My proposed explanation for the great pyramids.
  • The Great Pyramid
    Originally posted by Jbignes5 View Post
    and placing Larger then life stones in the age of 10,500 bc. This is the current estimate of the pyramids that is now accepted the world around.
    Who accepts this in mainstream academia? They have fought this for
    years and maintain the pyramid is about 4000 years old, which is beyond
    ridiculous. I find it hard to believe any of them on any serious level are
    openly discussing this much older date. What the Egyptians don't want
    is to admit that the builders of the pyramids were not their ancestors.
    I believe the pyramid is 12000-14000 years old seems like common sense
    when looking at just a few factors. Orion was rising above the horizon at
    a certain time of the year only back during that time frame of which the
    Giza complex is a mirror image of the Orion constellation. 3 pyramids are the
    belt and the sphinx is m42 or m43 (orion nebula location).
    Other complexes around the world correspond to mirror images of
    constellations in their part of the world that rose above the horizon at the
    same time of the year back during the exact same time period. I think
    the time of year was one of the solstices.
    All of these ancient civilizations were synchronized in duplicating the
    constellations in the layout of their complexes.
    That flying dome minaret vid could be a rope trick. In any case, acoustic
    levitation has been accomplished in the lab so it is not debatable whether
    or not objects can be levitated with sound. There are reports that the
    Tibetans have done this by surrounding rocks placed onto a platform that
    is shaped like a concave dish. They have musical instruments surrounding
    it and are able to levitate the rocks up to hundreds of feet in the air on
    top of a plateau. There is no video evidence of this, just the reports.
    RPX & MWO http://vril.io
    • The contractor that observed the pyramids at Giza was one of the very few who build skyscrapers in large metropolotan cities in the US. He is well versed in the construction of large buidings. He claimed it was not possible, with our current technology and machinery to construct a pyramid of that proportion with the size blocks that they contain. it was aired on Discovery last year. There was an entire episode dedicated to solving the mysteries of the pyramids. They only used the very best sources in their series. They used a scientist, construction contractor,geologist, and sonar unit operators to test several parameters of the stones for hardness,cutting methods, transportation methods, and labor required to build one. They claimed that even with our current machinery it would not be pheasible to build one in the 20 years claimed by the Egytians. Furthermore, it was decided that it was impracticle to get within a foot of precision in east-west, and north-south oreintation. Most skyscrapers are as much as two feet out of square. That is an acceptible measurement in that size of structure. Good Luck. Stealth
      • mortar
        Stealth,
        And the mortar used on the pyramids is superior to anything used in modern
        times. There was quite a bit of research into it and I don't recall if they ever
        were able to replicate its superior strength.
          I should have said it was more then acceptable with using the technique that i described.
          You could be entirely correct Aaron about the 12k-15k age as that is what I think is the real age. The sphinx is a lot less in age though seeing that it was built as a monument to the accomplished task. If they are right about the library underneath it it might be why it is younger.
          You are also correct in the alignment of the stars and when they should have built it. But the dates that the stars are lining up point to the date of 10,500 bc from what I understand. This is the only sticking point from using the star alignment method.
          I have also heard about the sound moving objects as well. You are quite right about that. The proof being hoarded away and hidden from us as well.
            Stealth,
            they weren't able to, nor can they replicate roman cements.
            on a side note, look at this picture, could it not be interpreted as evidence of giants? of course i am not suggesting that it is evidence of such, it is just a poor example of how someone can look at something hundreds or thousands of years later and misinterpret something entirely...
            • acoustics
              An interesting side note about acoustics, in some chambers in some of
              the "tombs" in South America, various sounds played in some of the
              chambers caused light - a type of sonoluminescence from the sound +
              geometry combination. This was about 10-15 years ago that I read an
              article on this.
              I think I read somewhere that there was some similar acoustic phenomena
              in the King's Chamber of the Great Pyramid.
                article on this.
                I wonder if that was from the crystal residue on the walls as you suggested? That would be an interesting experiment. Seeing that crystals produce vibration maybe the vibration is causing the crystals to manifest light.
                • I read somewhere that the angle of the great pyramid is 51 degrees 51 minutes and 51 seconds, this angle could only be found with an instrument with 3,600 points around a circle.
                  There is 360 degrees to a circle and in between each degree there is 60 minutes and between each minute there is 60 seconds.
                  Try and create a computer model of such a measuring device....you will not be able to see each separate dot even at 2400 dpi printing.
                  Now, consider how silly that would be to an ancient one, and we have no knowledge they had any such device.
                  So how did they find the angle? That was the question I asked myself years ago when I was setting out to build a scale model of the great pyramid to study its geometry. But I was stumped at first how to make this angle that accurately. Then a strange series of events happened, as always does when I ask questions of the infinite mind of the universe .I usually get answers, sometimes not right away, but years later.
                  I was sitting on the couch and I picked up a pocket calculator and do not know now what possessed me to start playing with the number 7, but did. I first entered into the display the number 1 then divided it by seven and the sum was 0.142857142857142857142857 I then wrote down that number. I then entered the number 2 and divided it by seven and the sum was .2857142857142857 then likewise 3 divided by 7 and the sum .42857142857142857...and that is when I took notice that the same sequence of numbers always came up and that sequence no mater where it started at ..each number in the sequence is always followed by its next in line, the basic sequence is broken down like this 14 28 57. Now when I look at the sequence like this if I add the first 2 numbers by itself or multiply by 2 IE 14 x 2 =28....28 is the next 2 digits in the sequence now 28 x 2 = 56...but 57 is the next number in the sequence not 56, in fact there are no 3's 6's or 9's in the sequence or 0's.
                  So this all entertained me for hours finding all the interesting things about dividing 7 into any number 7 will not divide into evenly...in fact any number that seven is not divisible by will have this sequence after it. The sequence just may start from the 1 or the 4 or the 2 or the 8 or the 5 or the 7 but will always be followed by the next number in that sequence.
                  type out in a text program the sequence for dividing 1 by 7 and 2 by 7 and 3 by 7 all the way up to 6 by 7 and place the numbers underneath each other and you will see more things most interesting. And you may ask...WHAT THE HECK DOES THIS HAVE TO DO WITH THE PYRAMID....I was wondering when you were going to ask....
                  After this 7 fetish of sorts it dawned on me that the angle of the pyramid was simply ONE SEVENTH of a CIRCLE...a great AH HA moment.
                  and when I checked my premonition I found I was correct...BUT using a 3600 point compass was imperfect.
                  So then I did the only logical thing, I made a compass divisible by 7...with like 350 points for instance, then the angle would simple be 50 degrees on that new drawn compass, you can see one of these compasses here in a jpg I will post.
                  Now i had a very accurate measuring reference drawn by Corel Draw that i could print at 2400 dpi and use to make my model perfect. And since I have master the art of Auto Body and fiberglass fab for same.. shapes could be ground using blocks to optical flat perfection.
                  Well one thing led to another in this discovery and I knew that all math and geometry for modern optics also came out from the Great Pyramid and I concluded that PI was also off based on the number we have been told is PI today. I re-adjusted PI to 3.142857142857 <<notice the sequence and I stop at the 12th digit in the sequence AFTER the decimal point, this is the TRUE number for PI and I have proven it to my own satisfaction and gave it to an mechanical engineer in Portland Oregon by the name of Jack Moody who held 300 patents and worked for the Cranstan Machinery Company which company makes large paper pulp machinery and sells it all over the world. Jack later asked me where and how I came up with this number as he went out in his fully equipped machine shop and told me he found it to be PERFECT for PI....in fact he NO LONGER uses a symbol on blueprints after a designated circumference measurement for any circle that puts the reader of a blueprint on notice that the number is just an approximation. Jack said he had received phone calls from all over the world as to why this symbol was missing and he told them because ITS NOT AN APPROXIMATION, that is the true circumference of that circle...so I guess you could say Jack was convinced.
                  This all took place back in the mid 1980's and to my knowledge I am the only one who has ever proposed this up to that time. I understand the significance of such a Statement...but yes I should be placed in History as one more person who has proposed an update on PI as there have been a few throughout History who have had it changed. But I would challenge anyone to prove the number faulty by practical use, they won't be able to.
                  So I believe in closing the ancients used a simple device to find the angle of the Great Pyramid they sought to build, they may have even used the stars, but that angle is simply one seventh of a circle.
                  Good Day...24!!!
                  • Pyramid
                    Interesting theory about Pi,anyway I will check it out later. I built a replica of the great pyramid of Giza about 10 years ago. I used it to experiment with to substantiate some claims I had heard some researchers had achieved. It was made of wood instead of stone, but I felt that the shape was the important issue, not the material it was made from. I made some interesting observations about the shape and or power that it seemed to posess. I made the bottom removeable for access to the inside. I placed different types of objects in it to evaluate any changes that occured. The only regret is taht I didn't put a window in it to observe any effects. It was as close to the actual degree measurements as I could get. A friend of mine was so intrigued by it, that he asked if he could take it and do some tests with it. I loaned it to him and never saw it again. I am in the process of gathering materials to build another, this time out of glass. Iwant to test it's ability as a power unit for solar electric generation. I will let you know what happens and post a picture when finished.Good Luck. Stealth
                    • Aaron and 1NRG24Seven, excellent posts! I would like to add to the both of them with a comment about sound and sacred math. First the sound... Solfeggio frequencies.
                      The Six Solfeggio Frequencies include:
                      UT – 396 Hz – Liberating Guilt and Fear
                      RE – 417 Hz – Undoing Situations and Facilitating Change
                      MI – 528 Hz – Transformation and Miracles (DNA Repair)
                      FA – 639 Hz – Connecting/Relationships
                      SOL – 741 Hz – Awakening Intuition
                      LA – 852 Hz – Returning to Spiritual Order
                      notice the numbers and a relation to 1NRG24Sevens post? And the math? Rodin-Aerodynamics.
                      The number is on the left, horizontal addition result is on the right. Notice how the 1,2,4,8,7,5 number pattern repeats indefinitely.
                      1 = 1
                      2 = 2
                      4 = 4
                      8 = 8
                      16 = 7
                      32 = 5
                      64 = 1
                      128 = 2
                      256 = 4
                      512 = 8
                      1,024 = 7
                      2,048 = 5
                      4,096 = 1
                      8,192 = 2
                      16,384 = 4
                      32,768 = 8
                      65,536 = 7
                      131,072 = 5
                      262,144 = 1
                      524,288 = 2
                      1,048,576 = 4
                      2,097,152 = 8
                      4,194,304 = 7
                      8,388,608 = 5
                      16,777,216 = 1
                      33,554,432 = 2
                      67,108,864 = 4
                      134,217,728 = 8
                      268,435,456 = 7
                      536,870,912 = 5
                      1,073,741,824 = 1
                      2,147,483,648 = 2
                      4,294,967,296 = 4
                      8,589,934,592 = 8
                      At this point some of you might be thinking, "What in the world do these number patterns have to do with real world applications?" These number groupings piece together into a jig-saw-like puzzle pattern that perfectly demonstrates the way energy flows. Our base-ten decimal system is not man made, rather it is created by this flow of energy. Amazingly, after twenty years of working with this symbol and collaborating with engineers and scientists, Marko discovered that the 1,2,4,8,7,5 was a doubling circuit for a very efficient electrical coil. There was still one more very important number pattern to be realized. On the MATHEMATICAL FINGER PRINT OF GOD notice how the 3, 9, and 6 is in red and does not connect at the base. That is because it is a vector. The 1,2,4,8,7,5 is the third dimension while the oscillation between the 3 and 6 demonstrates the fourth dimension, which is the higher dimensional magnetic field of an electrical coil. The 3, 9, and 6 always occur together with the 9 as the control. In fact, the Yin/Yang is not a duality but rather a trinary. This is because the 3 and 6 represent each side of the Yin/Yang and the 9 is the "S" curve between them. Everything is based on thirds. We think that the universe is based on dualities because we see the effects not the cause.
                      Forgotten In Time: The Ancient Solfeggio Frequencies
                      RodinAerodynamics.org - Marko Rodin - Rodin Coil
                      • Originally posted by HairBear View Post
                        Thank You Hair Bear...
                        I do believe that this number sequence is the key to literally everything, that is why I now incorporate it into anything and everything I build where ever and whenever possible. I am convinced that our 6 base system is flawed and has kept us in the dark somewhat and isn't it interesting that six is "HEX"...yes we have been HEXED by the six base of our thinking. Go back and add up the the 2 digits in what we are told is the angle of the great pyramid based on the 6 (HEX) system ...IE 51 deg 51 minutes and 51 seconds....5+1=6.....so it follows 666, no wonder the NWO illumanati crowd loves to take credit for the Great Pyramid symbol on the reverse side of a USA dollar bill, and also notice the Star of David pattern in the stars and the repeating number 13 in the symbol. The great pyramid covers 13 square acres at its base. Is the number 13 bad....no I do not believe in superstitions. You might take note there were 12 disciples Christ being the 13th. But my point here is we are stuck thinking we need to use a six based 360 degree circle....look at the pic i posted for the 350 degree circle again, and notice I placed other colors so you can see each color group brakes the circle at 7/14/21/28 and so forth segments. Now cut the circle like a pie into seven equal sections and notice no leg of the seven has an opposite leg...but two legs opposite the one....this creates a better wheel using seven spokes instead of six...now what about coil placement around an electric motor, if we used 7 instead of 6 or 8 or even 14 instead of twelve I believe we will tap into the best frequencies for zero point, but have not proven that to myself yet, hope somebody tries it using seven coils.
                        Anyway that is all for now....Good Day 24!!!!
                          Thanx for the sound frequencies numbers....think I could program them into my fully digital synth keyboard and play them.
                          I heard that old church hymns were changed and that middle C was changed in its frequency to stop the manifestation of spiritual activity when certain chords were played for extended periods or measures as we call them in music. they in essence detuned the perfect harmonics for our music. This would have an effect on us biologically too as all things are connected to frequency. I do not recall now what middle C used to be and what it is now...but it was off now by like 4 ticks down I think if I recall correctly...so if it was 444hz its now 440...just as an example...24
                          • natural pi 22/7
                            Very nice! I took almost the same path 15 years ago when I was deep into
                            the numbers. Your number look identical to what I came up with.
                            The final conclusion I came to was ancient "pi" was based on 22/7. I was
                            looking at the intuitive relationships between the shapes/geometries, etc...
                            Try it... 22/7. I called it "natural pi" and only shared it with some of my
                            close friends.
                            I have tons of notes on this in storage - I don't recall all the details, but
                            I "reinvented" the calender and time system, pi and about everything else
                            that went into the Great Pyramid and then some. That was a strange time
                            but the number you came to is the only time I have seen anyone post
                            this online.
                            • frequencies
                              Ravi posted something very extensive relating to this. I wasn't very
                              familiar with it but his document is somewhere in this forum.
                              Jbigness, if this is going too far off track let us know.
                                close friends.
                                this online.
                                HA!~ Aaron...ok...what I first did to do a simple proof to myself this was Pi I printed out a perfect 7 inch circle on 8.5 x 11 paper and spray mounted it to a piece of aluminum plate to cut out. I then used different means to ensure the disk was as accurate as possible @ 7 inches across when finished...I then had a circle to measure around. If I take 7 x 3.142857142857 that = 21.99999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 999999999999999999999999999999999999999999999...an d you get the picture....so the nines never end....
                                NOW consider if you would with me for a moment if you could get to the end of the nines and at some point they ended...could you tell me what would happen if I added a .000000000000...1 at the end of that number what would happen?...well the sum would be 22...or 22" circumference. Also consider trying to measure the size in subatomic particle size of that .000000000000000.........1 at the end of the nines.....it would be so insignificant and small that we could not even comprehend it....so for all intents and purposes 22" is the exact circumference of a 7 inch circle...or if you made a 7centimeter circle...22 centimeters would be its circumference, and it works with any system.
                                Therefor what I was looking for is a confirmation of this in physically measuring my exactly made seven inch disk...and no mater what method i used it was 22". So I find it interesting you brought up that ratio Aaron.
                                24
                                Last edited by 1NRG24Seven; 03-23-2010, 03:00 AM. Reason: tried to correct typos that no longer exist here but do when I post it...go figure
