My goal with this idea is to create an oscillation circuit which:
-runs from a DC potential (battery, caps.....)
-creates a field in an inductor on the on pulse
-on the off pulse the field collapses and sends the charge back to the source
-there is NO current link between poles of the source of potential, only voltage link (capacitive coupling between + and - poles)
-inductor may have secondary on it for power take off
-to sum it up: (do work with only potential, never depleting the source)
here's a diagram of one way I thought of doing it:
[ATTACH]5426[/ATTACH]
the transistor would be an NPN reverse biased for an avalanche breakdown switch. obviously there could be some resistors in there, but i showed my basic idea without any specific components. this may be a poor design, but with a proper oscillation created on the + side of the source, I think you'll get what I'm trying to do.
maybe a load could be placed on the primary circuit, maybe it should be on a secondary.
what if you put a ground on the - side of the battery, maybe with a diode pointing to ground, so if electrons are somehow used up during the process, more can be introduced to replenish it?
