I know this isn't the right place for this but maybe I can convince you of the importance of this proposal.
If at one point in our history aka 10,000 years or so ago there was a great solar cataclysm. The suspected 13th planet expolded and caused a great imballance in our solar system. With that 13th planet gone from our solar system it would cause a greater pull on the closer planets to the sun. drawing them further into the suns pull.
I believe that there was a very advanced civilization on mars. The eveidence is clear on that if it wasn't altered to keep the secret. It would explain all the evidence we have been finding out about the indian poems that describe vitmas (flying machines) and the stories about great battles. Atlantis would also be explained as well.
Well to get back to my original proposal. If there was a 13th panet it would have made the suns pull alot less on the closer planets. That means that mars would have been further out from the sun allowing for an atmosphere and water that the sun puts out. All the ingredients one would need for life and sustaining life would be there. So we are up to the great movement in to the sun. This would eat up the atmosphere in a short time. Enough time to evacuate mars and find a more stable planet to setup a temporary base to gather what one would need to survive in space. Since all the planets wopuld have tipped towords the sun it would have caused the earth to tilt in causing the ice age. If one wanted to balance the earth what would you think would have been done to amplify the magnetic sphere of our planet out and make it stable to continue life. Pyramids are a magnetic(Aethric) amplifyier. Look at Tesla's discovery of cone shaped coils and you see where this is going.
The pyramids where set on the perfect magnetic lay lines. When completed they would amplify the natural magnetic field and thats why I suspect they were off a 1/4 inch twords the field they were to amplify. But there is a missing component the capacitors or focusers. I suspect they are hidden in the pyramids in chambers like Edgar Cayse descibes. Once setup they would boost the natural field that surrounds our planet leveling it off from the extreem angle they were now being pulled in by the sun and allowing them to return the planet to it's normal angle.
You ever wonder why they were so accurately built for the time. Well I propose they were not in fact made by a civilization that had neither the way to be that accurate nor the ability to get the materials to the destination. It was built by an advanced civilization and used to correct the effects of the loss of such a huge planet being snuffed out. The meteor that hit was a piece of the 13th planet and could not have caused such a degree of angle that would have caused the ice age.
If you take all the reports for all the ages one can see that there is a truth behind this. They called them sun gods and for a good reason I believe haramien was correct that they use the suns black hole as a conduit for travel. *edit mars is not closer but farther then us from the sun* They came from mars which is now closer to the sun. I think these sun gods came here in peace and wanted to only retool to go to another planet to let our own society grow naturally. Of course I believe that some of these sun gods left some of thier own here to try and help for our own help that we gave them. As usual the ones that stayed were corrupted by mans nature. That was due to them breeding with man. They became barbaric like we were at that time.
Even the bible can be explained knowing that the arc of the covenant was the powersource left by them. Moses took that which they (pharo's) were using to ensalve us. I truely believe that Jesus was from the original civilization to try and correct the corruption that resulted from the original contact. Trying to focus us so that we did not destroy ourselves in our growth cycle after the initial contact.
Thats why Jesus was way different then the god we tend to believe in. We created something to explain the magic we saw and was exposed to by thier attempt to collect resources and get off our planet. They wanted to remove thier presence and let our growth of our own society go its natural way.
I think they have always been here watching and trying to effect changes thru indirect ways preparing us for another solar event. The Mayan callendar shows us when this event is gonna happen and when they will be back to guide us into the next phase of our existance.
Nassim Haramien tells us this as he goes thru the history and points out the obsurdities of our explainations of everything that can not be explained without the knowledge that there was an advanced civilization on our earth. My proposal is just that except with a more detailed explaination of what has become the greates lie ever told. I believe we are being lied to everyday by the same organizations that have created them in the first place.
I checked on Nassims theories about who owns the statlites that monitor the sun. The vatican does in fact own them. WHY? Now the Vatican says it is ok to believe in ET's. WHY? Because they have always known something about this history. They knew they would be comming back. Why because another event is gonna happen and they wanted to pay us back for hosting them while they transitioned from the earth to space. I would also think that them monitoring us like they have been has shown them that there is a deception going on and they are willing to expose it because we have grown enough to understand that nothing is magical and have matured enough to be open.
If you think about what I have said you would know there are very unexplainable things recorded in our history that have no good explainantion of why they occured. All the examples point to a giving of a technology that wasn't understood. When it broke down we didn't have the knowledge to fix it. We forgot the technology and are now finding evidence to the fact that we had the technology in the distant past. It's all there to be looked at. All you need to do is listen to Nassim and let it guide you in your quest to find the real truth.
We should know in a few years but I wanted to show you what I have seen and others have seen as well. I am not asking you to believe me. What I am asking you to do is look at all we know and have available to us to see the truth of it all.
