I would like to take the time to start a discussion about the Aether and the manifestations it effects in our universe.
I guess the best place to start is where it all begins. The Aether, in all it's grandness, is the perfect mono pole. It is smaller then any known molucule we have found to date but this doesn't limit it's effects. Since Aether particles are monopolistic in nature it wouldn't be a large leap to say that the reason they exist is because of a great bang. Bigger then anything imaginable this bang exploded a greater mass then anything you could imagine. It flung particles everywhere. Particles of every size were created from the eddies in the main mass of that explosion but the most comon particle was the smallest quantum of a particle. At the quantum scale this particle is
attracted and repelled with the same basic laws we understand today but for one thing. Everything has a base limit to how close they can get in that quantum world. It makes a network of squishy little spring like masses that move and react to it's neighbor either by a very weak potential difference (north or south) or the limit of knocing into it neigbors limit if that Quantum area was saturated with Aether. Which is not uncommon.
There are two states to the natural relaxed state of the Aether. Attraction state which is much closer to it's opposit monopole particle. The attraction is not enought to have close cohesion but much akin to a cars shock absorber. Just not a set outer limit since the Aether can travel faster then light when ejected from it's normal excited states. The other state is repulsion which has a normal relaxed position further then equalibrium to the repulsed particle. Aether particles are far from uniform in size and other partcles have bigger attraction the others. These bigger particles have the abilty to travel with streamer particles in tow, much like a comet from space has. And can stack in thread like cofigurations.
These particles can be compressed and have great effects from that compression because nothing resists this particle except for another particle of the same charge, which will only deflect it. These particles are the conduits of any phenomina we could think about in nature or even man made for that matter. Magnetism is completely explainable knowing that the magnet is a one way accelerator per side. The north side is actually the south attractor to these particles because they have a higher concentration of the north only Monopole on one side. When the magnet is made they heat them up or make the solution up and then energize the mixture aligning the perfect iron/colbalt configuration to make diode like funnels in the enriched aether layer in the material. The funnels are north in nature and the south particle is accelerated thru the funnels which are stacked in the magnets structure when cooled. These funnels accelerate the monopoles as they enter the funnel and even compress thier quantum boundries to a much higher speed.
The Aether is the conduit for magnetic reactions depending on the materials composition, which is either rich in Aether particles or deficient of a certain size of particles. The material being made up of billions upon billions of these Aether particles can have them knocked away from thier positions in the material, changing the charge in that material. Much like copper and a magnet. When the Aether strings drag thru the copper it collides with the other Aether present in that wire and knocks it out of place, which the copper becomes deficient at that time of the charge that got knocked out or sucked out by the Aether that cuts it. This takes some time to balance on it's own and holds the potential till a suitable Aether fills the hole.
Since everyone can agree that energy is never ever created nor destroyed we can also agree that within our great universe there sits a mass of these particles all moving and swaying, clumping repelling undulating forming bigger particles from larger masses of this. This constant state of movement is simply for the fact that we are hurdling thru space at a million miles an hour. This is what they estimate our galaxy arm is doing. That means these Aether are moving very fast like a great humongous stiring pot of soup. Hence why a magnet which attract and guide these particles and why it can hold onto a steel bar forever. Aether doesn't have resistance other then from colisions with other like polatiry particles but it does affect certain material in different ways. Depending on how many bigger particles are in it's composition depends on the effects of a passing strand of this Aether thru the material.
Help me to flesh this out guys. This is just what I think is going on based on my observation of both nature and our universe. This is by means not even close to being complete and I need some help with formating the ideas and correct ways to relate this to others. Any help would be apreciated and gladly accepted.
I do not want to start an arguement and would appreciate it if you kept the responses to the topic at hand.
Thank you for your help
I appologize for the spelling errors and will work on completing this later as I have to organize my thoughts. This should give you a little to think about and maybe help me out by asking me questions about this.
Thanks again
Thanks again
