I just glanced through the article and I am not sure this devices "heals", as it causes injury to the tissue through the diathermic effect. But I could be wrong as I did not read the whole thing...
Interesting. It work at 310KHz but I somewhat confuse with the mention of 80ms to 220 ms duration.
Acupuncture work by inducing pain to spesific area. It maybe just coincidence that the researcher hit the right spot. Or it work just like Royal Rife device.
Hi suchyo,
Hope you don't mind if I post here.
Have you heard of Dr Hulga Clarke by any chance? She wrote a few books the first of which was "The Cure For All Cancers" and then later released the book "The Cure For All Disease" in which she published the circuit for a Rife type DC device she named the zapper, which is much cheaper to build and it naturally sweeps all the frequencies that Rife found beneficial. Her son is an electronics engineer and he designed the circuit for her. I have built several of the devices and changed the circuit to include an LED that would go off at a voltage below what she said would be ineffective, that way one would know when to change the batteries. I also had to add another 9 volt battery to the circuit to get the voltage above that same recommendation as I was never able to do it with just one. The circuit is designed to a frequency of 30khz and an output of above 5 volts using a 555 timer and various caps and resistors. At one time I was able to build the complete circuit boards and mount it in a case with LED and switch and I added 1/8" audio plugs so that the hand held probes could be unplug from the unit for ease of storage. After building these and using them since 1989 I have only had a need to take just 1 (one) antibiotic tablet for a tooth that got infected and needed a root canal done. That was the only place on the body the unit could not reach as she mentioned in her book also. The inner tooth just has a few live nerves running in it with not much blood flow around it so these electrical impulses have a hard time reaching and effecting that sort of infection. The reason I only needed one tablet I believe is that I stopped using pharma antibiotics which builds the immune system up. I now believe antibiotics destroy the immune system and weaken it further, but that is just my take on it based on my own experiences using this device as I am not a doctor. This device is the cure for the common cold and flues and many other things.
Good Day and Good Health.....24
Hi 1NRG24Seven thanks for the info can you please post your schematic so I could replicate.
Another Dr using electronics to heal cancers is a Dr Holt here in Australia. He is based in perth and has been through hell and back with the media, but over 1000 patients swear by his methods.
As far as I know the machine generates an EM field or radio waves of some description.
P.S. The best and most cost effective way of getting rid of cancer is baking soda. Dr Simoncini of Italy is an Oncologist who specialises in this form of treatment. He has been so successful that his world wide medical licence has been cancled because he no longer recommends chemo or radiation treatments. This is a big no-no in the cancer world, even though the world wide success rate of chemo etc is only 25% , and out of that 25% most are dead within 10 years after treatment because of follow up cancers as a result of the radiation treatment for the first cancer.
Baking soda is a big help in changing the ph of the body.
I believe in the Rife treatment, but I don't believe in Hula's theories of how the electronics works ( very odd stuff ), but I have not tried Hula's device. I have researched Rife's work, and GENIUS is what I say every time I look at his work and method.
I believe what I got from a chinese doctor was some of the best advice I have ever heard.
He said this, in America you have some of the best testing devices ever on the planet. However the problem comes when the doctor attempts to fix the problem.
That just rang so true to me, the cure = get you to take this pill forever.
The cure = to cut, burn or radiate the problem.
So many good methods of healing. I know Jesus heals today, and I know that prayer is awesome, and I know that if we were to change some simple things of our lives we could avoid many many problems that we bring on ourselves.
The zapper basically electrocutes blood-borne parasites. It also speeds along the death of parasites from body tissues, organs and digestive tract. Dr. Hulda Clark and other courageous health care practitioners have noted that the ongoing failure to acknowledge the widespread and harmful role of parasites in human disease is the greatest medical conspiracy of our time. Get rid or your parasites, and you're on your way to great health!
Baking soda alkalyzes the body. Cancer needs an acidic and low-oxygen environment to thrive. Once you alkalyze the body's tissues, they are able to carry more oxygen. Otto Warburg won the Nobel Prize in 1931 for his work in this area (respiration of cancer cells). However the implications of his work with regards to curing cancer are passed over in medical texts.
A raw, plant-based diet will alkalyze the body. Raw fruits and vegetables also deliver their vitamin, mineral and enzyme content more intact (relative to cooked food). This kind of diet will nurture the immune system to reverse many diseases. Staying away from acid-forming and mucous-forming foods (especially grains like wheat and corn and heavy meat consumption) helps this process along.
Bowel and liver health are crucial to fighting all diseases. Clean out the bowel and the body can eleminate its toxins properly. What you don't eliminate thru the bowel may come out thru the skin, lungs or build up in body tissues - not a good thing over time. Doing liver flushes enables the liver to detox the blood - a very important factor in fighting disease. Check out the work of Dr. Max Gerson and his daugter Charlotte Gerson in this regard. Look for video footage of Charlotte Gerson online and just listen to what she has to say.
BTW, Dr. Tullio Simoncini is completely reversing cancerous bowel obstructions by irrigating them with a 20% baking soda solution in a matter of days (he's also doing the same with breast cancer, lung cancer and other forms). It's all online for anyone to see on his website and others, in vide format. I believe a bit of squeezed lemon juice in water will similarly alkalyze the body. Even tho it's acid, it becomes alkaline once ingested.
Parasites (parasite cleanse - check out what Hulda Clarke has to say)
Bowel (bowel cleansing)
Liver (liver flushing)
Raw Plant-Based (alkalyzing and nourishing) Diet
Paying attention the the above, from what I've read and come to understand, will alleviate most disease. Hope this helps someone.
Don't believe me - do your own research. Alternative Medicine Forums, Blogs & FAQs on CureZone.com is a good site for further investigation into these areas.
Bob
Any chance you could post the schematic? I'd love to build one of these.
I used the circuit diagram only once to make the first board then refined that board for ease of duplication and then used the second board for my visual reference for duplication, I was making two and three at the same time. I would need to open up one of my completed unit and try and make a circuit diagram off it with component parts list, might take me some time...maybe this spring. Unless you have her book you will have no clue how to use it, if you held onto the hand probes unwrapped with a few layers of tissue paper you will transfer copper into your blood stream. Tissue is used then made damp or wet to make you part of the circuit so the unit will cycle through all the frequencies. If you used it just one 8 minute session it will make you sick with a cold. The reasons for this are given in her book and yes she is correct it does just that. One must use the unit 8 minutes then wait 20 minutes and another 8 minutes then wait 20 and then the final 8 minutes, so a total of three 8 minute sessions with 20 minutes off between each. The zapper neutralizes bee and wasp stings and I have not tested it yet on snake bites but believe it would neutralize these poisons also. A friend was stung here in the hand who was highly allergic to bee and wasp stings and he was saying it would probably send him to the hospital. I hooked him up so he could treat himself with a zapper....the swelling stopped pain was decreasing and he was truly amazed as his usual experience was that the sting would eventually start to restrict his airways and make it hard to breath making him seek medical help, non of that happened. That made a believer out of him.
One more thing the Hulda Clark zapper is a much simpler build than the Rife machine, that is why I originally chose her diagram over the Rife, and a huge difference in parts cost. It will cost you a small fortune in parts to duplicate a Rife. Plus the Clarke version is portable, you don't need wall current.....24
Hi all!
I've found this (long) document on Rife and his instruments. Lot's of history and some schematics. A History of Rife's Instruments and Frequencies
By the way, 1NRG24Seven, why do you say duplicating a Rife instrument would cost a small fortune? It's got quite few parts and old vacuum tubes can be replaced by modern solid state devices Even if you use top of the line components the overall cost is affordable. At least around here, it costs me waaay more paying someone qualified enough to build it and test it, than the parts themselves. Still when I come down to money vs. my (large) family's health...well I don't have to think too much about it.
Good luck!
