Dear All,
Please see my drawing in the attachment.
The idea to create an excess energy. Not sure if this theory are work.
Example ;
• Big Cylinder Diameter 4 Inch
• Small Cylinder Diameter 2 Inch
• Shaft Diameter 1 Inch
• Pump Pressure 1000 PSI
When Piston reach top stroke, pressure will raise on Pilot Port A and pilot control (not shown) will joint Cylinder port A and Cyl Port B. This action will increase pressure on big cylinder and same time reduce pressure on small cylinder to equal pressure (if my formula are correct, with 4” stroke length the pressure will be 133 PSI). The load (estimate 1 Tone) will push down by gravity and pressure on big cylinder will also push down in other word the force of down stroke much bigger than the load (about 1500kg).
When all piston down completely, the pressure will increase on Pilot port B and then pilot control will connect the Cylinder Port B to “Pump” and at same time connect Cylinder Port A to Tank. So the Piston will lift up until next step and so on.
Please comment.......
Selamatg
Example ;
Selamatg
