While researching browns gas and the "Fast Freddy" cell design, I came across Tom Beardens paper on Atomic Hydrogen:
THE ATOMIC HYDROGEN REACTION
So much to my surprise, if one takes H2 gas and pipe it through and electric arc it will absorb 100X the energy from the "vacuum", according to Tom Bearden, or from the "ether" according to Tesla.
- Maybe the same effect could occur with corona discharge?
- Maybe HHO gas can power an engine if first going through an electric arc or electric field first to absorb the ether energy?
Cheers, Mike R.
Quote from William Lyne's book "Occult Ether Physics"
Page 84:
![](http://www.cheniere.org/images/Image12.jpg)
"Langmuir (1912) discovered that hydrogen at low pressure in contact with a tungsten wire heated by an electric current is dissociated to some extent into atoms:"...."This absorbs a large amount of energy, about 100 kcal. Per gram-molecule. " "... The atomic hydrogen formed is chemically very active. Atomic hydorgen is formed when an electric arc between tungsten electrodes is allowed to burn in hydrogen at atmospheric pressures"
"Hydrogen molecule dissociate to atoms endothermically at high temperatures (heat of dissociation about 103 cal/gram mole) in an electric arc, or by irradiation." "...the hydrogen atoms recombine at the metal surface to provide heat required for welding."
"The older text showed the clearer construction of a device, and the newer text showed that only 103 cal./gram mole were required for dissociation, while the older text showed that 100,000 cal./gram mole were liberated on recombination. Only by jumping back and forth between the two sources was I able to put a complete documentation together, and discover the conflicts."
Page 84:
Cheers, Mike R.
