The key to ALL these things EVERYONE is trying to do is Flux Compression!!!!!
I've been trying to figure out exactly what's happening with all these circuits that use split secondaries wound in opposite directions and center tapped....
I found out those type of transformers are called Differential Transformers. The output of both ends of the secondary is of equal magnitude and equal direction.....Splitting the Positive
The center tap is ground...
If you look at Bearden's MEG, he shows the waveform that is the resulant output of the thing....Just AFTER a reversal past the zero point in the sign wave is the Unidirectional transfer of current. There's an other patent I saw that incorporated this same thing to do electrolysis, but with archaic switching.
Basically you create two opposing currents that are both equal and balance to each other, so that when the input is at high amplitude nothing is transfered. When the ZERO POINT is reached on the input wave, the balanced bucking is debalanced and biased in one direction, resulting in the transer of energy unidirectinally.
This way all potential is retained by the pickup form the source, and no energy is transfered. Once the input reaches equalibrium and momentarilly stops affecting the secondary, the potential is manifested into kinetic.
These transformers can also be used to modulate and demodulate a carrier signal
