
              Intriguing!
              /Hob
              Dude, i completely forgot about this, my old phone stopped displaying pdf's and i didn't read the patents.
              I could kick myself, and probably will.. Looking into it now.
              • #22
                /Hob
                Hob Nilre
                • #23
                  Hi all,
                  Here are some interesting patents from around 1915-1918:
                  Posted these at my website: Bestandsoverzicht van /pdf/Patents/Benitez/
                  Enjoy!
                  • #24
                    Hi all,
                    esp@cenet — results view
                    One of them is definitely the TS:
                    esp@cenet — Bibliographic data
                    A picture of Benitez version of the TS:
                    /Hob
                    It is more than "just" a TS...
                    Zero Point Energy - Carlos Benitez - MDG 2007
                    14,311. Benitez, C. F. Oct. 9. [Addition to 17,811/14.] Systems of charging and discharging galvanic batteries; supplying by arrangements of condensers and transformers; systems of charging and discharging condensers.-Batteries of accumulators are arranged in two sets, and one set, consisting of the parts 1, 2 being charged and arranged in series, is used to charge the second set consisting of the parts 3, 4 arranged in parallel or series-parallel. The charging-circuit contains the primaries 15, 27 of two transformers having condensers 14, 22 connected as shown, with a view to augmenting the charging-current, so that when the second set is fully charged by arranging its parts in series and the set 1, 2 in parallel, the second set will be used to charge the first, augmentation being again obtained. The effect obtained from the condensers and transformers is described in the parent Specification and in Specification 5591/15. A trembler may replace the spark-gap 23.
                    So, 23 is a spark gap, while the "charging-current" goes trough the primaries of these two transformers. So, it is more than just a TS and he also refers to earlier patents for the trick. Page 2:
                    Of course the current furnished by the discharge of battery 1-2 alone, would produce a smaller charge in the batteries 3-4, but that currrent can be increased by any of the methods already described in the aforesaid Patents No. 17,1811/14, and 5591/15, and by these means it is always possible to charge and discharge alternately each battery 1-2 and 304, from one another, keeping constant a predetermined charged, and furthermore producing an excess of electrical energy, that can be employed at will.
                    • #25
                      What kind of usage of transformers is this?
                      Benitez patent 17,811 is full of it!
                      e and f are diodes, allowing current only in the direction of the arrow.
                      It reminds me somehow of the hex-converter.
                      Can someone explain this please?
                      /Hob
                      Very interesting detail. As I posted here
                      http://www.energeticforum.com/renewa...tml#post123445
                      Benitez explains how they made diodes back then, very similar to electrolytic capacitors. Page 9 and on:
                      http://www.tuks.nl/pdf/Patents/Benitez/GB121561A.pdf
                      And then we got another FE device that relies on some kind of "water fluid in between electric plates" in series with a coil to function, just as Bedini's SG *and* TS, Gray, Meyer/Puharich. See: http://www.energeticforum.com/renewa...tml#post124383
                      It looks like the combination of a coil and a device containing an electrolyte in between metal plates, either an electrolytic cap, a battery or a WFC, is the way to be able to use a sharp electrostatic pulse. That what Tesla called a disruptive discharge, which is a sharp rise or drop of voltage, hence a large change of the electric field, which can give rise to a magnetic field according to the Maxwell equations, without the need for a current to occur. Now because the ions inside the fluid are slow moving, it takes a while before a current can actually flow. During this time, you can apparantly build up a magnetic field inside the coil for free, which you can then subsequently tap and use, for example to charge a battery or as a current when the coil is part of a TF.
                      • #26
                        Hi my first test the battery switching
                        https://www.youtube.com/watch?v=LI_K...e_gdata_player
                        • #27
                          https://www.youtube.com/watch?v=hO2-...e_gdata_player
                          First test without HV loopback
                          • #28
                            I'm a Benitez fan. You might pm Matthew jones. He's replicated 500 watts F.E. for months on end.
                            Can you give details on how you built your trembler?
                            Keep going.
                            • #29
                              Hi part 3
                              https://www.youtube.com/watch?v=rHVg...e_gdata_player
                              Ciao Luca
                              • #30
                                Originally posted by gnino View Post
                                interessante anche per il fatto che nel circuito conduce anche la parte che viene magnetizzata mi fa pensare all'effetto Einstein _ De haas _ anche il brevetto Giampaolo Maccanti -- alleged free energy generator
