this wave is what heat and all EM spectra travel on. if 2 candles are placed 180 degrees apart on a disc, the flames point towards the center of axis, away from the artificial gravity created by spinning. an energized PMH [leedskalnin] is spun,and artificial gravity over 1G will push the orbit of force out and since magnetic current flows to metal , dense metal like gold held at plane,now this force streams off bending light like a heat wave!...i will post a video as soon as i can. i have unlocked the mystery! check this out..if you hold a metal weight over the center of mass, its weight increases! this model works...more soon. p.s. i do have the only working model, i need to share this with the world!
gravity waves found
Originally posted by david lambright View Postthis wave is what heat and all EM spectra travel on. if 2 candles are placed 180 degrees apart on a disc, the flames point towards the center of axis, away from the artificial gravity created by spinning. an energized PMH [leedskalnin] is spun,and artificial gravity over 1G will push the orbit of force out and since magnetic current flows to metal , dense metal like gold held at plane,now this force streams off bending light like a heat wave!...i will post a video as soon as i can. i have unlocked the mystery! check this out..if you hold a metal weight over the center of mass, its weight increases! this model works...more soon. p.s. i do have the only working model, i need to share this with the world!to the Energeticforum David! Looking forward to seeing what you have to show.
Sounds intriguing.
i figured out leedskalnins generator
i figured out leedskalnins generator ,but i can not get the video posted!..any way check this out- when i aim my laser at the device,from 10 feet away, i can feel a force pushing back !! in the video i will show that this force can be seen and it is distorting light like a heat wave..you will see it too as soon as i figure out how to get this video posted...tonight hopefully.
Originally posted by david lambright View Posti figured out leedskalnins generator ,but i can not get the video posted!..any way check this out- when i aim my laser at the device,from 10 feet away, i can feel a force pushing back !! in the video i will show that this force can be seen and it is distorting light like a heat wave..you will see it too as soon as i figure out how to get this video posted...tonight hopefully.
you can post at Home - EnergeticTube.com*-* Where technology goes LIVE!, i never got Problems there,
but maybe you use a *flv format, not sure if mpeg works.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
If you need any help posting the video people here can help. Let us know what programs you have and formats you are using. I'm sure everyone here is interested in what you have described, sounds very intriguing. Sounds like your device can focus chi energy..
Uploading videos to youtube-
Uploading Videos - YouTube Help
Youtube tricks-
10 Youtube URL Tricks You Should Know About
Originally posted by david lambright View Post...if 2 candles are placed 180 degrees apart on a disc...
disc diameter
distance between candles
is the disc spinning?
at how many rpm?
are the candles directly fasten onto the disc?
which material is the disc made of?
thank you
amir shah
Doesn't the spinning flames leaning in simply demonstrate that artificial gravity produces the same effects as mass gravity? After all, heat rises only because cooler air sinks in a gravitational field. IIRC, growing plants exhibit the same response. So it does not surprise me that the new vector produced by two gravities, (natural and artificial) pulling in different directions, would result in the leaning nature of the plants and flames.
A couple of years ago I posted this video called the Plasma Puzzle where cold plasma leans away from gravity where convection is not involved. This experiment was hard to produce because it required a specific spiral vortex in the stream to demonstrate the effect. That particular device was returned because the plastic overcoat peeled off and the new one does not give that tight spiral. I'm sure there are enough of these out there that others can duplicate the experiment.
So I agree that there is some interaction between EM radiation and Gravity that begs an explanation.
gravity waves found
here is the link..http://www.youtube.com/watch?v=rGNY0yJBmds...i know ...i am making another video as we speak..more soonest
david lambright
