Back,
When looking at any rociprecating engine it is not the fuel that actrually turns the crankshaft but the flywheel's abiltily to store recipercating motion that makes the crankshaft go round. Take off the flywheel and most likely you will snap the crankshaft in two.
When I hear someone that refuses to read or take the nessary classes so they can understand these things I hear the same old tired excuses. " Oh taking the needed class would take too long." That is the wrong answer to the question as time is not the issue but ones personal improvement is the issue. For after the time has passed the person that took the needed classes will have improved themselves and the person that refused to read and/or take the needed classes will be in the same place as if nothing ever happened to them, I call it stuck on stupid.
What is needed with all of this is a full understanding of chemistry, good physics and math skills. If you are lacking in any of these areas then please stop right now and take the needed classes to improve yourself, for time is not the issue but where you will be when that time comes around. Take a few engine concept classes, machine shop classes, strength & matireal classes, anything to improve your mind. This way everything becomes clear as you will understand why engines are built the way that they are.
One thing is clear though, the automotive industry doesn't want this technology, but why? Learn to first start off by following the money.
1. What happens if you invent something that cuts down the carbon build-up in an ICE buy 50% to the bottom line of the automotive industry's profits?
2. What about something that cuts carbon build-up by 100%?
Well, no carbon build up means the engine would loose the primary thing that causes them to breakdown. That would mean a big loss in maintenance revenues, some 35-60% of their bottom line. So now you know why hho adding and water for fuel technologies are not wanted by the automotive industries.
Now a lot of the people that rise up against me are ones that a suck in a perpetrio motion wheel of stupidity, in that they refuse to seek out self improvement so that they could start to understand the concepts found in this site. I have watched them fail time and time again only to repeat the same mistakes all over again. Then they give up only to return without ever improving themselves and make the same and even new mistakes all over again.
I ask people to strive for understanding but most refuse to leave their confort zones just ignore me. Anyway, engines have a lot of room for improvement, but you first have to fully understand them before you can make changes to them. The oval pistons is just one of many such improvements that could do the trick, look it up, and know it was band from racing due to the others where just so far behind that improvement.
h2opower.
h2opower.
