gravity waves found
  • hi...
    Originally posted by sucahyo View Post
    I come accross thread where what create aura can change the way an ice forms. Maybe we can use ice to see the PMH effect?
    David, if you do not add space after the link, the link won't work.
    sucahyo, thanks....have you or anyone else seen any photos of what Tesla and Crookes were seeing?....i know that i have had a difficult time trying to capture what i see .....is there more on the ice and auroras?...david
    • Hi all.
      I typed this yesterday but accidently deleted it.
      @Jedijs, My magnets come from a guy I met who was building a model T ford.
      The first layer of magnets sticks to the metal base of my wheel and the second layer sticks to the top ring of the wheel but not to the first layer of magnets. So 1/2 the magnet flux goes down and 1/2 goes up....more or less.
      Imagine this dotted line as the top metal ring.
      NN^^SS^^NN^^SS^^NN
      NNvvvSSvvNNvvvSSvvvNN
      You can see where the flux goes as shown above.
      @Harvey, I"m not sure why the clover leaf is there but it could have something to do with the flux going up and down?
      I'll have to wait until I get more layers on to test things out.
      To charge my magnets I now use a setup similar to the drawing you posted.
      In the attatched pic you can see my charging setup and some other bits and pieces...a brass ring and my aluminum pmh. (which is solid cast, not a seperate keeper.)
      Cheers.
      • hi...
        here is another link to Hutchinson, and visual distortions during levitation of objects Hutchison effect & UFOs i am on the hunt!...david
        • Can someone point me where to buy those V magnets for fort T model? As far as I know those are ALNICO. Harvey posted a link long time ago, but I am not sure if you can really buy magnets there because they only send you recharged magnets if you send them your used ones back. I don't even have used ones.
          Jetijs
          • YouTube - Secret to Coral Castle and Pyramids AntiGavrity - SHARE BEFORE REMOVED FROM YOUTUBE!
            informative video about the Leedskalin device.
            • V magnets
              Hey Jedijs, You will have to find people who work on vintage cars.
              The guy I found knew another guy who had a shed on a farm...yada yada....and that's how I got all mine.
              There was some for sale on E-bay last year. Someone was selling the whole replica of Ed's wheel!
              I suppose it's a matter of luck, but they are out there.
              Scotty.
              • @ Cherryman
                Very interesting video. Hope will remain there for a couple of days. Could be a very possible theoretical explanation. David should be the first who can test this, cause he already has the device running.
                sadang
                • Hi all
                  @ Sucayo
                  the PMH in ice is a very good idea
                  and here the result in pix.
                  I placed my PMH charged in a small and long plastic container with some tap water. And put all in the freezer.
                  2 hours later very interesting result.
                  It seems there is a vortex ring around each pole. The vortex are mixing in the midlle of the PMH and are pushing the ice higher than it should be normally. The vortex effect is also visible on each side of the PMH. so in pix 2 and4 you see the 3 waves. A big one in the middle and two smaller on each side. On pix 3 you see the vortex from above.
                  On pix 1 i have pushed the contrast to better see the cut view of the vortex ring (so far it is vortex ?)
                  just my 2 cents
                  good luck at all
                  Laurent
                  • Woopy,
                    If you have a colloidal silver maker, use distilled water to make the colloidal silver using the hot water method. Boil you water and then put it in a glass container where you produce your colloidal silver. No salt needed. Then freeze it. Should turn out clearer.
                    IndianaBoys
                    • @ the Icemakers
                      It's hard to get a neutral starting point with water.. Don't forget that you're thoughts or surroundings can influence the ice-structure as well, at least.. according to Dr. Emoto.
                      YouTube - Water, Consciousness & Intent: Dr. Masaru Emoto
                      • Originally posted by Cherryman View Post
                        Briliant! I already had something similar in my mind about how the magnetic currents travel in Leedskalnins wheel. Good to see something that confirms that.
                        Thanks!
                        • Colloidal Gold Frozen Ice Cube from 2008 project:
                          Picture does not do justice as to how fine a detail there is.
                          IndianaBoys
                          • indiana........FINE work !!!
                            can you do a control sample.....the same technique.....but using something innocent.....umm......i dunno what to suggest........a leaf maybe?
                            • i watched the emoto video ( strange his name is Emoto......Emote? )...but anyways.,,......i had to laugh at the "mother teresa" one....(Not many people know what a callous, heartless, money grabbing biotch she was )......hence........my laughter at the pretty pattern produced from the "Mother Teresa" pattern
                              • Originally posted by woopy View Post
                                Interesting .
                                Can you do it with higher level? Because I think water show something similar to iron powder on magnet although it work not just on magnetism.
                                Can you take the picture of ice in front of ambient light or dark background? the first one show it better.
                                See if you can notice air bubble, you may need to increase water level for this. My camera do not have zoom so I can not show it clearly but the bubble is near the top part but bellow many small double helix air column:
                                Cool . Is that without anything else that produce energy?
