gravity waves found
  • Here's a video of my replication of the Baker's Device, YouTube - Baker's device
    I used the nylon fibers found inside a CAT 5 cable. All I need to do now is to add a mirror to the nylon string to reflect the laser light, then seal it up so there are no air currents to affect the experiments. I also need 4 ring magnets so the combined forces of the earth's magnetic field and those of the doughnut magnets almost cancel each other out so it will rotate quite freely and be the most sensitive. This setup detected a magnet from 4 feet away without the nulling magnets in place. It didn't take very long to assemble this apparatus and it was easy to build.
    GB
    • Hi all
      next experiments and results
      1- the pmh in epoxy resine. No assymetry at all. The resine polymerises completely flat,pix 1
      2- i put a neomagnet at both ends of the U bar but i did not energised the pmh
      pix 3 shows the icing . There are deformation in the center, but few assymetry. And almost no tunnel effect. And the neo mag are much stronger than the energised pmh.
      3- i redo the previous test exactly same config (same matos at the same freezer and same orientation) but without the magnets and pmh energised.
      pix 4 shows the strong assymetry in the icing. And the nice circular tunnel effect.
      4- my daughter who is osteopathe and kynesiologue. put her hands arround the pmh, and she could feel the strong and assymetrical ernergy . Than she tested the pmh with neomagnet and not energised and no feeling .She than tested with a pendulum and it is amazing to feel that the pendulum try to avoid the proximity of the pmh. Than i showed her the pix 4 and she immediately said " it makes me think to a yin and yang design"
      OK,as i am not at all specialist of those kind of energy, i don't know what is going on here but surely something interesting.
      For info i tried to test the pmh by placing coils all arround and check with the scope, but no measurable results. Any idea how to test with the scope ?
      good luck at all
      Laurent
      • hi...
        jet, did your mail come yet?...when you get the device, it is charged and working...please show as many people as would be interested in this type of thing!.....harvey, do you get any "compression" in your viewfinder?...at mikes house#3, what i saw on the viewfinder was the same as the video...shutter artifacting?...your replication is fantastic! you are doing everything i was doing....testing it every which way, your compass readings are similar, your device must be radiating....how many people have seen this replication?.....with the device spinning, have you held a piece of quartz near it....this usually helps it to be viewed easier....show this to others and see if anyone sees this effect....it is there, just very, very subtle.....your device is obviously charged exactly as mine...the effect must be present?...david
        • David, nothing in the mail yet. I will inform you as soon as I get the ring
          Jetijs
          • Hi Dave,
            Thank you for your kind words
            I tried the flame and smoke stuff - but I think it was too dark to see the smoke and the flame had too much air resistance so the inertial gravity was not too evident. The flame was useful in showing the side draft coming away from the elements while it was spinning though.
            There is also a section in the video that shows me recharging the PMH - I noticed on playback, that while I was busy getting the battery positioned, there was a lot of 'pixelation' going on in the still shot (still in the since that nothing was moving, but the camera was rolling). This is as close as I have been to seeing anything wavy - and unfortunately, it can be explained away as video compression algorithms.
            When I am finally able to detect the emissions I will be sure to find a way to record them for everyone.
            I have borrowed my son's HD camera today. It is a Cannon VIXIA HFM31 HD CMOS - the same one I filmed the Mock-Up with. I plan on doing some sunlight shots today as well. The weather has cleared up a bit - so I may also try Jet's suggestion tonight and see what happens. (I'll check the convective reports first to ensure there are no coincidences)
            Flame - Smoke and PMH Recharge:
            YouTube - Lambright - 012
            This Video is a Strobe Video: WARNING! Strobe Lighting can trigger unwanted physical reactions in some persons. You may wish to advance to 4 minutes where I finally synchronize the flash rate with the shutter.
            YouTube - Lambright - 013 - WARNING!!! CONTAINS STROBE LIGHT
            Cheers!
            • Also - another thing I was thinking:
              I wonder what type of ice crystal will form if I freeze a bottle of water in the middle of the PMH - I may try that too
              • hi...
                jesus at OU got his device today!....he is still testing.....i sure hope he can detect SOMETHING.....david
                • hi woopy!
                  Originally posted by woopy View Post
                  Hi all
                  some more pix of this afternoon test
                  i do not see any influence of air movement in my different freezer
                  and any
                  way my question is the same
                  what is this ring of air all arround the basis of the pmh
                  the 3 pix shows the evolution during the freezing process.
                  1 after 1 hour all is frozen apart one specific part (dark zone)
                  2 after 2 hours all is frozen and the dark zone is now elevated , (higher than the rest of the surface)
                  3 and you can see in pix 3 the circular tunel of air surrounding almost all the contour (see the red arrows)
                  please consider this as an important question as to solve the leedskalnin beautifull energy solution
                  thank's
                  good night at all
                  Laurent
                  excellent work...i think you are correct! very interesting stuff, i am sure Ed would like this!...where is the air tunnel coming from?..so what i am going to do is freeze one of my oxide core PMH devices and see what happens...my oxide core device puts out a good deal more radiation than steel so i predict more of an effect...[i have not attempted this yet], so we will see what happens....i must go to portland to deliver blood to the red cross, [blood shuttle], and possibly help save a life!...i will be back tonight....david
                  • Hi David and Harvey
                    Yes i think you both should try the icing test on your device.
                    Today i made lot of icing test with very impressive results.
                    I will do an analisis of the results tomorrow and report what seems to be of importance.
                    Just for info it seems that the tunnel effect is not circular but more 2 separate tunnels on both N and S pole of the pmh. Perhaps very near as what Ed pictures on his book cover. But i need more test to be sure and understand what is going on.
                    But anyway fantastic thread here, and also at OU.
                    Bravo at all and good luck
                    Laurent
                    • woopy...
                      again, great work!....i believe that what you have done is nothing short of fantastic...i am icing my oxide core device right now so when i get home[blood run], i will post again then.....one more time, great work woopy!...PS, do you mind if i post some of your test results at OU?....david
                      • hi everyone...
                        i took my device out of the freezer and all around the tube were these radial "lines"....no bubble tube....i put it back in the freezer for now..,..i will post more later...david
                        • Hi David
                          Of course you can no problem.
                          Here some more tests
                          What is difficult with icing is that the freezer may have some magnetic surrounding which gives different results.
                          But what i can say is that the pmh effect is very clear in the ice.
                          i have enclose some pix
                          pix 1 is a small pmh deep in water see the stratifications. But as i say before, the stratification works better in one of my freezer and is not so clear in another one), So i am not sure that those strat are due to the pmh.
                          pix 2 is a bigger pmh also in deep water but the container is more flat. See the impressive assymetry.
                          pix 3 is a test with a pmh at 3 basis. Seems not so strong as the U shape.
                          pix 4 and 5 is a pmh lying. See the strong assymetry but this time also under the basis, Very interesting.
                          I am now icing 2 different pmh on the side.
                          Yes the icing shows very well what is going on.
                          Hopes this helps.
                          Good luck at all
                          Laurent
                          • Hi all
                            other test results on pmh icing
                            pix 1 and 2 show the pmh standing with a long bolt as basis
                            see the assymetry, and the air tunnel (probably almost 2 assymetrical opposed air tunnels ) developping arround the complete system.
                            This assymetry have to be further researched and i think that the air tunnel energy develops all arround the device. (please see all my previous post and make you a picture)
                            Pix 3 is the previous pmh next to another pmh with round tubing (seems to be far less efficient at the present)
                            OK so far some ideas , it seems your are somehow sleeping here !!
                            please dear friends don't be shy to try all those icing. we all have to learn, and this stuff is really great.
                            good luck at all
                            Laurent
                            • Zoom
                              Exposed Metals Freezer Bagged To Keep From Contaminating Food
                              Zoom
                              Pyrex Dish With Masking Tape Label Beneath
                              Zoom
                              Label Under Glass - Writing is on the Adhesive Side
                              Just some kind words for the Ice to grown on
                              Zoom
                              Using Distilled Water
                              Zoom
                              Filled with Water - Ready to Freeze
                              Zoom
                              After a few hours - Crust formation shows air flow depression
                              Zoom
                              Side View shows Attempted Dendrite Formations (Glass Fogs fast- sorry)
                              Hi Definition Movies:
                              Surprise Ending:
                              YouTube - Lambright - 014
                              Failed Attempts at Rolling Shutter Illusion:
                              YouTube - Lambright - 015
                              • Hi all.
                                I can't see anything in the ice pics , but I would suggest to freeze your PMH's with the N pole prong East and S pole prong West...if possible.
                                I've put together a ring of Vee magnets in a NS..NS fashion, but I haven't noticed anything with it yet.
