Combining radiant output, 0.2 + 0.2 = 1.5
  • #31
    I don't know if this can be used to measure performance, full CFL brightness at 3 watt:
    YouTube - 3 watt CFL ligther with sting oscillator
    • #32
      I don't know how high the voltmeters can go though there is no way I'm running this without a load! It has already blown two MJL21194 transistors and they aren't cheap!
      Nikola Tesla
      • #33
        Yes, I understand the risk, I understand if you don't try it. My curiosity cost me 5 computer fan ...
        I found that the PNP is the most vulnerable part in my circuit. I think MOSFET would fry instantly without load.
        This circuit teach me that 240V part of a transformer is not 240V anymore in radiant oscillator, it would have high enough voltage to make spark gap. If the 9V primary have >2000V then the 240V part would surely more than 240V .
        • #34
          Sucayo, if you want a reliable consistent means of measuring the CFL output, in terms of brightness, you should go to a local hydroponics store and buy one of the $10-20 light meters. Then you just set the sensor in a fixed spot and assess the normal output level vs. the levels that you modify with your circuit.
          • #35
            Just to let you know, Imageshak dumped your upload due to violation of terms it seems.
            thay
            • #36
              Thanks, I can not afford that. Besides I doubt it is available in Surabaya.
              Here is comparison of ceiling light with CFL.
              YouTube - Previous 3watt CFL brightness comparison
              I notice that at lower frequency, the light is more violet. At resonance it flicker at brighter than ceiling. Same brightness appear before resonance frequency.
              thay
              Thanks, I delete it since I think it is unimportant, it only work with 1 capacitor FWBR too.
              • #37
                Accidentaly found booster
                Booster circuit increase efficiency:
                YouTube - Boosted sting oscillator
                Unfortunately, the circuit is a mess. I will post the circuit when I can identify which part of the circuit actually part of the booster.
                • #38
                  Booster circuit test
                  Input power:
                  without booster = 0.95A@11.5V = 10.925 watt
                  with booster = 1.26A@11.5V = 14.49 watt
                  Output power
                  without booster = 0.31A@10.8V = 3.348 watt
                  with booster = 0.64A@10.8V = 6.912 watt
                  Efficiency:
                  without booster = 0.31A@10.8V = 30%
                  with booster = 0.64A@10.8V = 47%
                  YouTube - Booster circuit test
                  • #39
                    61.9 % efficiency ...
                    YouTube - Boost circuit with lighbulb COP = 0.62
                    Input is 1.14A at 11.57, output is 1.03A at 8V.
                    my 61.9% vs Sepiroth's 62.4% , very close .
                    Charging almost full broken (10V) battery result in 57% efficiency.
                    • #40
                      Just you wait till I get those transistors replaced
                      looking good
                      Nikola Tesla
                      • #41
                        looking good
                        Something better than MJL? wow.
                        How about diode? Have you ever compare diode? not from spec but from bench / output current test?
                        BTW, here is a picture of my 3 watt sting oscillator :
                        • #42
                          A Big thumbs up
                          Hi sucahyo.
                          A Big thumbs up I've not had the time to try any of your work yet.But I have been reading and watching. Thank you .Tec
                          • #43
                            thanks
                            thanks for sharing sucahyo, with picture looks simple!
                            just a question for you, do you know what is the complementary PNP transistor of your KSC5027? a need too pass high current and voltage true my circuit! but the transistor must be PNP,
                            hugs
                            • #44
                              Thanks tecs and Juju .
                              I don't think you need to use KSC5027. MJL29114/MJL29113 is much better. However, just to see if the circuit can work with cheap transistor, I will make the TIP31C + TIP32C one and see how it compare with the KSC5027 one.
                              Important:
                              Nvisser notify me that the PNP leg I post in diagram is wrong.
                              I will post the correct circuit right away.
                              • #45
                                Revised circuit
                                This is the correct diagram for my circuit. This one use cheap TIP31C & TIP32C, 200mA at 10V version.
