Core Proximity
Hi Joit,
Thank you for that video - I am like that too, I have the equipment and even a measure of time but no ambition to do the experiments
I see now, what you were saying regarding the induction of two coils - I think
If I understand correctly, the top coil is driven externally by a voltage, and the 'in house made' lower coil is the pick-up coil being monitored by the scope. So as the magnet-core changes position, we get different results for the induction through that core.
One thing that is readily seen, is that when the flux of the magnet-core is perpendicular to the flux of the driven coil, there is a material advantage in that the core extends further into both coils by half of their radius rather than half of their thickness. So from a core perspective, the magnet is better than the air and acts as a better pathway for induction.
We also have the consideration as to what causes induction. It is a change in flux. When the core is parallel so that its magnetized flux is in line with that of the driven coil, we must provide enough driven flux to cause a coercion in the magnet (either to increase it's magnetization or demagnetize it) before a change is observed in the pickup coil. This is because in this configuration, the magnet flux is a relatively uniform circle matching the coil windings and it requires a great deal of energy to create a change in more domains. In other words, in this position we have to change the magnetization of the core to influence the surrounding coil.
But when we turn the core 90°, we have a different situation. Now the two flux fields are not joined up or directly opposing. Instead, we are moving the flux sideways in half of the coil and lengthways in the other half. So we are pushing the magnet flux back and forth like branches in the wind and the coil sees a greater change than before. Even though half of it is no real change, the net differences are much greater than the other configuration.
If we wrap a tube with a single coil and drop a magnet down that tube, which will produce the greater energy? Dropping the magnet with the B lengthwise with the tube, or with the B crossing the tube? That would be an interesting experiment.
What if a steel ball had 6 or 8 magnets stuck to it with N all facing out, and it was dropped down the tube?
Hi Joit,
