The theory behind the Hidro invented by James Kwok?
http://www.energeticforum.com/renewa...tml#post137659
Since Mr. James Kwok is also Chinese, I paid special attention to his invention. The first post is in reply 18 of the above mentioned thread. This is the second post.
One question the average person may ask is:
Does the James Kwok Hidro use gravitational energy? Is it a form of unbalanced wheel?
My answer is NO. The reasons are:
1. If he uses gravitational energy from the falling submarine container, that will be very limited. The maximum energy is governed by the formula “potential energy = mgh” where m is mass of the container, g is the gravitational constant and h is the height. This submarine container does not fall in vacuum. It falls inside a water column. The downward force will be opposed by the buoyancy (= volume x density of water x g) and the water resistance. He has to bring up another submarine container at the same time with that limited force.
2. If he uses energy from air (formula in reply 18), he can control the speed of ascent of the submarine container. He does not need to rely on the buoyancy alone. He can jet out some of the water + Air in the submarine container. That will give a very high upward force. He is effectively firing a torpedo! That force is much higher than what step 1 can possibly provide.
3. Most people (even scientists) may mistakenly think that the energy supplied to compress the air is the total Input Energy. They are mistaken. Air is not a fuel but an Energy Carrier. The total Input Energy should be the sum of the Epump + Eair. Epump is the energy supplied. Ein is the Energy carried into the submarine container by air.
4. For a 100% efficient system Eout should be equal to Epump +Ein. Ein is FREE. It is the bring-in air energy. It is the energy freely from the environment mentioned in the last sentence of the brief description.
5. James Kwok can control the output power by adjusting the “torpedo jet valve”; the actual pressure of the compressed air; and the ratio of water and air in the rising submarine container. Salute to him and his team’s brilliant engineering.
6. In other words, Mr. James Kwok is using the energy from still air. Air is constantly flowing in and out of his Hidro device. That device cannot be a CLOSED system. Energy is carried by the forced flowing air. The device will run cold. This can easily be checked by measuring the temperature of the air around the top of the tower.
This is my analysis. Others are welcome to put forward their analysis. The World will learn better and faster with such scientific input.
More servers are coming. Amen.
