Tesla Air MHD Electrical Generation Device
  • #31
    Originally posted by Slovenia View Post
    Pretty wild indeed. Thanks for sharing it.
    Well if you are intrested, there are people thinking/hoping that the cropcircels are blueprints of many different things.
    One group even thinks they are al part of a space ship blue print.. And trying to built it:
    The Crop Circle Ship - Blueprints in the Crop Circles (video)
    • #32
      This is very interesting indeed.
      Thanks Cherryman.
      • #33
        Do you have any idea what Tesla intended to use the device for after looking at it?
        I don't know. But PAGD, which I think is very similar, reportedly output 4 times input and allow reduction/increase of things weight:
        • #34
          Replication?
          Originally posted by sucahyo View Post
          I only took it from the book mentioned:
          here
          Sucahyo,
          Is there enough information in the dropped Tesla patent drawing to replicate it? If so, I'd like to identify the parts and try to replicate it.
          Best Regards,
          Slovenia
          • #35
            Free Energy Surprise
            Slovenia,
            This device is the "Free Energy Surprise" circuit that Lyne talks
            about.
            Go here and join...
            freeenergysurprise : Free Energy Surprise
            In the files section are all the docs for free posted with authors permission.
            Maybe you could ask Bill Lyne if you can have permission to post them here.
            Anyway, the entire doc is there for everyone to download!
            RPX & MWO http://vril.io
            • #36
              Slovenia,
              about.
              Go here and join...
              Hi Aaron,
              Thanks for the information. I'll contact William Lynes and see if he'll allow us to post the pics here.
              Best Regards,
              David Fine
              • #37
                Free Energy Surprise | William Lyne
                Great, the Free Energy Surprise doc is about 16 pages, that would be the most important to post.
                • #38
                  If we use information from current replication of pulse glow discharge:
                  - Bruce A. Perreault suggested negatively charged lead in the middle and positively charged iron tube in air for readily available implementation. Or tungsten middle and semiconductor material outside. Use spark gap for pulse. Load is put on a step down transformer secondary.
                  - Correa's use side by side allumunium electrode in a vacuum. Self pulsing depend on various factor. Load is put on rectified output.
                  - Correa's use voltage more than 500 V but less than 1000V, maybe in the range of arc region of alumunium.
                  - Correa's tune the output frequency to gold graviton to reduce gold leaf weight.
                  - It is said that aether resonance frequency is 1.54X times the normal electricity resonant.
                  Good luck .
                  Go here and join...
                  Thanks for the info .
                  • #39
                    I think PAGD really is a Tesla MHD device. The effect seems to support it.
                    Paul & Alexandra Correa ~ Pulsed Abnormal Glow Discharges (PAGD)
                    The PAGD seems to have anti-gravity, COP>1 and conversion from radiant to conventional electricity.
                    HI Sucayho,
                    You ask that PAGD have also conversion from radiant to electricity.. what is the diagram referred to that? Regards
                    • #40
                      I believe this describes the gun part...
                      The New Art of Projecting Concentrated Non-dispersive Energy Through Natural Media
                      The one thing I have a problem with is that he was touting it as a weapon but had other uses like power generation.
                      • #41
                        Originally posted by tutanka View Post
                        HI Sucayho,
                        ORAC to one wire to AV plug:
                        • #42
                          Electrons Are The Connection..
                          Tesla use radiant energy name for protect what have understand.. Radiant energy = free electrons. HV capacitors are electron batteries and electrons are released in secondary load circuit. Isn't present voltage potential but only pure energy. Don't exist DC or AC field but ONLY pure energy. Tesla have found that, using high voltage at high frequency and capacitors you can have access to an next energy level.. pure energy current without voltage. Tesla have found also that for increase efficency is possible change arc discharge method and use high voltage/high frequency directly on molecules like air for obtain more free electrons. More free electrons more pure energy. You don't obtain any shock because in fact you obtain only an natural energy source. You can see that from Tesla Radiant Energy youtube video, you obtain two electron flow and you can summ these with an electric short circuit.
                          Hairpin circuit in fact is ONLY an electron loop!
                          Dr. Aspden have designed an special generator, no more different from Hairpin circuit, the main difference is that use tubes (and air) but you can replace DC power with AC every using high voltage and high frequency.. in all case you need to "tune" the tubes for obtain free electrons from air (and also Nox and Ozone) but you can use ONLY nitrogen and you can re-use that more and more times. Important thing.. you need NO EARTH in your circuit or your electrons go out from there.
