Rodin Coil Tests and Replications
  • pouder,
    in order to be able to drive bigger loads ( voltage/current )...you coul wire up your wave generator as in the attached image...which is what im using to allow me to use the PIC which can only supply mA....but can turn on/off the transistor in order to use much bigger currents etc..
    simply replace the two connections where it says "from PIC"....and connect your wave gen there ( observing correct orientation on the diode that is in the opto-coupler )
    in terms of the coil itself, bare in mind..... it may not be geometry that produces the "goods" so much as "the order of the windings".....as evidenced by Jamie removing the hollow donut...then squashing the windings flat..... the coil still p[erformed just as well as a properly shaped ( correct geometry ) coil.... but of course the "order" of the windings was still the same as before he flattened it.
    • YES!!! thank you rave and jbig!! .. I knew I found the right forum..
      • *i mean rave ..... the vid for the comp to the starship?
        • Be careful of the Jamie factor.
          Originally posted by rave154 View Post
          pouder,
          Rofl. Just a joke there. I think that the operation that worked that was actually tested was the floating magnet in that crushed coil. If one wanted to do what Rodin talks about and generate immense energy then I would pay attention to the geometry more. Since it is all about manipulating the fields to create a huge vortex out the ends I think he means that spinning the vortex faster would generate more in return. Because this energy, once in motion, is more powerful than anything we know. It is what I suspect allows BEMF to form in a coil.
          Think of the coil as a huge windmill. The main props are the huge swirling BEMF fields that get created. This turns the smaller ones in between the coils windings generating energy that way. Like a large gear turning thousands of smaller ones. Now this is only a theory but a very sound one from how Rodin describes the action of the geometry.
          • just found this.... a FASCINATING READ of how flux works etc..... WELL RECOMENDED !!! ( im about half way through here and its already explained some things about transformers that were baffling me !! )..
            Login
            if the above doesnt work i have attatched the same file
            • That was a good read Rave. I am half way finished with the coil we spoke of earlier.
              I will be applying a grey tube senario to the new coil as soon as I recieve my order.
              Makes sense....
              Rob
              • Originally posted by stubbs View Post
                Makes sense....
                Rob
                Please stubbs if you use the grey tube stuff with this be very very careful about the static nature to this energy. Very high voltages can come about from using this if properly done.
                • It would not be the first time I have been nailed with this thing...
                  I have taken a few precautions as far as extreme ESD goes.
                  I have 2 lightning rods spaced ~2m apart, plus the pluming of my house.
                  If that does not get it; then I deserved it...
                  • Jbignes5 you are right. this stuff is kind of spooky at times.
                    I wonder how many times Mr. Tesla got nailed, while figuring out just
                    half of his accomplishments.
                    • Damn stubbs.....just "what" exactly are you planning here?
                      • A lot...
                        Tesla got nailed a lot. That is how he did things. He knew that no one had done it before so all avenues needed to be looked into. Including the exposure to things that might not have been ok for him to be exposed to.
                        It sounds like you have all the bases covered so Experiment well my friend. Although this energy is weird at best who knows what to expect. Take care.
                        • Thanks for the concern. Alot of people would only be interested in the outcome.
                          • Originally posted by rave154 View Post
                            "a single heavy copper conductor in the center of the coil, where the apex of the coil is, with a magnetic quenched spark gap" per Jbignes5
                            similar to the grey tube setup.
                            It seems to make perfect sense...
                            • stubbs......now THAT..........i cant wait to see on video......but be careful at all times..........take tesla's and Alanniss's advice.....one hand in my pocket at all times
                              • Actually rave....
                                To tell you the truth if Tesla is right this is pure voltage potential. The only harm I see is coming from the emissions of the event. Always make sure you set the arc space to be above 20k hertz. I think 15-20k is a reasonable timing to avoid strange effects.
                                Also if you are using an arc space, enclosing it in a mineral oil bath allows for a better and cleaner arc timing with few miss firings of the arc space. like pre arcing. Although this can be done later Tesla says it helps a lot to have it in an oil bath. Weather this works out or not is to be seen.
                                Also make sure the connector going from the caps to the arc space is a thicker strap of copper. Seeing that Tesla says that it is harder to explode the wire that way. But this might have been because of the voltages Tesla was using. So keeping that in mind one could lower the arc event potential and still use a smaller gauge wire or copper strip. This copper strip is where the event comes from not the arc space. It's like a mini antenna that radiates before the arc happens. Keep that in mind when designing the unit to go into the coil.
                                Since Tesla proved that pure Voltage is essentially harmless I still think that caution is best. Atleast until we know more about this energy...
