gravity waves found
  • video
    YouTube - OC device in IR light and YouTube - lambrights oxide core device ....david
    • Originally posted by david lambright View Post
      Hi David,
      I see a reflective curved pipe back there up against the wall behind the 2x4 posts - that is the secondary focus point.
      But the other two reflections, one below the ring and slightly forward and one behind it slight upward - those are lens reflections. You can eliminate those by lighting your ring from behind instead of in front.
      The copper ring artifact is very nice - I've seen this phenomenon even with the naked eye. Easy to do, just bring a narrow object up to your pupil while focusing on a pattern in the background - you get the same type of effect.
      • a video
        YouTube - oxide core PMH device .....david
        • jet
          i got the mail today!...beautiful!...did you get a chance to see the latest vid?...the halo is the effect that lenses.....trying to get a better vid...david,,,,,Phttp://www.youtube.com/watch?v=72rSNIx0JKMS watch and comment...david
            Clickable link
              Hi David
              Glad you received the orgonite. Can you see something similar around it as you see on your devices?
              Jetijs
              • hi everyone......
                jet...yes i do....i am going to try and video this....there is a very very interesting thread/s over at thunderbolts.....by Lizzie...various energy and force speculations.....also, on "gods"genes etc. etc. ......very good reading...i must apologize for my videos, they do not do this energy field justice.....smokey2 at OU can agree with that...so i continue to try...david
                • What is the effect again that you are seeing?
                  I checked out the last video and to tell you the truth I did see something like a heat shimmer but it was sideways going twords the magnet. The one problem is that the carpet in the shot has a lot of texture to it and it is hard to tell any effects. Why not try a white piece of paper with lines on it... Like the old school paper. I think it is called loose leaf paper...
                  That might get you some where instead of trying to see from such a high texture shot. Digital cameras have a way with artifacting and we humans like to interpret that as the gods honest truth... So a better proof would be to bring the texture down a bit and just use some plain straight lined paper instead...
                  • hi everyone......
                    jbig...i will try that, possibly tonite....but to anyone who is interested...it seems like the videos are better before they are processed...so if i upload a video and let you know when, you could watch it before it is processed ...i do not know if this would help or hinder YouTube - another try david
                    • I wonder if growing plants in the presence of the PMH might cause some evidence to be manifested
                      Perhaps some bean sprouts or the like.
                      • hi everyone...
                        here is a bit of a post by Lizzie at thunderbolts.info...Torsion fields have been studied by several groups of Russian scientists for at least three decades and most of that time in secret. What are torsion fields? According to A. Akimov, these fields come in at least three types: E-fields, S-fields, and G-fields. The E, S, and G stand for Electric, Spin, and Gravity fields. The torsion field and its emanations are subtle energy fields. They are separate and distinct from classical Electric, Magnetic, and Gravity fields.
                        Torsion fields can be generated, detected, switched on and off (such as for communication purposes), and are a distinct type of energy field heretofore not included in today's classical physics. Torsion field emanations can travel at velocities at least as high as 109 times the speed of light. Torsion fields can interact with laser beams (change frequency); affect biological processes; are generated by melting or solidifying some materials; affect quartz crystals; affect some electronic components; can favorably change some beverages; and have been noted to affect gravity.
                        According to Akimov, torsion fields coupled with the standard electric, magnetic, and gravity fields should provide means for a unified field theory that will extend the realm of science to include the effects of consciousness.......i find this thread very interesting, i like the part about QUARTZ and the part about LASERS....sounds familiar!....the thread is various energy and force speculations......good stuff....i hope to get some good video up today...david
                        • Anyone interested to throw some quartz in the ice now?
                          • Originally posted by Harvey View Post
                            That's a really good suggestion. It could be just be thrown into a pot with some soil and the plant, as a control case a non PMH containing pot could be used. Daily pictures would show its grow progress.
                              I found my box of rocks - nothing big, just small ~3cm but I do have 3 different types of quartz.
                              I don't plan on doing any more ice tests though, but when I get around to it I may see if there are any effects with the elements. Busy with other things ATM.
                                Ok. Look forward for the test. Mine around that size too and the effect of a single rock is much greater that the effect from anyone PMH. But there is someone else that have nothing with quartz around the same size. If you have nothing then your rock is dead.
                                Plant may get influenced. But since the effect looks weak, we should not expect significant change. If you intent to try it with plant, notice which side that produce / void of bubble that you will be using.
