Peredev Mag Motor Geometry
  • Peredev Mag Motor Geometry
    About a year ago before coming to these forums I was studying the geometry of the
    Peredev mag motor using my best guess based upon the few videos available on you tube as a starting point to attempt to draw a template. My best guess of the number of magnets around the circumference of his main rotor was between 28-33 as there was no way to know for sure by observation and still shots of the videos. So I then started drawing each of the five guesses between 28 magnets to 33 magnets and discovered only the 30 magnet position formed 30 perfect triangles, it was the only choice I believed worked and also gave the angle of the holes to be drilled into the large disk so that the torque pushed not towards the center but between the center and the outside of the rotor
    I thought I would share this and a pic of the template that I came up with. This template would be laid out on a disk large enough so one could cut the clam shells out of same large disk, So first the large disk would be cut, then drilled through the thickness of the clam shell into the inner rotor from the edge of the disk, then the clam shells could be cut away from the inner rotor so all holes would line up perfectly and their respective angles. The gray lines depict the angle of the drill holes to make the unit rotate either counter clockwise or clockwise depending on which set of angles you decided to use. I don't know if the rotation direction should be changed as to where in the world you were using it. I have heard that in Australia that water drains in the opposite direction in its funnel than that action in the USA. I did not include in this drawing or template the cuts to the clam shell into their two separate components as seen in the video. These are simple cuts at 6 O'clock position straight up to the rotor and at the 12 O'clock position straight down to the rotor respectively. The two clam shell pieces then look like they were rounded at the top and bottom of each cut to allow them to pivot. Pivot point holes would be determined after this step was done so one could physically move them in a like manner as was seen in the video. How much one would round these edges would also become obvious after doing this as you would observe anywhere it might bind up. Also the claim shells would have less magnets in them in number than the main rotor because of the bottom and top cuts to separate the two pieces, Which I believe is also beneficial so the rotor does not create a place to lock up. Searl claimed in his videos he had to have at least one less magnet on the outside magnets to get his machine to work, or it would not spin. Now I know Searl has nothing to do with Perdev but I only mention it because his device was also all magnets, Howbeit different in construction yet I believe its one of the clues this Peredev design also uses. Let me make it clear that this is all based at this point on speculation and or presumption, neither of which means didly until one actually tries to duplicate the design. I always try to study a mater and its geometry for some time before deciding on the most likely design to approach, taking in consideration many drawings and using a process of elimination one from another. This method has always served me well in passed builds on various projects and rarely came up with something that did not work. This seems to save time and materials wasted by failed designs.
    I would challenge anyone to look at the Peredev videos and you will see that the angles the magnets are drilled into the clam shell and rotor are very close to the geometry here if not the same, and as stated the number of magnets if you do a pause in the video you can count what you see that 30 magnet positions could very well be possible to what he used. Maybe someone on this forum has actually seen it in person and could confirm or dispute this for me, otherwise my guess is as good as anyone else. Again I base my best guess on the way the geometry came together using 30 magnets positions on the rotor.
    Peredev mentioned magnet shielding this would be an area for experimentation to find out what works best "BEFORE" the holes are drilled. First you will need to pick out the size diameter of the magnets you will use and their lengths or the use of button type magnets stacked, and the thickness of rotor/clam shell non magnetic material. I am thinking even wood might work for a prototype here before one would invest in the more expensive (what looks like) a teflon based material used in the Peredev design. I know there is another name for this material as i have several pieces of it, it just slips my mind at the moment. Once one knows the diameter of the magnets plus shielding cylinder thickness together to determine final (tight fitting) hole diameter drill size you will be using. Also there needs to be determined a rotor side pin hole perpendicular to and through the magnet shield/holders to fasten them in a way so centrifugal forces do not force the magnets out of their place. This hole will be perpendicular to and through each magnet hole on clam shells and rotor alike...this position
    of the drill holes for this procedure can best be determined during the build
    Notice in the pick a right triangle above to the left of the largest circle. This was just an after thought I added so as to make a drill jig to hold and guild the drill in at the perfect angle to the outside of the circle. Many ways can be used to do this but a jig will be a must build for these holes. I imagined a special table top drilled and 30 holes drilled into the side of the disk so you could drill a hole and move it one position to the right or left peg it or bolt it through so it can not move then the next hole can be drilled. Sort of like a lathe indexing jig, only laying flat on a table top. Then drill jig also mounted to not move so each progressive position could be drilled perfectly in through the edge of the disk before the clam shells were cut from the larger disk as mentioned above.
    To offset the middle rotor (of three like in the video) from the center claim shell all one would need to do is place all three center rotors together and set the offset you desired then drill the four center holes around the shaft opening through all three pieces. Or another plan might be to drill seven holes and only use 3 for the hub mounting plates...this way you could alter it by experimentation. I think an odd number should be used here as it offsets the angles to something out of phase between the rotor and claim shell so as to prevent lock up points. I choose seven for this as the angle of the great pyramid is 1/7th of a circle. On a 360 degree circle that angle is 51 degrees 51 minutes and 51 seconds. Good luck finding that without my modified 350 degree circle compass template which I will also make available here, or a simple seven segment circle template or both.
    What I am proposing here is a starting point for a build, not a final draft for a prototype. Anyone desiring to take the leap would have to do your own engineering for size of rotor, material thicknesses, drill and magnet size, shaft size, etc etc etc.
    If you do decide to try it please post any ideas you might have and results if any. I can not start this project until two other projects on the drawing board are completed which will get me off the grid this year. Then will have money to play with with the savings to explore the Perdev possibility here.
    Good Day troops, and a better day yet to come....24
    PS Sorry for the wordy post here, My communication skills need polishing.
    as soon as I figure out how to post pics here will do so.
    ok lets see if these links work, if not let me know
    2 drawings
    Magnetic Motor usethis30 on Flickr - Photo Sharing!
    Heptahedral2 on Flickr - Photo Sharing!
      I once thought about building a Perendev replication, so worked out the figures for it. I decided against it because of the huge cost if it is built right. The magnets would run about $15 to $18 each, and you would need 108 of them just for the three rotors, let alone the stator clamshells.
      The Perendev uses three rotors, each having 36 neodymium magnets which are 35mm (about 1+3/8 inch) diameter. The preferred angle for magnet bores, as mentioned in the Perendev patent application, is "between 30 degrees to 35 degrees," and this angle is "relative to the tangent to the circumference of the rotor at the mouth opening of its sockets." In other words, draw a circle to represent the rotor, then draw a straight line at the outside of the circle which contacts the circle circumference at the center of the line, and this line is the tangent to the circumference. The contact point between the line and the circumference will be the center of a magnet bore, and the bore will be at an acute angle of 32.5 degrees (splitting the preferred angle range) to the tangent line.
      Here's a photo of the Perendev triple stack rotor, and you will notice the black lines that mark off a 90 degree angle. Not counting the magnet at the left black line, you will count 9 magnets over to the black line at the right, and 9 more would take you half way around the circumference. You lose sight of the second 9 magnets, but can count the retaining pins. Thus, 18 more magnets would bring you back to the line you started at, for a total of 36 magnets.
      Notice the arcs cut into the rotor at the left of each magnet bore. These are for additional shielding, which has not been applied yet in this photo.
      The shielding for the magnet bores is shown below. The older version used a 25mm diameter neo magnet and a bismuth shield, but they later went to a 35mm diameter and improved shielding. I realize that the 35mm magnet looks smaller, but it's just the aspect ratio of the photo that makes it appear that way. I would say that the above photo shows the rotors with the 25mm (about 1 inch) diameter magnets installed.
      Hope that helps,
      Rick
        Hi Rick, were those pics from an "original" or from Peswiki's replication?
          That's the actual Perendev stuff.
            Thanx Rick...I was going off of hard to see video clips, did not know these photos were available. Nice clear high res photos.
            I knew this was going to be an expensive build and was the only reason I chose not to jump into it before more information was available.
            Do you have any information Rick on the motors output equivalent in break HP, seemed to appear from videos as a best guess to be significant. Also any information of this device ever being available for purchase? I hate to see it get suppressed like so many others. This part I don't understand as anything I have built I could also duplicate and start selling it, why these inventors don't do that is beyond me. As you built more units and get more orders the price would soon come down as you buy materials for the builds in higher quantity. Sure the first ones will naturally be more, but with something like this people would pay it.
            BTW Rick how you doing on your magnetic motor build, did you get that mechanism working yet for the final stage?
            Thanx again ....24
              Hi 1NRG,
              Yes, way too expensive just to replicate in order to prove it works. It's too bad that companies like this don't see the light of providing licensing to individuals who want to replicate a single unit, and offer that at a reasonable price along with all information needed for a successful replication. I think there would easily be hundreds of people who would pay $100 for such a one-shot license and builder's info kit. That could be paid for and downloaded on the Internet, so no costs would be involved. If only 100 people purchased the license, that would generate a quick $10,000 for the developers. And, if the unit can be replicated to work as shown in the Perendev videos, these 100 replications would bear independent testimony that the calaims are true, quell all skepticism, and fuel large orders. If not able to fill those orders on their own, they could then license manufacturing rights to 100 builders, for say 1000 units per license, and offer these licenses at let's say $10,000, giving those who purchased the original licenses (and who built successful replications) first shot at the manufacturing license. So there's another fast million dollars with the company doing absolutely nothing. That would give them the capital to etablish their own manufacturing facility, if they don't already have one, and future sales could be extremely lucrative. In that way, they could accomplish all of their long range plans many years sooner than under their present plan, and not have to take in any partners in financial agreements that would diminish their future returns. It beats the heck out of me why such obvious answers are not seen by developers, who instead do things the long and hard way.
              And yes, I am moving forward on my own magnetic motor, in "weekend warrior" mode. I'll post some photos shortly.
                Another note....
                Your above idea of cutting a large disc, drilling the bores, then cutting away the clamshell area is a possibility, but keep in mind that the clamshells use fewer bores, so you would be making holes that will not receive magnets. Also, at least two holes (and possibly four) could not be bored this way into each rotor. This is because the ends of each clamshell which form the pivots must have material to pass the pivot bolts through the clamshell stack, as well as the bolts adjacent to these which are used in conjunction with spacers between each rotor, as shown in the tri-stack clamshell assembly diagram on page 17 of the patent document. Using the drawing of the rotor stack shown on page 14 of the patent document, and scaling this to the 35mm diameter of the magnets, I have estimated the diameter of the rotor to be about 622 mm (24.5 inches). The side to side thickness should be twice or more than the 35mm magnet diameter, so 70mm (2+3/4 inches). The rotor drawing shows 18 magnets used for each rotor, but the Perendev rotor stack shown in the photo has double that number, so it would appear that the magnets are closer together than shown in the diagram. Judging from the photo, the rotor would not appear to be any larger than 24.5 inches diameter, and may in fact be closer to 21 inches, basing the measurement on a 25mm (1 inch) diameter magnet size.
                Keep in mind too that the bores must accommodate not only the magnets, but also the outer shielding and the inner pyrolytic carbon layer.
                Notice, in the patent clamshell assembly drawings, that the bores of the three clamshells are aligned straight across, rather than staggered as on the rotors.
                Rick
                  Brady Arrested
                  Hi Folks,
                  Just thought you'd like to know that it is now being reported that Mike Brady has been arrested for embezzlement because he took millions of dollars from people for his fake PMM systems, and never delivered them.
                  A fitting end for a classic fraudster!
                  Perendev magnet motor inventor arrested for embezzlement
                  Enjoy,
                  Peter
                  Peter Lindemann, D.Sc.
                    Are you sure his PMM was fake Peter? Could it be that organized opposition to such a device brought about a means to stop him from fulfilling his obligations, thereby making him look like a fraud? Seems Paul Pantone for one was brought up on SEC charges then the case was made into a mental issue to take him out of circulation taking him to the funny farm...then he could not fulfill any outstanding obligations. I am not convinced that the Peredev design was a fraud. The opposition to such devices is real and all hell breaks lose to stop anyone from bringing this sort of technology forward. Seems even tho they have loads of money given out to these inventors for some reason they still can't seem to succesfully manufacture and get the ball rolling. We have story after story of how people have been supressed...why even Nikola Tesla one of the greatest inventors was eventually effectivly neutralized by JP Morgans influence, Turns out JP Morgan was just a front man for the real money power of the Rothchild banksters dynasty
                    Good Day...24.
                      Pretty Sure!
                      Are you sure his PMM was fake Peter? Could it be that organized opposition to such a device brought about a means to stop him from fulfilling his obligations, thereby making him look like a fraud? Seems Paul Pantone for one was brought up on SEC charges then the case was made into a mental issue to take him out of circulation taking him to the funny farm...then he could not fulfill any outstanding obligations. I am not convinced that the Perendev design was a fraud. The opposition to such devices is real and all hell breaks lose to stop anyone from bringing this sort of technology forward. Seems even tho they have loads of money given out to these inventors for some reason they still can't seem to successfully manufacture and get the ball rolling. We have story after story of how people have been suppressed...why even Nikola Tesla one of the greatest inventors was eventually effectively neutralized by JP Morgans influence, Turns out JP Morgan was just a front man for the real money power of the Rothchild banksters dynasty
                      Good Day...24.
                      Hi 24,
                      Yes, I am 99.9% sure that the Perendev PMM design does not work. Many skilled engineers have attempted to replicate it, and none have seen it produce forward torque. The design, as proposed, produces a set of conditions where the machine will only rotate under the influence of an external motor.
                      You are correct about the operation of suppressive forces, but they only have to come into play when a technology works, AND the inventor is in a position to market them. I do not believe that this is a case of suppression, because Mike Brady never had anything worth suppressing!
                      Peter
                        Originally posted by Peter Lindemann View Post
                        Hi 24,
                        Peter
                        Hi Peter,
                        I have contacted Brady some 10 years ago asking for a Canadian dealership on behalf of my company. Basically asked for sizes, input, if any, output parameters, weight, cost etc. No technical details. I was doing my homework, finding out if he might be genuine. I never got an answer as I had expected and I have posted this on KeelyNet at the time, if I remember right, may be energy 2000, may be both.
                        The real problem is, that to sell an electric whatever in Germany needs a pile of approvals and certifications. This means, That the officialdom has known, that Brady was a con. They allowed it to grow this big, to have an outstanding scam, to throw bad light on all free energy research. This was a behind the scenes political action of the "masters".
                        There is actually a fair possibility, that Brady is not even a con, but worked as an agent on the "master's" behalf and that he will get new identity after the show trial and spend the rest of his life somewhere comfy.
                        Anyway, if it goes off with a blast, like Perendev did, keep your hand on your pocket.
                        With kind regards, Slavek.
                          hmmm
                          are you saying that this video:
                          YouTube - FREE ENERGY 16 Similar Perendev Magnet Motor But Diffrent Style
                          and this one of mr allan sterling at teslatech 2005:
                          YouTube - Perendev And Bedini Magnetic Motors
                          are fakes? dont believe so...
                          Hi 24,
                          Peter
                          • #14
                            Interesting first video, I wasn't aware of it - convincing!
                            Sterling's Perendev replication was a non-runner though, he even says it during the demo.
                            • #15
                              sprocket
                              yes, it will not run for long times, but the truth is that it runs for a while!
                              in the first video, you can see some magnetic cancelling alloy in the magnets, and i think that is the trick! all the rotor magnets are repel by the the outside magnets!
                              hugs
