Under closed circuit conditions the amount of 'pressure' or voltage imbalance or potential difference, from all those imbalanced and unravelling fields in the supply source, is the greater. The zipons forge a path through the circuit components' fields and, in so doing, they orbit. You will recall that an orbit is simply a single justification in a circular path. By the time the zipons have returned to the negative terminal of the battery they are also able to present an alternate charge to the amalgam. They re-enter the amalgam and recombine those molecules and atoms but this time with a different justification or spin. They have done the particulate equivalent to two permanent magnets moving in space and in time to adjust the proximity of their various fixed charges or polarities.
At every 'recombination' of the atoms and molecules at the source, they also reduce the potential difference or voltage imbalance at the source. This then satisfies the innate requirement of all zipons to 'forge' or 'move towards' a state of balance. The atoms and molecules within the acid mix - is systematically varied until the experienced 'acid' condition of that bath, that first amalgam, is restructured to a more balanced less acid, or neutral condition. The zipons have simply used circuit components to move towards their required balanced distribution of charge. In this they have followed their innate and immutable imperative to establish a balanced charge condition in all amalgams.
This implies that their movement or current flow can only be enabled if there is first an experienced voltage imbalance. In other words, without that source voltage imbalance, no current flow would have been required and therefore no current flow would have been enabled.
